basement electric heat
10-02-2016, 16:32
Sad basement electric heat
Please help how do you turn on the basement electric heat units, there is a thermostat: curb side bay but nothing happens??????
Mike Richard
Monson, MA.
2004 M380
2004 PT Cruiser Toad
10-02-2016, 20:39
RE: basement electric heat
Mike,
I may be wrong as it's been awhile since I owned a M380 but I'm thinking there are two (12VDC?) electric heaters in the bays. one curb side 3rd bay and one behind the water & septic bay driver side. I thought there was a dial thermostat on each unit. I can't remember if they are hard wired or plug-in. Never the less, you will need to determine if there is power going to them using a multi-meter. I would suspect a blown fuse if neither works.
10-03-2016, 07:25
Thank you I found 1 thermostat, near the heater curbside, I turned it up seems to get power but no heat? I tried turning electric heat on in Batroom(which works) and that did not help, fuse looks good, if fuse is marked correctly. Any ideas? Thank You...
Mike Richard
Monson, MA.
2004 M380
11-21-2016, 16:31
I found the problem with the Electric Heat in Basement. There was 2 unmarked fuses in bedroom that were missing. They were marked Spare in the Manual.
Mike Richard
Monson, MA.
2004 M380
