Coolant Sensor Switch Location
07-11-2005, 06:02
My 81FC35 electric clutch fan will not engage unless I apply 12 volts
directly to the fan wiring. I suspect the problem is the thermostat
switch, But I can not locate this switch on the engine. Does anyone
know he location? When tracing the wiring from the clutch fan the power
wire connects to two additional wires. Does anyone have any idea where
these wires are coming from? I guess one is coming from the thermostat
switch.
Thanks
Charlie Shannon
Saint Albans, WV
81FC35
07-11-2005, 06:27
Charlie,
The thermal switch for the electric fan clutch is to the right of the fan on
the front of the engine It had three terminals on it and should have either
three or four wires.
Four wires if you have a dash over-ride switch. It's a cylinder looking
switch that screws into the front of the engine.
Chet Geist
1981 FC33, Austin, Texas
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of chaaur2
Sent: Monday, July 11, 2005 1:03 PM
Subject: [WanderlodgeForum] Coolant Sensor Switch Location
switch.
Thanks
Charlie Shannon
Saint Albans, WV
81FC35
YAHOO! GROUPS LINKS
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
