Upper dash hinges down-- but how?
09-20-2005, 12:53
I am still learning on my new 89wlsp. I want to explore on replacing
my old original TV. Does the TV also swing down and how do you get it
to swing.Thanks for your help!!
09-20-2005, 22:54
In a message dated 9/20/2005 8:58:48 P.M. Eastern Daylight Time,
egardata@... writes:
I just put a new LCD Flat Screen TV in the front of my 89 WL 36' SP. When
you open up the side doors there are some screws that hold the panel on that
the TV is in. When you take the screws out the panel comes off & then you can
take the TV out. After I had it out I made a bracket to mount the New Flat
Screen to the same face panel. It is a 20" Sharp TV & it worked out really
well. Can't tell that it wasn't made that way. Hope this helps
Don
89 SP 36' & 79 FC 33' for sale
Butler, PA
09-21-2005, 03:14
You do not need to swing the overhead dash down to remove the TV.
Pull the interior of the overhead storage areas on either side of the
TV. They are held in place by 3 or 4 screws in the forward edge of
the bottom of the storage compartment. Once they are out you can see
what it takes to liberate the TV. If you are tossing anything that
works, let me know, I might be interested.
--- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
09-21-2005, 05:04
--- In WanderlodgeForum@yahoogroups.com, "fred89sp"
see
replacing
get it
Thanks for the respone Fred, I havent thrown away anything yet. I
did take my antenna dome down and apart. It looks unrepairable to me.
I remember you saying that you repaired yours several times and
gave up. has any one mounted a multidirectional dome on top of the
raising mechanism, to be able to raise it?
09-21-2005, 06:25
I have replaced the domes in the past but they are no longer available
from Tandy.
As far as I am concerned they cannot be repaired.
I think someone, possibly Steve Birtles, has a replacement from
another manufacturer.
> the
> see
> replacing
> get it
09-21-2005, 06:35
We have the replacement OEM Antenna
for the Wanderlodge drop me a line
info AT capeinnovation dot com
Stephen 77fc35
> from Tandy.
> > the
> > see
> > replacing
> > get it
