Why the engine replacements?
08-26-2005, 16:25
Hi all,
This is Christina's hubby, Phil. She's shared your answers to her previous posts/questions with me while I was on the road. Everyone has been very helpful. Thank you. In way of introduction, I am a carhauler--I drive one of those rigs you see hauling 9-10 new cars to dealerships. Prior to that I was in the towing/heavy equipment transport business, and prior to that, I owned an auto repair business. Can you guess what my duties will be when we find our 'bird? Which brings me to my question. While reading the Bluebird 'for sale' listings on various websites, I noticed a good percentage of the listings noted, "coach has 120,000 miles, engine has 20,000 miles" or, "low miles on 'new' motor", etc.,etc. What struck me was the relatively low mileage on the motors being replaced. Keep in mind I've been driving diesel rigs for several years and it's routine to run them 500,000 miles before any major repairs, if any, are performed, and then it will probably be an in frame overhaul. I've also driven medium duty trucks with gas engines that ran 200-300,000 miles before anything major. So, my question for you veteran Bluebird owners--why do I see comments about motors being replaced in coaches that the seller is claiming has relatively low miles (less that 125,000)? I'm making some assumptions here--tell me if I'm right or wrong, or somewhere in between: 1. Someone got sold a bill of goods. 2. Lack of use (5000 miles per year for 15-20 years). Engine gaskets and seals blowing out. 3. Something regarding the durability of diesel motors primarily used in the Bluebird. 4. Lack of proper maintenance of the lubrication and/or cooling systems, causing premature wear or overheating. 5. Original motor was underpowered and the replacement was an upgrade to more horsepower. There may be more assumptions to be made, but these are the first that come to mind. All comments are welcome. Thanks, Phil |
08-26-2005, 17:32
Phil, I just bought a 94pt40 last month and started looking two
months prior. I too found it unusual that low mile birds had new engines. I have several dump trucks with over 400,000 and drive them hard off road and they have the orig powerplants. The 3208 Cats are not a sleve cylinder engine and an inframe is not possible but with such low miles I dont think they ever get worn out. I think operators are over tacking the Cats or lugging them and burning them up. The 4 and 5 allison gives less room for mistakes then a 10 speed manual shift. I have a 8v92 detroit and let me tell you that I have alot to learn as I try to keep the r's up and the temp down. I look at the gauges and once in a while I look at the road. It is hard to climb a hill and keep the trans from down shifting to a lug with only 5 speeds to use. I think the detroits were just driven wrong. Cant go wrong if you get a bird from Miller coach works or Randy Dupree, wish I did. Greg O'Connor 94pt40 CAlifornia When I drive --- In WanderlodgeForum@yahoogroups.com, "Christina Corpus" > Hi all, > > This is Christina's hubby, Phil. She's shared your answers to her > previous posts/questions with me while I was on the road. Everyone > has been very helpful. Thank you. > > In way of introduction, I am a carhauler--I drive one of those rigs > you see hauling 9-10 new cars to dealerships. Prior to that I was in > the towing/heavy equipment transport business, and prior to that, I > owned an auto repair business. Can you guess what my duties will be > when we find our 'bird? > > Which brings me to my question. > > While reading the Bluebird 'for sale' listings on various websites, I > noticed a good percentage of the listings noted, "coach has 120,000 > miles, engine has 20,000 miles" or, "low miles on 'new' motor", > etc.,etc. What struck me was the relatively low mileage on the motors > being replaced. > > Keep in mind I've been driving diesel rigs for several years and it's > routine to run them 500,000 miles before any major repairs, if any, > are performed, and then it will probably be an in frame overhaul. I've > also driven medium duty trucks with gas engines that ran 200-300,000 > miles before anything major. > > So, my question for you veteran Bluebird owners--why do I see comments > about motors being replaced in coaches that the seller is claiming has > relatively low miles (less that 125,000)? > > I'm making some assumptions here--tell me if I'm right or wrong, or > somewhere in between: > > 1. Someone got sold a bill of goods. > > 2. Lack of use (5000 miles per year for 15-20 years). Engine gaskets > and seals blowing out. > > 3. Something regarding the durability of diesel motors primarily used > in the Bluebird. > > 4. Lack of proper maintenance of the lubrication and/or cooling > systems, causing premature wear or overheating. > > 5. Original motor was underpowered and the replacement was an upgrade > to more horsepower. > > There may be more assumptions to be made, but these are the first > that come to mind. > > All comments are welcome. > > Thanks, > > Phil |
08-27-2005, 00:26
Greg's post Sounds reasonable to me along with several items
