90WLSP36 Smoke and heat
11-18-2005, 04:39
Just recently my bird began to blow blue oil smoke when it was cold.
This symptom has gradually gotten worse over the last 3 months. After warmup the smoke disappeared (after 10 min or so). I took it to the local Cat dealer who discovered that the turbo was shot. He replaced the turbo ($4000.00 +) and the oil smoke is worse than before, what's more, the engine will not heat to above 160 deg. whereas before it ran at 190 deg. The dealer says I have to run it hard to clean the engine out but I have to get the engine temp up. The oil temp also does not go up over 170 deg. Does this sound like symptoms of a stuck thermostat? If so, how hard is it to replace and what would cause the excessive oil smoke? Thanks, Chuck Harrison Akron, Ohio 90 WL SP36 |
11-18-2005, 06:01
First, I would change the thermostat.
I think you have the Cat 3208TA, 300 HP. My 300 HP had only one thermostat some older 3208's have two. Stop at the Cat parts dept and they can print out a picture of this area. It is not too difficult to change. If you decide to do the repair yourself, I or this forum can give further details. Could be injectors or more, you need to give more symptoms. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Just recently my bird began to blow blue oil smoke when it was cold. > This symptom has gradually gotten worse over the last 3 months. > After warmup the smoke disappeared (after 10 min or so). I took it > to the local Cat dealer who discovered that the turbo was shot. > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > before, what's more, the engine will not heat to above 160 deg. > whereas before it ran at 190 deg. The dealer says I have to run it > hard to clean the engine out but I have to get the engine temp up. > The oil temp also does not go up over 170 deg. Does this sound like > symptoms of a stuck thermostat? If so, how hard is it to replace and > what would cause the excessive oil smoke? > > Thanks, > Chuck Harrison > Akron, Ohio > 90 WL SP36 > |
11-18-2005, 06:41
>Fuel is black, oil is blue, when cold, there could be some oil left on the cylinder that burns off, I have been told by a great diesel mechanic, that if I were blowing blue smoke it could be the rings. As always a second apinion is good advice. > Just recently my bird began to blow blue oil smoke when it was cold. > This symptom has gradually gotten worse over the last 3 months. > After warmup the smoke disappeared (after 10 min or so). I took it > to the local Cat dealer who discovered that the turbo was shot. > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > before, what's more, the engine will not heat to above 160 deg. > whereas before it ran at 190 deg. The dealer says I have to run it > hard to clean the engine out but I have to get the engine temp up. > The oil temp also does not go up over 170 deg. Does this sound like > symptoms of a stuck thermostat? If so, how hard is it to replace and > what would cause the excessive oil smoke? > > Thanks, > Chuck Harrison > Akron, Ohio > 90 WL SP36 > |
11-18-2005, 07:15
The engine runs very smooth and noticeably stronger since the new
turbo was installed. The Cat mechanic suggested that the turbo had not been working for a long time therefore excessive carbon buildup could have "gummed up" the rings. The engine has 88000 miles on it. could have--- In WanderlodgeForum@yahoogroups.com, "pattypape" > > First, I would change the thermostat. > I think you have the Cat 3208TA, 300 HP. > My 300 HP had only one thermostat some older 3208's have two. > Stop at the Cat parts dept and they can print out a picture > of this area. It is not too difficult to change. If you decide to do > the repair yourself, I or this forum can give further details. > Could be injectors or more, you need to give more symptoms. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > Just recently my bird began to blow blue oil smoke when it was > cold. > > This symptom has gradually gotten worse over the last 3 months. > > After warmup the smoke disappeared (after 10 min or so). I took it > > to the local Cat dealer who discovered that the turbo was shot. > > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > > before, what's more, the engine will not heat to above 160 deg. > > whereas before it ran at 190 deg. The dealer says I have to run > it > > hard to clean the engine out but I have to get the engine temp up. > > The oil temp also does not go up over 170 deg. Does this sound > like > > symptoms of a stuck thermostat? If so, how hard is it to replace > and > > what would cause the excessive oil smoke? > > > > Thanks, > > Chuck Harrison > > Akron, Ohio > > 90 WL SP36 > > > |
11-18-2005, 12:27
The transmission retarder on our 88FC stopped working. Everything mechanical
