					microwave 110 v works  Invertor not
					09-14-2015, 09:32
					well after needing the genny 24/7, we are finally able to turn her off and open the windows . But , it turns out that on the invertor the micro and 2 other outlets are not working ?  . so with the genny running they work , with Invertor they do not ?  any thoughts GuRu s
				al perna 2000 LXI ormond beach fla  |
					09-14-2015, 09:47
				RE: microwave 110 v works  Invertor not
					Was it wired OEM, or by the PO, so that the inverter would not power those units to save battery power?  If so, one would need to move wires so that they WERE hooked to inverter power.
					09-14-2015, 10:14
					on the LXI it is powered thru the Inverter Ned
   Maybe it was done by the PO  , not sure as it worked for the past 3 years on Invertor ?
					09-14-2015, 10:26
					Hey Al, go into the inverter RC7 panels and disable auto-sensing.  See if that helps.
david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right"  |
					09-14-2015, 12:09
					relay switch under the bed , larger silver boxes, one will be tripped the other way. ??
Gregory O'Connor 2001 LXi43ss Romoland California 92585 951-830-5997 Rainbowrv.com  |
					09-14-2015, 19:25
(This post was last modified: 09-14-2015 19:27 by al perna.)
					and may I ask how that is done
![]() Greg, we do not have a box under the bed that I know of . If there is one it is covered in carpet, I will look ? al perna 2000 LXI ormond beach fla  |