mentioned by Phil: 2. Lack of use (5000 miles per year for 15-20 years). Engine gaskets and seals blowing out. 4. Lack of proper maintenance of the lubrication and/or cooling systems, causing premature wear or overheating. Along with trying to limp in with a problem, when a pro trucker might pull over and wait for a service truck. Dan previous 83 FC35 with the Cat 3208 now 94 BMC 37' with the Cummnins --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Phil, I just bought a 94pt40 last month and started looking two > months prior. I too found it unusual that low mile birds had new > engines. I have several dump trucks with over 400,000 and drive them > hard off road and they have the orig powerplants. The 3208 Cats are > not a sleve cylinder engine and an inframe is not possible but with > such low miles I dont think they ever get worn out. I think > operators are over tacking the Cats or lugging them and burning them > up. The 4 and 5 allison gives less room for mistakes then a 10 speed > manual shift. I have a 8v92 detroit and let me tell you that I have > alot to learn as I try to keep the r's up and the temp down. I look > at the gauges and once in a while I look at the road. It is hard to > climb a hill and keep the trans from down shifting to a lug with only > 5 speeds to use. I think the detroits were just driven wrong. Cant > go wrong if you get a bird from Miller coach works or Randy Dupree, > wish I did. > > Greg O'Connor > 94pt40 CAlifornia > > When I drive --- In WanderlodgeForum@yahoogroups.com, "Christina > Corpus" > > Hi all, > > > > This is Christina's hubby, Phil. She's shared your answers to her > > previous posts/questions with me while I was on the road. Everyone > > has been very helpful. Thank you. > > > > In way of introduction, I am a carhauler--I drive one of those rigs > > you see hauling 9-10 new cars to dealerships. Prior to that I was > in > > the towing/heavy equipment transport business, and prior to that, I > > owned an auto repair business. Can you guess what my duties will be > > when we find our 'bird? > > > > Which brings me to my question. > > > > While reading the Bluebird 'for sale' listings on various websites, > I > > noticed a good percentage of the listings noted, "coach has 120,000 > > miles, engine has 20,000 miles" or, "low miles on 'new' motor", > > etc.,etc. What struck me was the relatively low mileage on the > motors > > being replaced. > > > > Keep in mind I've been driving diesel rigs for several years and > it's > > routine to run them 500,000 miles before any major repairs, if any, > > are performed, and then it will probably be an in frame overhaul. > I've > > also driven medium duty trucks with gas engines that ran 200- 300,000 > > miles before anything major. > > > > So, my question for you veteran Bluebird owners--why do I see > comments > > about motors being replaced in coaches that the seller is claiming > has > > relatively low miles (less that 125,000)? > > > > I'm making some assumptions here--tell me if I'm right or wrong, or > > somewhere in between: > > > > 1. Someone got sold a bill of goods. > > > > 2. Lack of use (5000 miles per year for 15-20 years). Engine > gaskets > > and seals blowing out. > > > > 3. Something regarding the durability of diesel motors primarily > used > > in the Bluebird. > > > > 4. Lack of proper maintenance of the lubrication and/or cooling > > systems, causing premature wear or overheating. > > > > 5. Original motor was underpowered and the replacement was an > upgrade > > to more horsepower. > > > > There may be more assumptions to be made, but these are the first > > that come to mind. > > > > All comments are welcome. > > > > Thanks, > > > > Phil |
08-27-2005, 03:39
Phil,
I think you are on track with your # 2 & # 4 assumptions. Neglect, lack of knowledge, and trying to save a dime on routine maintenance. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Christina Corpus" > Hi all, > > This is Christina's hubby, Phil. She's shared your answers to her > previous posts/questions with me while I was on the road. Everyone > has been very helpful. Thank you. > > In way of introduction, I am a carhauler--I drive one of those rigs > you see hauling 9-10 new cars to dealerships. Prior to that I was in > the towing/heavy equipment transport business, and prior to that, I > owned an auto repair business. Can you guess what my duties will be > when we find our 'bird? > > Which brings me to my question. > > While reading the Bluebird 'for sale' listings on various websites, I > noticed a good percentage of the listings noted, "coach has 120,000 > miles, engine has 20,000 miles" or, "low miles on 'new' motor", > etc.,etc. What struck me was the relatively low mileage on the motors > being replaced. > > Keep in mind I've been driving diesel rigs for several years and it's > routine to run them 500,000 miles before any major repairs, if any, > are performed, and then it will probably be an in frame overhaul. I've > also driven medium duty trucks with gas engines that ran 200- 300,000 > miles before anything major. > > So, my question for