injector pump
01-03-2006, 01:45
injector pump
ebay 8027104749
12-19-2006, 07:48
injector pump
In a message dated 12/19/2006 5:29:21 P.M. Mountain Standard Time,
kerry.edwards@... writes: _http://boatdiesel.http://boathttp://boah...rum_Forum_ (http://boatdiesel.com/Forums/index.cfm?c...orum_ID=66) Kerry-- that site is another pay for play site. Thanks, but I don't pay to get info. Any other options? Ernie Ekberg 83PT40 Weatherford, tx Wanderlodgeforum- freely given info, freely taken [Non-text portions of this message have been removed] |
12-19-2006, 07:49
injector pump
Thanks, Curt, i'll look into some companies in Ft Worth, that can do that.
Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
12-19-2006, 10:00
injector pump
My injector pump is leaking on my genset from a fitting on the top .
Ralphs is too- no we are not twins. Anyone done a removal ? I read in the manual for perkins that says you have to time that thing when you put her back. that leaves me out of that picture, for sure. Ernie- 83PT40 in Texas |
12-19-2006, 11:16
injector pump
Ernie if it is a rack return, can you just route it to the tank?????? I
dont know about it but CurtS is expert on spending money on a perkins GregoryO'Connor 94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > My injector pump is leaking on my genset from a fitting on the top . > Ralphs is too- no we are not twins. Anyone done a removal ? I read in > the manual for perkins that says you have to time that thing when you > put her back. that leaves me out of that picture, for sure. Ernie- > 83PT40 in Texas > |
12-19-2006, 11:31
injector pump
Ernie,
Call a diesel specialty shop, one that rebuilds diesel fuel pumps/injectors. Ask them if they will remove, service, reinstall/time the pump. Might be a good time to tune up the injectors too. That's what I did. The guy had me park the bus behind his shop. He removed the pump and injectors. I drove the bus home. A few days later he called and I took the bus back. He rebuilt the pump and the injectors, and reinstalled/timed the unit. Part of the timing is getting the RPMs set, and that is done by watching the gen-set AC voltage gauge until the set is putting out 120V. If you do this be sure the fuel lines get sealed up or diesel fuel will get all over. I paid $800.00, which included servicing the Racor, new spin on fuel filter, injector seals/o-rings, etc. Not cheap, but was less than taking the bus to a shop that would keep the bus while working on the Yanmar. Good luck. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Ernest Ekberg wrote: >My injector pump is leaking on my genset from a fitting on the top . >Ralphs is too- no we are not twins. Anyone done a removal ? I read in >the manual for perkins that says you have to time that thing when you >put her back. that leaves me out of that picture, for sure. Ernie- >83PT40 in Texas > > > > >Yahoo! Groups Links > > > > > > |
12-19-2006, 11:33
injector pump
Greg,
YANMAR, YANMAR...Not Perkins. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Gregory OConnor wrote: >Ernie if it is a rack return, can you just route it to the tank?????? I >dont know about it but CurtS is expert on spending money on a perkins >GregoryO'Connor >94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > >>My injector pump is leaking on my genset from a fitting on the top . >>Ralphs is too- no we are not twins. Anyone done a removal ? I read in >>the manual for perkins that says you have to time that thing when you >>put her back. that leaves me out of that picture, for sure. Ernie- >>83PT40 in Texas >> >> >> > > > > > >Yahoo! Groups Links > > > > > > |
12-19-2006, 12:20
injector pump
Here's a Perkins 108 forum. While it's devoted to boats, the engine's the same
so you may find an answer to your question there. http://boatdiesel.com/Forums/index.cfm?c...orum_ID=66 Kerry 82 FC 35 Denver |
