onan 3 cyl generator '90wlsp36
10-22-2005, 11:00
Help,
I just returned from an extended business trip and went to start the generator on my bird (which was running fine when I left) and it will start and immediately shut down. For the short time it runs it blows lots of black smoke. The air cleaner is brand new and unobstructed. I can keep it running by manually pulling back on the lever attached to the stop solenoid. Other items noticed are the oil pressure and temp gauges which appeared to be pegged (before I tried to start it the first time). |
10-22-2005, 12:15
Check for 12 volts at the fuel shut off solenoid.
Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Help, > I just returned from an extended business trip and went to start > the generator on my bird (which was running fine when I left) and it > will start and immediately shut down. For the short time it runs it > blows lots of black smoke. The air cleaner is brand new and > unobstructed. I can keep it running by manually pulling back on the > lever attached to the stop solenoid. Other items noticed are the > oil pressure and temp gauges which appeared to be pegged (before I > tried to start it the first time). > |
10-22-2005, 14:10
> > Help, > I just returned from an extended business trip and went to start > the generator on my bird (which was running fine when I left) and it > will start and immediately shut down. For the short time it runs it > blows lots of black smoke. The air cleaner is brand new and > unobstructed. I can keep it running by manually pulling back on the > lever attached to the stop solenoid. Other items noticed are the > oil pressure and temp gauges which appeared to be pegged (before I > tried to start it the first time). > Same thing happened to me once ..turned out just simple problem of ..swithches on generator..one was tripped off...i wasted a lot of time until I checked them...sometimes we look for a major problem and it turns out to be a simple fix on our birds. Regards, Hank Hannigan 90SP36 |
