2002 LXi - NO POWER TO DC AUX AIR COMPRESSOR
08-27-2016, 14:52
All
1. My understanding is the DC source is simply from the house battery bank to a distribution panel, fused (both fuse number & panel location unknown to me) with no "on" / "off" switch but controlled by the 2nd pressure switch next to 110 VAC aux air pressure switch.
2. When purchased DC compressor was missing but wires appeared to be there. With bus DC system on, NO air pressure on bus air system and 110 VAC compressor OFF at breaker panel and NO pressure in small aux air tank cannot detect 12 VDC at wires or pressure switch.
3. Is my understanding correct and if so does anyone know the panel location and fuse number or can you expand on troubleshooting procedure.
All replies appreciated.
Dean
Dean M. Bertrand
Cape Coral, FL
2002 LXi 43 SS
dmbertrand@embarqmail.com
08-27-2016, 17:28
RE: 2002 LXi - NO POWER TO DC AUX AIR COMPRESSOR
Dean,
It should be circuit breaker SK37 in your front lower right load center. I'd also check for power across the pressure switch. These switches are known to fail.
08-27-2016, 18:26
David:
Thank you, unit in shop, will trace early next week and advise results.
Dean
Dean M. Bertrand
Cape Coral, FL
2002 LXi 43 SS
08-27-2016, 19:30 (This post was last modified: 08-27-2016 19:32 by cmillsap.)
Dean,
There are many electrical schematics on your LXi in the Document Library found by clicking on the link above. Every Wanderlodge LXi owner should have and carry the following list of fuse and relay locations found on their coach..
Attached File(s)
.doc  BBFUSEPUBA.doc (Size: 24 KB / Downloads: 944)
.doc  BBFUSEPUBB.doc (Size: 43.5 KB / Downloads: 984)
.doc  BBFUSEPUBC.doc (Size: 30 KB / Downloads: 888)
.doc  BBFUSEPUBD.doc (Size: 33.5 KB / Downloads: 1039)
.doc  BBFUSEPUBE.doc (Size: 28.5 KB / Downloads: 926)
.doc  BBFUSEPUBF.doc (Size: 25 KB / Downloads: 903)
.doc  BBFUSEPUBG.doc (Size: 30 KB / Downloads: 944)
[+] 2 users Like cmillsap's post