you veteran Bluebird owners--why do I see comments > about motors being replaced in coaches that the seller is claiming has > relatively low miles (less that 125,000)? > > I'm making some assumptions here--tell me if I'm right or wrong, or > somewhere in between: > > 1. Someone got sold a bill of goods. > > 2. Lack of use (5000 miles per year for 15-20 years). Engine gaskets > and seals blowing out. > > 3. Something regarding the durability of diesel motors primarily used > in the Bluebird. > > 4. Lack of proper maintenance of the lubrication and/or cooling > systems, causing premature wear or overheating. > > 5. Original motor was underpowered and the replacement was an upgrade > to more horsepower. > > There may be more assumptions to be made, but these are the first > that come to mind. > > All comments are welcome. > > Thanks, > > Phil |
08-27-2005, 07:21
Phil,
Very good question. I've pondered the same thing before and would have to agree with your assumptions #1 and #4, with #2 being a part of #4. I've been following the Wanderlodge forums for 4 years or so now, and am often amazed when the topic of lubrication comes up and people are trying to figure out the minimum they can get away with when maintaining their engines/drivelines. Do I hafta use expensive lubricants? Do I hafta change the oil before storage? Should I bother with oil sampling? Should I bother with additives in the coolant? Normally these folks become converts to proper mechanical maintenance after the discussions, but there are folks out there who don't partake in the forum. How often should I check the oil? Well, if you have to ask, probably more often than you are... Regarding assumption #1, I saw receipts from an owner of a fresh transmission fluid and filter change (internal and external). His transmission had no internal filter (to my knowledge), and the spin on filter had a date marked on it with marker over 5 years old! I insist on keeping a friendly eye on the folks who work on my coach (rare). Some folks overspin their engines. This'll kill the CAT. The way I understand it the valve springs can't keep up and it eats a valve. These coaches were built when the national speed limit was 55 and most were geared for about 65 max. So unless you install a new rear end or larger tires, that's all you should do. As you know, the governor won't slow the engine if the driver wants to point the rig downhill and mat the pedal and some tach's are in need of adjustments after many years. There's always the temptation to be motoring on down the road, but hey, if there's a house on your back, what's the hurry? You're already there. So improper maintenance like no valve lash adjustment at the proper interval, plus overspinning, plus perhaps marginal lubrication, and maybe no additives in the coolant... How long can the poor engine last? If Grandpa hasn't driven it in five years, perhaps it should have fresh fluids before start-up. It happens. The engines are all very staunch, heavy duty top line units. But they're only bulletproof with proper maintenance. I wouldn't make the assumption that all the engines have a checkered past though. What you are seeing is a small percentage of coaches that have been misunderstood by their owners and are being sold. I would look for an owner who baby's his coach, changes fluids and keeps records, gets oil samples, and generally would rather keep his coach than sell it. Oh wait...that's me! ![]() Gary Miller 83 FC 33 - For Sale 'millercoachworks.com' Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Christina Corpus" > Hi all, > > This is Christina's hubby, Phil. She's shared your answers to her > previous posts/questions with me while I was on the road. Everyone > has been very helpful. Thank you. > > In way of introduction, I am a carhauler--I drive one of those rigs > you see hauling 9-10 new cars to dealerships. Prior to that I was in > the towing/heavy equipment transport business, and prior to that, I > owned an auto repair business. Can you guess what my duties will be > when we find our 'bird? > > Which brings me to my question. > > While reading the Bluebird 'for sale' listings on various websites, I > noticed a good percentage of the listings noted, "coach has 120,000 > miles, engine has 20,000 miles" or, "low miles on 'new' motor", > etc.,etc. What struck me was the relatively low mileage on the motors > being replaced. > > Keep in mind I've been driving diesel rigs for several years and it's > routine to run them 500,000 miles before any major repairs, if any, > are performed, and then it will probably be an in frame overhaul. I've > also driven medium duty trucks with gas engines that ran 200- 300,000 > miles before anything major. > > So, my question for you veteran Bluebird owners--why do I see comments > about motors being replaced in coaches that the seller is claiming has > relatively low miles (less that 125,000)? > > I'm making some assumptions here--tell me if I'm right or wrong, or > somewhere in between: > > 1. Someone got sold a bill of goods. > > 2. Lack of use (5000 miles per year for 15-20 years). Engine gaskets > and seals blowing out. > > 3. Something regarding the durability of diesel motors primarily used > in the Bluebird. > > 4. Lack of proper maintenance of the lubrication and/or cooling > systems, causing premature wear or overheating. > > 5. Original motor was underpowered and the replacement was an upgrade > to more horsepower. > > There may be more assumptions to be made, but these are the first > that come to mind. > > All comments are welcome. > > Thanks, > > Phil |
