Wire tracing
07-28-2005, 16:26
Wire tracing
Can anyone recommend a decent "Tone & Probe" for tracing wires? I
tried the Home Depot unit and promptly returned the junk. Troy, 8FC33 |
07-28-2005, 16:38
Wire tracing
If you have the complete set of drawings for your coach, they are color
coded and very easy to trace once you learn the system. Most multimeters have a resistance function with a tone to check diodes and you can use that to trace wires if you want an easier method. Connect one probe to the wire you are interested in and the other end of the meter to ground. Then you can sequentially touch each wire in another location to ground and when it tones you have found the wire. This assumes of course you have all power turned off. Tom 1982 FC35 Vernon Center,NY At 04:26 AM 7/29/2005 +0000, you wrote: >Can anyone recommend a decent "Tone & Probe" for tracing wires? I >tried the Home Depot unit and promptly returned the junk. > >Troy, 8FC33 |
07-28-2005, 16:46
Wire tracing
Troy,
That is a good question. I've tried several different units and find the signal is very weak or nonexistent in larger wiring. I'll be interested in the responses to your note. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ttikalsky wrote: > Can anyone recommend a decent "Tone & Probe" for tracing wires? I > tried the Home Depot unit and promptly returned the junk. > > Troy, 8FC33 > |
07-28-2005, 17:11
Wire tracing
I have used this unit and it worked very well in tracing hidden circuits.
http://www.lashen.com/vendors/triplett/f...asp#3245-k Am not advocating the vendor, but the triplett unit. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions,, Oklahoma At 09:46 PM 7/28/2005 -0700, you wrote: >Troy, >That is a good question. I've tried several different units and find the >signal is very weak or nonexistent in larger wiring. I'll be interested >in the responses to your note. > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > >ttikalsky wrote: > > > Can anyone recommend a decent "Tone & Probe" for tracing wires? I > > tried the Home Depot unit and promptly returned the junk. > > > > Troy, 8FC33 > > > |
