How Thick Is The Roof
12-17-2005, 04:28
No rails or decking plate
Joe Blankenship
Phoenix,Az
90WB40
--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
> Do you have the rails on the roof?
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
> > I am trying to mount solar panels on the roof of my 1990 WB. My roof
> > does not have the deck plate. I drilled a whole in the medal roof and
> > only found foam insulation under it. How do you get anything to hold
> > on just thin medal.
> > Thanks for any help
> > Joe Blankenship
> > Phoenix,Az
> > 90WB40
12-17-2005, 05:52
Hi Joe
Stephen Birtles has excellent advice.
The idea of keeping air flow from getting under is important of course.
The weight of the panels will assist greatly.
Good Luck
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge PT41
12-17-2005, 08:52
There are on most panels only a limited number of mounting points
either 4 or 6 with a 1 inch zed you can fasten the pnaels to the roof
an other alternative is to make a frame and bolt to the roof ribs and
inlay the panel into the frame Bear in mind if locating the roof ribs
they also hold up interior ceiling so there is not much room for error
when drilling too deep and bingo screw in living room
The blusbird goat rail is held on by sheet metal screws as is the
armour secondary or walking roof.
If I was installing on unarmored roof
1 inch zed clamps ond mount the panels into the center of the roof to
account for deflection or curvature in the roof the frame of the panel
will provide strength, the weight of the panel stability and the zeds
stop the panel from moving, You also need sufficient room on the back
of the panel to make the electrical connections.
The goat rail and secondary roof are held on by gravity the screws
just hold in place likewise the roof airs are held on by 4 screws that
sandwich the 20-22 gauge together along with some urethane sealer to
stop leaks.
Solar panels are mostly made to withstand wind broadside with the
panels laid down you present very little surface area simple clamps
will suffice
If you looking for specialty frames and mounts probably the best there
are
unirac dot com
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Hi Joe
> Good Luck
> Fred & Jeanne Hulse
> Morristown Arizona
12-17-2005, 11:52
To bad..met another birder who bolted his solar panels with cross
braces to the rails. Ran the braces across the bird then bolted the
solars to them. This is what we will do on ours.
Bob Lawrence
84 PT36
Tacoma, Wa.
> Joe Blankenship
> Phoenix,Az
> 90WB40
