Jacobs engine brake/ high idle
03-06-2006, 22:40
David- thanks for thee hint. Will be researching the wiring in the next few
hours. Ernie-83pt40 in louisiana
03-07-2006, 00:02
Thanks, George. I have the old 6v92 in my coach and will try and get a
manual to read up on this. Ernie-83pt40 in louisiana
03-07-2006, 01:23
I have an inoperative engine brake and high idle. Steve Gureasko and I
took the push rod assembly apart and removed the 2 o-rings and
reassembled it and put it back on the coach. No high idle.Has anyone
troubleshot this system? Before I head back to Montana, the Jake brake
is a must have. Thanks, Ernie Ekberg, 83pt40 in louisiana
03-07-2006, 03:07
Earnie, this is just a stab in the dark, but on my
coach the high idle only works when the emergency
brake is engaged. Could there be a fault in the
signal that the emergency brake sends to the
high idle?
David Brady
'02 LXi, Smokey, Va
>Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.375 / Virus Database: 268.1.2/274 - Release Date: 3/3/2006
03-07-2006, 04:01
HI Ernie,
Not sure which engine you have. If it is the Cat, I don't know
diddley, but if it is a Detroit.... IF they used the standard Jacobs
unit, it does three functions. The primary function is as a buffer
screw which is designed to take the loping out of the engine at idle.
Adjustment is critical. Book says to turn it in until there is an
increase in rpm not to exceed 15 rpm. best done with an electronic
digital tach.
Second function is to activate the micro switch that activates the
Jake brake. Purpose of this micro switch is to assure that the engine
is in the idle position before activating the Jake. Again a critical
setting. Last function is the high idle where a pneumatic cylinder
pushes a rod inward to increase the governor setting giving you the
high idle. All three of these functions are performed by the same
push rod and, if not set correctly, one or more will not work. If you
don't have the Jacobs manual for the Jake Brake, best get a copy of
one for the proper method of setting it. I gave mine away with the
coach so can't help other than memory, and you know how b ad that can get.
Another way is to jumper the micro switch which will allow the Jake to
operate without that protection. To be safe, you will have to turn it
on and off manually from the driver's station. Not only an
inconvenience, but it can be forgotten. You could do that as a test to
see if the problem is at the micro switch.
Hope this is of some help.
George Lowry
'06 Alpine Apex - Formerly '95 WBDA 4203
Spearfish, SD traveling to SOCAL.
> Yahoo! Groups Links
03-07-2006, 16:58
Hi Guys:
Before you go to that length, does the gear selector have to be in gear? I think
so. One should look for the obvious first.
Bill
George Lowry wrote: HI Ernie,
digital tach.
George Lowry
> Yahoo! Groups Links
SPONSORED LINKS
Recreational vehicles
Wanderlodge Automotive maintenance
Recreational vehicle dealer Used
recreational vehicles Automotive radiators
YAHOO! GROUPS LINKS
Visit your group "WanderlodgeForum" on the web.
To unsubscribe from this group, send an email to:
Have a question? Yahoo! Canada Answers. Go to Yahoo! Canada Answers
