Exploded Batteries, please help and explain.
03-21-2006, 07:28
Guys,
(might wanna grab a coke. I tend to type alot.) I lurk here alot but almost never post. I've owned my 1980 35FC BB for almost 2 years now and am still learning about the ole girl. I have a problem that I'm hoping you guys can help me with. When I got her, the batteries that were in it wouldn't hold a charge for too long since it had been stored for a couple years with the fridge set to electric and killed them. I dealt with it for a while, but decided that I needed to just get new ones. I went to the Sam's club and talked to the battery guy about what I needed and he sold me on getting (4) of the Exide "golf cart" batteries. They worked great last summer. About a month after our vacation when I went to go start her up, it was dead and I found that "somebody" had left ONE little light on. I decided then that I'd just leave it plugged into shore power through the winter and leave the battery switch by the shifter set to OFF. I went out about 5-6 weeks ago, flicked on the battery switch, and she fired right up. I let her tun for about 30 minutes and all was well. I went out Saturday to do the same, only when I hit the key, the volts dropped to zero and it would barely even engage the starter selenoid. I checked the (4) NEW batteries for water and soon discovered (while adding water) that all four batteries had split along the same vertical seam. I spoke to a different guy at the Sam's club about it yesterday and he was a turd. He started telling me that you can't let 6V batteries get that cold (we live in Flint, MI), that I should know not to use a battery that says "golf cart" in a bus, and that I needed to convert it over to run 2 deep cycle 12 volt batteries and blah blah blah. He pretty much was in "cover our butt" mode and I pretty much was having none of it - since I bought them on THEIR recomendation. Needless to say, I forsee myself dealing with somebody at the management level when I return these babies very soon. I didn't think there would be any problem with leaving it plugged in since it was made for full timers who would do the same darn thing. Has anybody else ever experienced this? Can you explain what happened so that I can try not to repeat this little stunt with GOOD batteries? Got any other suggestions? Thanks in advance. John |
03-21-2006, 08:02
Sounds like they were over charged to the point of no return!! I
suspect that you do not have a battery problem but a charging problem instead. This is common for your model 'Bird. Do you still have the original battery boilers, I mean chargers that came from Blue Bird? If so than replace them with Iota smart chargers and you will solve the problem. There has been much written here about this subject ...good luck. -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@...> wrote: > > Guys, > > (might wanna grab a coke. I tend to type alot.) > > I lurk here alot but almost never post. I've owned my 1980 35FC BB > for almost 2 years now and am still learning about the ole girl. I > have a problem that I'm hoping you guys can help me with. > > When I got her, the batteries that were in it wouldn't hold a charge > for too long since it had been stored for a couple years with the > fridge set to electric and killed them. I dealt with it for a > while, but decided that I needed to just get new ones. > > I went to the Sam's club and talked to the battery guy about what I > needed and he sold me on getting (4) of the Exide "golf cart" > batteries. They worked great last summer. About a month after our > vacation when I went to go start her up, it was dead and I found > that "somebody" had left ONE little light on. I decided then that > I'd just leave it plugged into shore power through the winter and > leave the battery switch by the shifter set to OFF. > > I went out about 5-6 weeks ago, flicked on the battery switch, and > she fired right up. I let her tun for about 30 minutes and all was > well. I went out Saturday to do the same, only when I hit the key, > the volts dropped to zero and it would barely even engage the > starter selenoid. > > I checked the (4) NEW batteries for water and soon discovered (while > adding water) that all four batteries had split along the same > vertical seam. > > I spoke to a different guy at the Sam's club about it yesterday and > he was a turd. He started telling me that you can't let 6V > batteries get that cold (we live in Flint, MI), that I should know > not to use a battery that says "golf cart" in a bus, and that I > needed to convert it over to run 2 deep cycle 12 volt batteries and > blah blah blah. He pretty much was in "cover our butt" mode and I > pretty much was having none of it - since I bought them on THEIR > recomendation. Needless to say, I forsee myself dealing with > somebody at the management level when I return these babies very > soon. > > I didn't think there would be any problem with leaving it plugged in > since it was made for full timers who would do the same darn thing. > > Has anybody else ever experienced this? > > Can you explain what happened so that I can try not to repeat this > little stunt with GOOD batteries? > > Got any other suggestions? > > Thanks in advance. > John > |
03-21-2006, 08:13
As far as I know, the inverter/charger/boiler is the original.
