House Heating Systems Questions
10-31-2005, 05:57
your thermocouple might be dirty. use a small wire brush and gently clean
that area. mine were dirty and that did the trick. ernie-83pt40 in montana
10-31-2005, 08:43
> Steve- do you hear the ignitin sequence when you turn your heater
on? There should be a valve in your outside refer access panel.
Ernie, if you mean a clicking, like the refer makes when it ignites, I
didn't notice it.
I know there is a valve for the refer in the outside access panel,
does this connect to the furnaces too, or is there another one in
there I missed? There is a valve next to the individual heater, which
is on.
Blair, I'll clean it up. I work 6 out of the next 8 days, then I have
a week off. Jane has to work then, so I'll take the RV out someplace
in southern UT. I'd get in too much trouble if I went to Las Vegas by
myself :-)
Steve
St. George, UT
'86 PT38