outside the transmission housing checks out ok and fluid level is dead on book @180 degrees. Previous owner said the only time it quit for him was when a breather tube that supposedly hangs down in front of Left steer tire got plugged. Can anyone tell me exactly where that rubber tube might be and where it might originate on the transmission and if I'm looking in the right place because I sure don't see it. ? John 88FC ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 18, 2005 11:01 AM Subject: [WanderlodgeForum] Re: 90WLSP36 Smoke and heat First, I would change the thermostat. I think you have the Cat 3208TA, 300 HP. My 300 HP had only one thermostat some older 3208's have two. Stop at the Cat parts dept and they can print out a picture of this area. It is not too difficult to change. If you decide to do the repair yourself, I or this forum can give further details. Could be injectors or more, you need to give more symptoms. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Just recently my bird began to blow blue oil smoke when it was cold. > This symptom has gradually gotten worse over the last 3 months. > After warmup the smoke disappeared (after 10 min or so). I took it > to the local Cat dealer who discovered that the turbo was shot. > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > before, what's more, the engine will not heat to above 160 deg. > whereas before it ran at 190 deg. The dealer says I have to run it > hard to clean the engine out but I have to get the engine temp up. > The oil temp also does not go up over 170 deg. Does this sound like > symptoms of a stuck thermostat? If so, how hard is it to replace and > what would cause the excessive oil smoke? > > Thanks, > Chuck Harrison > Akron, Ohio > 90 WL SP36 > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.362 / Virus Database: 267.13.4/175 - Release Date: 11/18/2005 [Non-text portions of this message have been removed] |
11-18-2005, 13:14
Considering that a remaned cat turbo is less then $700 does that mean
that there was over $3300 in labor to remove and replace it? tom warner 1982 FC35 Vernon Center,NY At 11:39 AM 11/18/2005, you wrote: >Just recently my bird began to blow blue oil smoke when it was cold. >This symptom has gradually gotten worse over the last 3 months. >After warmup the smoke disappeared (after 10 min or so). I took it >to the local Cat dealer who discovered that the turbo was shot. >He replaced the turbo ($4000.00 +) and the oil smoke is worse than >before, what's more, the engine will not heat to above 160 deg. >whereas before it ran at 190 deg. The dealer says I have to run it >hard to clean the engine out but I have to get the engine temp up. >The oil temp also does not go up over 170 deg. Does this sound like >symptoms of a stuck thermostat? If so, how hard is it to replace and >what would cause the excessive oil smoke? > >Thanks, >Chuck Harrison >Akron, Ohio >90 WL SP36 > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
11-18-2005, 23:54
Chuck,
Although the smoke is getting worse, the weather is also getting colder. It may just be cold weather that's causing the smoke. Last winter, mine smoked so bad when started on a very cold day that it appeared someone should call the Fire Dept. ;o) I found my engine heater had quit working. I went to NAPA and bought a 2,000 watt engine heater. If I pre-heat the engine, it barely smokes at all, but if the engine is bone-cold when I start it, it can produce significant smoke. The 3208 has no glow plugs, so it's extremely inefficient on a cold start and that's where the smoke comes from. Pre-heat your engine before starting and if that reduces the smoke significantly, it may not even be broken, just a 3208. Regarding the engine temp, you need to go to a Cat dealer and get the "thermostat kit" so you have good quality thermostats (it uses 2). Running the engine below operating temp isn't good for the engine. If fact, I believe in changing thermostats about every 3 years as a maintenance item. A bad thermostat can have a significant impact on an engine and I don't like risk. Better safe than sorry. George Witt 81 FC 35 Lincoln, Nebraska --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Just recently my bird began to blow blue oil smoke when it was cold. > This symptom has gradually gotten worse over the last 3 months. > After warmup the smoke disappeared (after 10 min or so). I took it > to the local Cat dealer who discovered that the turbo was shot. > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > before, what's more, the engine will not heat to above 160 deg. > whereas before it ran at 190 deg. The dealer says I have to run it > hard to clean the engine out but I have to get the engine temp up. > The oil temp also does not go up over 170 deg. Does this sound like > symptoms of a stuck thermostat? If so, how hard is it to replace and > what would cause the excessive oil smoke? > > Thanks, > Chuck Harrison > Akron, Ohio > 90 WL SP36 > |
11-21-2005, 03:09
Chuck,
We paid $1,696 for a new turbo (cartridge) from a CAT dealer 2 1/2 years ago. Bill & Rita in Roanoke, VA (46 & rain) 1987 FC-35 3208/300hp [Non-text portions of this message have been removed] |
11-21-2005, 06:33
The Cat dealer charged $2075.00 (supposedly for a new turbo).
--- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Considering that a remaned cat turbo is less then $700 does that mean > that there was over $3300 in labor to remove and replace it? > > tom warner > 1982 FC35 > Vernon Center,NY > > At 11:39 AM 11/18/2005, you wrote: > >Just recently my bird began to blow blue oil smoke when it was cold. > >This symptom has gradually gotten worse over the last 3 months. > >After warmup the smoke disappeared (after 10 min or so). I took it > >to the local Cat dealer who discovered that the turbo was shot. > >He replaced the turbo ($4000.00 +) and the oil smoke is worse than > >before, what's more, the engine will not heat to above 160 deg. > >whereas before it ran at 190 deg. The dealer says I have to run it > >hard to clean the engine out but I have to get the engine temp up. > >The oil temp also does not go up over 170 deg. Does this sound like > >symptoms of a stuck thermostat? If so, how hard is it to replace and > >what would cause the excessive oil smoke? > > > >Thanks, > >Chuck Harrison > >Akron, Ohio > >90 WL SP36 > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
11-21-2005, 06:37
Thanks George,
I tried an experiment, I kept the bird in our heated warehouse over the weekend and when I started it this morning there was little or no oil smoke. By the way, how do you turn on the engine preheat? --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > > > > Chuck, > Although the smoke is getting worse, the weather is also getting > colder. It may just be cold weather that's causing the smoke. > Last winter, mine smoked so bad when started on a very cold day > that it appeared someone should call the Fire Dept. ;o) > I found my engine heater had quit working. I went to NAPA and > bought a 2,000 watt engine heater. > If I pre-heat the engine, it barely smokes at all, but if the > engine is bone-cold when I start it, it can produce significant smoke. > The 3208 has no glow plugs, so it's extremely inefficient on a > cold start and that's where the smoke comes from. > Pre-heat your engine before starting and if that reduces the > smoke significantly, it may not even be broken, just a 3208. > Regarding the engine temp, you need to go to a Cat dealer and get > the "thermostat kit" so you have good quality thermostats (it uses 2). > Running the engine below operating temp isn't good for the engine. > If fact, I believe in changing thermostats about every 3 years as a > maintenance item. A bad thermostat can have a significant impact on > an engine and I don't like risk. Better safe than sorry. > > George Witt > 81 FC 35 > Lincoln, Nebraska > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > Just recently my bird began to blow blue oil smoke when it was cold. > > This symptom has gradually gotten worse over the last 3 months. > > After warmup the smoke disappeared (after 10 min or so). I took it > > to the local Cat dealer who discovered that the turbo was shot. > > He replaced the turbo ($4000.00 +) and the oil smoke is worse than > > before, what's more, the engine will not heat to above 160 deg. > > whereas before it ran at 190 deg. The dealer says I have to run it > > hard to clean the engine out but I have to get the engine temp up. > > The oil temp also does not go up over 170 deg. Does this sound like > > symptoms of a stuck thermostat? If so, how hard is it to replace and > > what would cause the excessive oil smoke? > > > > Thanks, > > Chuck Harrison > > Akron, Ohio > > 90 WL SP36 > > > |