08-27-2005, 11:02
Greg,
I agree with you that low mileage motors probably weren't replaced because they were worn out. More a matter of something breaking due to misuse. Lack of knowledge on how to operate a heavy diesel powered vehicle (over- taching the RPM's or lugging it down) results in an expensive lesson. Good reason to read the operator manuals. When my wife and I are looking at cockpit photos of units for sale, she kids me about, "it's got all of the guages you want." I tell her, "the more, the merrier." All those guages tell me what is happening under the dog house and floor boards. Keep the R's up and temp down. Phil --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Phil, I just bought a 94pt40 last month and started looking two > months prior. I too found it unusual that low mile birds had new > engines. I have several dump trucks with over 400,000 and drive them > hard off road and they have the orig powerplants. The 3208 Cats are > not a sleve cylinder engine and an inframe is not possible but with > such low miles I dont think they ever get worn out. I think > operators are over tacking the Cats or lugging them and burning them > up. The 4 and 5 allison gives less room for mistakes then a 10 speed > manual shift. I have a 8v92 detroit and let me tell you that I have > alot to learn as I try to keep the r's up and the temp down. I look > at the gauges and once in a while I look at the road. It is hard to > climb a hill and keep the trans from down shifting to a lug with only > 5 speeds to use. I think the detroits were just driven wrong. Cant > go wrong if you get a bird from Miller coach works or Randy Dupree, > wish I did. > > Greg O'Connor > 94pt40 CAlifornia > > |
08-27-2005, 11:37
Phil you and many of the operators that read this forum know about
over rpm damage but I think it deserves to be pointed out that you can cook a motor by over rpming "r'ing" on a down hill with your foot off the fuel. by using back pressure in the motor and a lower gear I never let the r's go over 2,000 before I ride the brakes slowing the r's to 1,800. on a down hill I flip the fan overide switch which puts a load on the engine and helps to keep it in the r range. One other reason I think the engines are swapped inplace of a rebuild or inframe repair is ;A coach sold with unknown engine probs is sold so low $ that a reman swap is cost effective and gives the new owner peace of mind. I run the limits on oilchanges, I dont do sampling because I dont want to spend the $ or see the results, I stopped using additives after Rogain failed me back in the 80's. It may be wise to do all the over maintaining things but as Jeff Miller points out doing the right maintainance at the proper time is key. Greg Bald in California --- In WanderlodgeForum@yahoogroups.com, "Christina Corpus" > Greg, > > I agree with you that low mileage motors probably weren't replaced > because they were worn out. More a matter of something breaking due > to misuse. > > Lack of knowledge on how to operate a heavy diesel powered vehicle > (over- taching the RPM's or lugging it down) results in an expensive > lesson. Good reason to read the operator manuals. > > When my wife and I are looking at cockpit photos of units for sale, > she kids me about, "it's got all of the guages you want." I tell her, > "the more, the merrier." All those guages tell me what is happening > under the dog house and floor boards. > > Keep the R's up and temp down. > > Phil > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > Phil, I just bought a 94pt40 last month and started looking two > > months prior. I too found it unusual that low mile birds had new > > engines. I have several dump trucks with over 400,000 and drive > them > > hard off road and they have the orig powerplants. The 3208 Cats > are > > not a sleve cylinder engine and an inframe is not possible but with > > such low miles I dont think they ever get worn out. I think > > operators are over tacking the Cats or lugging them and burning > them > > up. The 4 and 5 allison gives less room for mistakes then a 10 > speed > > manual shift. I have a 8v92 detroit and let me tell you that I have > > alot to learn as I try to keep the r's up and the temp down. I > look > > at the gauges and once in a while I look at the road. It is hard > to > > climb a hill and keep the trans from down shifting to a lug with > only > > 5 speeds to use. I think the detroits were just driven wrong. Cant > > go wrong if you get a bird from Miller coach works or Randy Dupree, > > wish I did. > > > > Greg O'Connor > > 94pt40 CAlifornia > > > > |
08-27-2005, 15:42
Good point, Dan. Thanks.
