Roof Air Conditioner Conversion Kit?
08-02-2005, 22:06
Howdy, Y'all.
The local RV repair guy quoted us approximately $900 for a new Dometic
roof AC. Included was cost for a conversion kit. Anyone know what this
"conversion kit" is?
Regards,
Liz
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
Homesick Texans in SE. FL
08-02-2005, 22:17
Jack and Liz,
I'm biting my tounge here but conversion kit my ...... Join
Camping World Presidents club, get one of their "additional 10% off"
coupons and order a new Dometic in the $600+ range. A couple of
years ago I put two new Dometic Penguins on my 'bird by playing the
Camping World coupon game and I feel like I came out way ahead. I
think the big difference with yours is that the inside portion is
different since yours is ducted. It sounds like the outside portion
is all you are needing so I don't see where the $900 figure comes
from let alone a "conversion" kit. If I'm wrong about this someone
else pipe up......
John Stiles
1980 33FC
"My Navion"
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> Howdy, Y'all.
Dometic
this
> Regards,
> Liz
> Regards,
> Jack and Liz Pearce
08-03-2005, 00:35
Jack and Liz:
I agree with John completely. The roof AC units do come in 2 pieces, the AC
unit and the air distribution box. They are separate pieces and usually the
old air distribution box will not fit the new AC unit because of changes in
design or what ever. They also must be compatible if your Rig is set up
with the master/slave type of thermostat controls. Go to Camping World and
save yourself 2 or 3 hundred dollars. Installation should not run over
135.00 as a norm, over the marked up price of a new unit.
Safe travels,
At 10:17 AM 8/3/2005 +0000, you wrote:
>Jack and Liz,
>else pipe up......
>John Stiles
>1980 33FC
>"My Navion"
> > Howdy, Y'all.
>Dometic
>this
> > Regards,
> > Liz
> > Regards,
> > Jack and Liz Pearce
08-03-2005, 02:15
Converting your money to his dishonest pocket.
I have installed several of these airs and it can easily be done in less
than an hour.
The a/c units come complete and require no conversion kit.
08-03-2005, 07:49
I recently replaced the roof airs on my PT40 WB and learned the
following.
I replaced my Dometics with Dometics but had to change the
thermastat wire form an 8 pin type to a 4 pins type. The conduet
from the air unit to the thermostat (in my coach) was ribbed plastic
and very hard to pull the new wire thru, in fact on one unit I had
to reroute the wire completely. The thermostat has to be replaced to
the new 4 pin type as well. The air units innerchanged on the roof
openings and wireing easily with minor changes.
I paid about $600.00 each including thermostats.
Gene Shutt
1988 PT-40-WB
> Jack and Liz:
pieces, the AC
usually the
changes in
set up
World and
over
> Safe travels,
> >Jack and Liz,
off"
portion
someone
> >else pipe up......
> >John Stiles
> >1980 33FC
> >"My Navion"
> > wrote:
> > > Howdy, Y'all.
> >Dometic
what
> >this
> > > Regards,
> > > Liz
> > > Regards,
> > > Jack and Liz Pearce
