Eaton power sterring seal failure-twice
10-20-2005, 04:57
I have an Eaton model 243p power sterring pump.The front seal was
weeping and I took it in for repair.It blew the shaft seal in about 500 miles.The second time in about 800 miles.It was sent and repaired by the same company[Hydra Steer].Thay say that it was not there problem and that it was a system failure,air bubble,turning sterring wheel to stop position and holding,rough roads,hitting curbs. No contamination was found.It was set to supply 4gpm at 1750 psi. Any coments. Ken Kalmakoff 3208t 1982-35 Richmond, BC Canada |