Of course, I can call the company maintenance department and pass the buck to them whether or not to call road service. It's not any money out of my pocket. I guess that's why subscribing to an emergency road service program may be wise for an RV owner. Phil --- In WanderlodgeForum@yahoogroups.com, "Dan Weaver" > > Greg's post Sounds reasonable to me along with several items > mentioned by Phil: > 2. Lack of use (5000 miles per year for 15-20 years). Engine gaskets > and seals blowing out. > 4. Lack of proper maintenance of the lubrication and/or cooling > systems, causing premature wear or overheating. > > Along with trying to limp in with a problem, when a pro trucker > might pull over and wait for a service truck. > > Dan > previous 83 FC35 with the Cat 3208 > now 94 BMC 37' with the Cummnins > > |
08-27-2005, 17:03
Gary,
Thanks for your reply. --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > Phil, > > Very good question. I've pondered the same thing before and would > have to agree with your assumptions #1 and #4, with #2 being a part > of #4. > > I've been following the Wanderlodge forums for 4 years or so now, > and am often amazed when the topic of lubrication comes up and > people are trying to figure out the minimum they can get away with > when maintaining their engines/drivelines. Do I hafta use expensive > lubricants? Do I hafta change the oil before storage? Should I > bother with oil sampling? Should I bother with additives in the > coolant? Normally these folks become converts to proper mechanical > maintenance after the discussions, but there are folks out there who > don't partake in the forum. Kind of like the old TV ad, "Pay me now, or pay me later." Sounds like asking a seller whether or not he has all his service records available would be a good idea. If not, then it's 'buyer beware' time. > How often should I check the oil? Well, if you have to ask, > probably more often than you are... Copy that. > > Regarding assumption #1, I saw receipts from an owner of a fresh > transmission fluid and filter change (internal and external). His > transmission had no internal filter (to my knowledge), and the spin > on filter had a date marked on it with marker over 5 years old! I > insist on keeping a friendly eye on the folks who work on my coach > (rare). ...and since there is more money to made... > > Some folks overspin their engines. This'll kill the CAT. The way I > understand it the valve springs can't keep up and it eats a valve. One company I worked for installed a CAT engine into one its medium duty trucks. It was replacing a Cummins. The thing I remember about driving that truck after the swap was how quickly the CAT engine peaked out in each gear. You definitely had to watch the tach. > These coaches were built when the national speed limit was 55 and > most were geared for about 65 max. So unless you install a new rear > end or larger tires, that's all you should do. As you know, the > governor won't slow the engine if the driver wants to point the rig > downhill and mat the pedal and some tach's are in need of > adjustments after many years. Out here in California, we have the Grapevine heading north out of Los Angeles. On the north side, northbound, the speed limit for trucks is 35 mph. I downshift my 78,000 pound truck into 6th gear, engage the Jake brake, and cruise down that grade at 18 mph, never touching the brake pedal. I am constantly amazed at all the motorhomes that pass me going full tilt down that mountain. I mean, they are keeping up with the cars that are going down at 75 mph. You can hear the engines winding out tight. > There's always the temptation to be motoring on down the road, but > hey, if there's a house on your back, what's the hurry? You're >already there. Our plan is to full time, so this is exactly our philosophy. > > The engines are all very staunch, heavy duty top line units. But > they're only bulletproof with proper maintenance. > > I wouldn't make the assumption that all the engines have a checkered > past though. What you are seeing is a small percentage of coaches > that have been misunderstood by their owners and are being sold. It appears from the responses to my question from everyone that there is no issue regarding the durability of the engines used in the Bluebird. > > I would look for an owner who baby's his coach, changes fluids and > keeps records, gets oil samples, and generally would rather keep his > coach than sell it. Oh wait...that's me! ![]() My wife is very impressed with your coach. I have to remind her what our plans are and that 35 feet is the minimum we've decided on. Now if you could figure out how to extend your unit 2-3 feet... :>) > > Gary Miller > 83 FC 33 - For Sale 'millercoachworks.com' > Milwaukee area > |
08-28-2005, 01:35
Phil,
