Rear Axle Lubrication
02-27-2006, 02:47
(1) What kind of lubrication should I place into the rear axle of my
1979 FC? (2) Should I drain the old lube before adding the new lube, because I have no idea what kind of lube is in there now. (3) How do I drain the old lube if I must? I figure that I'll need a pump to suck the old lube out. Thanks. Henry@... 1979 FC35, McAllen, Tx. |
02-27-2006, 03:13
You should find a 3/4 npt plug with a 1/2" square female lug on the bottom of
the pumpkin. Remove with 1/2" breaker bar. I refilled with 80-140 petro oil. I'm too cheap to pop for syn oils. Generally fill line is just below the pinion gear centerline. Pinion gear is on center with drive shaft. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 27, 2006 8:47 AM Subject: [WanderlodgeForum] Rear Axle Lubrication (1) What kind of lubrication should I place into the rear axle of my 1979 FC? (2) Should I drain the old lube before adding the new lube, because I have no idea what kind of lube is in there now. (3) How do I drain the old lube if I must? I figure that I'll need a pump to suck the old lube out. Thanks. Henry@... 1979 FC35, McAllen, Tx. SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
