Technical Question??
11-24-2005, 04:50
HELP:::
We are in the process of cooking Mr. Turkey.. How can I use my RayTec infrared thermometer to check the Bird, tempurature? What temp should the breast be?? (Cookbooks say the interior should be around 170. Jack Smith At Home in SoCal |
11-24-2005, 04:57
It all depends opn what type of stuffing you are using and the type of
gravy would also have a bearing on the exterior temp have a GREAT DAY Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" > > HELP::: > We are in the process of cooking Mr. Turkey.. > How can I use my RayTec infrared thermometer to check the Bird, > tempurature? What temp should the breast be?? (Cookbooks say the > interior should be around 170. > Jack Smith > At Home in SoCal > |
11-24-2005, 06:00
Jack its the temperature deep inside the breast or at a leg joint
that you need to monitor and I dont believe taking the temperature on the surface of the bird will help you at all. You use a simple thermometer with a stem that is inserted in the breast. Tom Warner 1982 Bluebird vernon center,NY At 11:50 AM 11/24/2005, you wrote: >HELP::: > We are in the process of cooking Mr. Turkey.. >How can I use my RayTec infrared thermometer to check the Bird, >tempurature? What temp should the breast be?? (Cookbooks say the >interior should be around 170. >Jack Smith >At Home in SoCal > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