Thanks for the nice words. Can't stretch the coach for ya. Have to admit, if I were full-timing, the extra two closets in the 35 footer would come in handy, though not critical. Truth be told we've never run out of storage with three kids and two adults on long trips. Overthinking things a bit (which I tend to do), a 35 foot coach is about 2000 pounds heavier than a 33 on the same axles. Those are heavy closets! (extra A/C, heavier genset, slightly larger fuel tank, bigger jacks, etc...) Pulling 2000 pounds more trailer or toad likely offers even more storage than the two closets, and it's not on the axles. Hmmmm. Just thought I'd muddy the water for you. Gary Miller 83 FC 33 - For Sale 'millercoachworks.com' Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Christina Corpus" > Gary, > > Thanks for your reply. > > > --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > > > Phil, > > > > Very good question. I've pondered the same thing before and would > > have to agree with your assumptions #1 and #4, with #2 being a part > > of #4. > > > > I've been following the Wanderlodge forums for 4 years or so now, > > and am often amazed when the topic of lubrication comes up and > > people are trying to figure out the minimum they can get away with > > when maintaining their engines/drivelines. Do I hafta use > expensive > > lubricants? Do I hafta change the oil before storage? Should I > > bother with oil sampling? Should I bother with additives in the > > coolant? Normally these folks become converts to proper mechanical > > maintenance after the discussions, but there are folks out there > who > > don't partake in the forum. > > Kind of like the old TV ad, "Pay me now, or pay me later." Sounds > like asking a seller whether or not he has all his service records > available would be a good idea. If not, then it's 'buyer beware' > time. > > > > How often should I check the oil? Well, if you have to ask, > > probably more often than you are... > > Copy that. > > > > > Regarding assumption #1, I saw receipts from an owner of a fresh > > transmission fluid and filter change (internal and external). His > > transmission had no internal filter (to my knowledge), and the spin > > on filter had a date marked on it with marker over 5 years old! I > > insist on keeping a friendly eye on the folks who work on my coach > > (rare). > > ...and since there is more money to made... > > > > > > Some folks overspin their engines. This'll kill the CAT. The way > I > > understand it the valve springs can't keep up and it eats a valve. > > One company I worked for installed a CAT engine into one its medium > duty trucks. It was replacing a Cummins. The thing I remember about > driving that truck after the swap was how quickly the CAT engine > peaked out in each gear. You definitely had to watch the tach. > > > > These coaches were built when the national speed limit was 55 and > > most were geared for about 65 max. So unless you install a new > rear > > end or larger tires, that's all you should do. As you know, the > > governor won't slow the engine if the driver wants to point the rig > > downhill and mat the pedal and some tach's are in need of > > adjustments after many years. > > Out here in California, we have the Grapevine heading north out of Los > Angeles. On the north side, northbound, the speed limit for trucks is > 35 mph. I downshift my 78,000 pound truck into 6th gear, engage the > Jake brake, and cruise down that grade at 18 mph, never touching the > brake pedal. I am constantly amazed at all the motorhomes that pass > me going full tilt down that mountain. I mean, they are keeping up > with the cars that are going down at 75 mph. You can hear the engines > winding out tight. > > > There's always the temptation to be motoring on down the road, but > > hey, if there's a house on your back, what's the hurry? You're > >already there. > > Our plan is to full time, so this is exactly our philosophy. > > > > > > The engines are all very staunch, heavy duty top line units. But > > they're only bulletproof with proper maintenance. > > > > I wouldn't make the assumption that all the engines have a > checkered > > past though. What you are seeing is a small percentage of coaches > > that have been misunderstood by their owners and are being sold. > > It appears from the responses to my question from everyone that there > is no issue regarding the durability of the engines used in the > Bluebird. > > > > > > I would look for an owner who baby's his coach, changes fluids and > > keeps records, gets oil samples, and generally would rather keep > his > > coach than sell it. Oh wait...that's me! ![]() > > My wife is very impressed with your coach. I have to remind her what > our plans are and that 35 feet is the minimum we've decided on. Now > if you could figure out how to extend your unit 2-3 feet... :>) > > > > > Gary Miller > > 83 FC 33 - For Sale 'millercoachworks.com' > > Milwaukee area > > |
