high idle
10-03-2005, 17:23
high idle
On my coaches with the high idle engaged the throttle pedal never did
anything. When the high idle is turned off everything is normal. Mike |
10-03-2005, 20:18
high idle
I recall, that when I was going down the freeway with the cruise on, I
reached for my CB mike, which is located right beside high idle lever. Hit the lever and the cruise disengaged, thought the engine had died and pulled over- just in time to see what I did. Now, I keep the mike on the dash. Ernie -83pt40 in montana [Non-text portions of this message have been removed] |
10-04-2005, 04:15
high idle
Much of this depends upon the type of throttle you have. If you have
an air throttle, it does not move; If you have a cable throttle, it normally will move. The fast idle is applied at the governor throttle arms, therefore it does not affect the air throttle; the cable throttle, having a mechanical connection to the throttle pedal will move the pedal. Hope this helps. George Lowry '95 WBDA 4203 Spearfish, SD Currently in Northern California Mike McMahan wrote: > On my coaches with the high idle engaged the throttle pedal never did > anything. When the high idle is turned off everything is normal. Mike > > > > > > > Yahoo! Groups Links > > > > > > > > > |
