Battery Filler; from Trojan Batteries And Chargers
02-05-2006, 00:53
Nice find Fred....I am going to check on one of these; ideally, for
the back row of fill points, I'll try to figure out a way to fit a small hose to the removed "push to fill spout" Frank 85FC33 --- In WanderlodgeForum@yahoogroups.com, "fred89sp" wrote: > > You press this battery filler into the fill hole and it shuts off when > the cell gets to proper level. It is quick and easy. > > http://buy1.snapon.com/catalog/item.asp?...up_ID=1498 |
02-05-2006, 06:36
Hi Frank,
I have one of the automatic shuttoff Battery fillers from NAPA, but I can't get it to fit into the area above my house batteries, and adding a hose to the NAPA model will not work that way either, it uses a check ball inside of the filler neck to shut the water off when the cell is full, so the water would have to fill up the hose before it shut off and thus would overflow the cell. Try this one that I made up myself, it works great and I believe that it is cheaper too. http://www.pbase.com/iamflagman/image/53793639 It doesn't have an automatic shutoff feature, but I have found that I can tell by the sound of the water going into the battery, when each cell is getting full and then I just check it with a mirror. I have eight house batteries in my side compartment on a rear bath model and a lerge semi truck battery in the front compartment for the main engine. Check out this on my web site; http://www.pbase.com/iamflagman/image/28954670 "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 ALSO VISIT THE: Wanderlodge Owners Group Forum http://autos.groups.yahoo.com/group/wanderlodge/ '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA //////////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "fwernlein" wrote: > > Nice find Fred....I am going to check on one of these; ideally, for > the back row of fill points, I'll try to figure out a way to fit a > small hose to the removed "push to fill spout" > > Frank > 85FC33 > > > > --- In WanderlodgeForum@yahoogroups.com, "fred89sp" > wrote: > > > > You press this battery filler into the fill hole and it shuts off > when > > the cell gets to proper level. It is quick and easy. > > > > http://buy1.snapon.com/catalog/item.asp? item_ID=63055&group_ID=1498 > |
