Celing Panel in BR Coming Down
07-11-2005, 00:43
Howdy, Y'all.
One of the ceiling panels in the bedroom is coming down. It is the
panel where the air conditioning grill is located. Standing in front
of the window, on the curb side, the lower right corner of this panel
has lifted up. At the lower left corner of this panel, I can see a
slight water mark on the on the strip directly below it. Now I don't
know how long that water mark has been there. When Jack comes home
from work, we will try and ease some paper toweling behind that panel
to see if there is some moisture in that area.
My question is what keeps those ceiling panels up? Are they glued at
the corners?
Thanks,
Liz
Fulltiming in a Wanderlodge
Regards,
Jack and Liz Pearce
1993 Wanderlodge WB40
Homesick Texans in Lantana, FL
07-12-2005, 04:58
Liz:
Sounds like you found your leak from a while back. The corners
are probably glued.
Moderator
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> Howdy, Y'all.
front
panel
don't
panel
at
> the corners?
> Thanks,
> Liz
> Regards,
> Jack and Liz Pearce
