LED Taillights
12-02-2005, 14:27
LED Taillights
I am new here and am the proud owner of an 82 FCRB35. I am interested
in info on installing LED taillights, specifically where I can purchase the equipment and what modifications are required. Thanks |
12-03-2005, 03:24
LED Taillights
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...>
wrote: > > I am new here and am the proud owner of an 82 FCRB35. I am interested > in info on installing LED taillights, specifically where I can purchase > the equipment and what modifications are required. > > Thanks > scott info: on LED taillight can be found at DORAN LED BUS LIGHTS. tim detour mi 83 35 fc. |
12-03-2005, 04:04
LED Taillights
for LED replacement of standard bulbs >>> you might want to check
http://www.superbrightleds.com R. Webb 91 WL Cedar Rapids, IA |
12-03-2005, 12:52
LED Taillights
--- In WanderlodgeForum@yahoogroups.com, "rvvi"
> > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> > wrote: > > > > I am new here and am the proud owner of an 82 FCRB35. I am > interested > > in info on installing LED taillights, specifically where I can > purchase > > the equipment and what modifications are required. > > > > Thanks > > > scott > info: on LED taillight can be found at DORAN LED BUS LIGHTS. > > tim detour mi > 83 35 fc. Thanks, Tim...which lights fit the FC? > |
12-03-2005, 12:59
LED Taillights
I used standard round bus LED lights, several MFGRs make them, bought
mine at Holland Bus Company but likely any truck supplier or school-bus dealer will have them for around $35/each. The stripes are put on after the taillamps so the slight amount of newly-exposed body on the upper two will not be striped. You'll probably want to either touch-up or install a round trim-piece to cover the footprint from the original lights. When you do the install, run a tail-lamp wire up from the lower one so that you get four tail-lamps instead of two. The upper light originally is only brake-turn, no tail. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > I am new here and am the proud owner of an 82 FCRB35. I am interested > in info on installing LED taillights, specifically where I can purchase > the equipment and what modifications are required. > > Thanks > |
12-03-2005, 15:04
LED Taillights
Central States Bus Sales has Doran 7 in led in Red and Amber for
$34.81 each. They also have the marker lights for $8.10 each. http://www.centralstatesbus.com/fliers.html The usual I'm nots. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > I used standard round bus LED lights, several MFGRs make them, bought > mine at Holland Bus Company but likely any truck supplier or school- bus > dealer will have them for around $35/each. > > The stripes are put on after the taillamps so the slight amount of > newly-exposed body on the upper two will not be striped. You'll > probably want to either touch-up or install a round trim-piece to cover > the footprint from the original lights. > > When you do the install, run a tail-lamp wire up from the lower one so > that you get four tail-lamps instead of two. The upper light originally > is only brake-turn, no tail. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> > wrote: > > > > I am new here and am the proud owner of an 82 FCRB35. I am > interested > > in info on installing LED taillights, specifically where I can > purchase > > the equipment and what modifications are required. > > > > Thanks > > > |
12-03-2005, 16:49
LED Taillights
Can they just be wired straight in with no modifications? Do the
mounting holes in the body line up? --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > I used standard round bus LED lights, several MFGRs make them, bought > mine at Holland Bus Company but likely any truck supplier or school- bus > dealer will have them for around $35/each. > > The stripes are put on after the taillamps so the slight amount of > newly-exposed body on the upper two will not be striped. You'll > probably want to either touch-up or install a round trim-piece to cover > the footprint from the original lights. > > When you do the install, run a tail-lamp wire up from the lower one so > that you get four tail-lamps instead of two. The upper light originally > is only brake-turn, no tail. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> > wrote: > > > > I am new here and am the proud owner of an 82 FCRB35. I am > interested > > in info on installing LED taillights, specifically where I can > purchase > > the equipment and what modifications are required. > > > > Thanks > > > |
12-04-2005, 03:43
LED Taillights
Mounting holes I'm not remembering, but I don't think so as the
original Cat-Eye lights have the screws out on the corners and the new ones are round, ... thus the witness lines where the stripe doesn't cover the cream paint on the upper light. I think that the gasket for the new light just barely covers the old screw-holes. As far as wiring: I believe that the tail-lamps can be changed with no wiring modifications (although I suggest wiring the upper one to the tail- lamp with the lower one). If you change the side-repeaters and the front turn-signals also (all turn signals would then be LED) then the flasher will not blink, I install a dummy load in the overhead at the large relays, 10ohm-20watt is what I remember using, from Radio Shack, the big ceramic-style resistors. Maxxima makes a nice LED clearance light that is as close as I've found to a direct replacement: It is the same screw-holes and a 1- wire unit like original, but it is smaller overall so again the light doesn't cover the old footprint in the stripe (stripes added after lights, although your '82 has the tape-stripes (through mid-'83)). Also the Maxxima lights will require that you caulk or silicone-seal the wire hole when installing so that water doesn't creep in through the bracket. Good luck, - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > Can they just be wired straight in with no modifications? Do the > mounting holes in the body line up? |
03-19-2009, 15:50
LED Taillights
Oops, I forgot to tell you all where to find the LED taillight pictures. They
are in the photo section under Jerry'd 85 PT40. Sorry! Jerry 85 PT40 |
User(s) browsing this thread: 7 Guest(s)