Shouldn't there be something that stops the system from charging up batteries that don't need charging? Aside from buying a new charger (how much are they?) should I just unhook the battery cables when I'm not using the bus? --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Sounds like they were over charged to the point of no return!! I > suspect that you do not have a battery problem but a charging > problem instead. > > This is common for your model 'Bird. > > > Do you still have the original battery boilers, I mean chargers that > came from Blue Bird? If so than replace them with Iota smart > chargers and you will solve the problem. > > There has been much written here about this subject ...good luck. > > > -James > 78FC33SB > LasVegas NV > > > --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" > <mrbeebody@> wrote: > > > > Guys, > > > > (might wanna grab a coke. I tend to type alot.) > > > > I lurk here alot but almost never post. I've owned my 1980 35FC > BB > > for almost 2 years now and am still learning about the ole girl. I > > have a problem that I'm hoping you guys can help me with. > > > > When I got her, the batteries that were in it wouldn't hold a > charge > > for too long since it had been stored for a couple years with the > > fridge set to electric and killed them. I dealt with it for a > > while, but decided that I needed to just get new ones. > > > > I went to the Sam's club and talked to the battery guy about what > I > > needed and he sold me on getting (4) of the Exide "golf cart" > > batteries. They worked great last summer. About a month after > our > > vacation when I went to go start her up, it was dead and I found > > that "somebody" had left ONE little light on. I decided then that > > I'd just leave it plugged into shore power through the winter and > > leave the battery switch by the shifter set to OFF. > > > > I went out about 5-6 weeks ago, flicked on the battery switch, and > > she fired right up. I let her tun for about 30 minutes and all > was > > well. I went out Saturday to do the same, only when I hit the > key, > > the volts dropped to zero and it would barely even engage the > > starter selenoid. > > > > I checked the (4) NEW batteries for water and soon discovered > (while > > adding water) that all four batteries had split along the same > > vertical seam. > > > > I spoke to a different guy at the Sam's club about it yesterday > and > > he was a turd. He started telling me that you can't let 6V > > batteries get that cold (we live in Flint, MI), that I should know > > not to use a battery that says "golf cart" in a bus, and that I > > needed to convert it over to run 2 deep cycle 12 volt batteries > and > > blah blah blah. He pretty much was in "cover our butt" mode and I > > pretty much was having none of it - since I bought them on THEIR > > recomendation. Needless to say, I forsee myself dealing with > > somebody at the management level when I return these babies very > > soon. > > > > I didn't think there would be any problem with leaving it plugged > in > > since it was made for full timers who would do the same darn thing. > > > > Has anybody else ever experienced this? > > > > Can you explain what happened so that I can try not to repeat this > > little stunt with GOOD batteries? > > > > Got any other suggestions? > > > > Thanks in advance. > > John > > > |
03-21-2006, 08:24
Hi John,
Try putting some 6V batteries in series. I have six (three pairs, each in series) from Sam's. They work great. When in dry storage however, you must leave them either disconnected or on a timer so that they do not overcharge and only get charged 2 hours a day. I have the original chargers too and they work fine as long as you do not let them on continuously. Once the batteries are fully charged, disconnect them at the battery tray (install a switch). The switch under the dash does not disconnect the batteries. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@...> wrote: > > As far as I know, the inverter/charger/boiler is the original. > > Shouldn't there be something that stops the system from charging up > batteries that don't need charging? > > Aside from buying a new charger (how much are they?) should I just > unhook the battery cables when I'm not using the bus? > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > Sounds like they were over charged to the point of no return!! I > > suspect that you do not have a battery problem but a charging > > problem instead. > > > > This is common for your model 'Bird. > > > > > > Do you still have the original battery boilers, I mean chargers > that > > came from Blue Bird? If so than replace them with Iota smart > > chargers and you will solve the problem. > > > > There has been much written here about this subject ...good luck. > > > > > > -James > > 78FC33SB > > LasVegas NV > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" > > <mrbeebody@> wrote: > > > > > > Guys, > > > > > > (might wanna grab a coke. I tend to type alot.) > > > > > > I lurk here alot but almost never post. I've owned my 1980 35FC > > BB > > > for almost 2 years now and am still learning about the ole girl. > I > > > have a problem that I'm hoping you guys can help me with. > > > > > > When I got her, the batteries that were in it wouldn't hold a > > charge > > > for too long since it had been stored for a couple years with > the > > > fridge set to electric and killed them. I dealt with it for a > > > while, but decided that I needed to just get new ones. > > > > > > I went to the Sam's club and talked to the battery guy about > what > > I > > > needed and he sold me on getting (4) of the Exide "golf cart" > > > batteries. They worked great last summer. About a month after > > our > > > vacation when I went to go start her up, it was dead and I found > > > that "somebody" had left ONE little light on. I decided then > that > > > I'd just leave it plugged into shore power through the winter > and > > > leave the battery switch by the shifter set to OFF. > > > > > > I went out about 5-6 weeks ago, flicked on the battery switch, > and > > > she fired right up. I let her tun for about 30 minutes and all > > was > > > well. I went out Saturday to do the same, only when I hit the > > key, > > > the volts dropped to zero and it would barely even engage the > > > starter selenoid. > > > > > > I checked the (4) NEW batteries for water and soon discovered > > (while > > > adding water) that all four batteries had split along the same > > > vertical seam. > > > > > > I spoke to a different guy at the Sam's club about it yesterday > > and > > > he was a turd. He started telling me that you can't let 6V > > > batteries get that cold (we live in Flint, MI), that I should > know > > > not to use a battery that says "golf cart" in a bus, and that I > > > needed to convert it over to run 2 deep cycle 12 volt batteries > > and > > > blah blah blah. He pretty much was in "cover our butt" mode and > I > > > pretty much was having none of it - since I bought them on THEIR > > > recomendation. Needless to say, I forsee myself dealing with > > > somebody at the management level when I return these babies very > > > soon. > > > > > > I didn't think there would be any problem with leaving it > plugged > > in > > > since it was made for full timers who would do the same darn > thing. > > > > > > Has anybody else ever experienced this? > > > > > > Can you explain what happened so that I can try not to repeat > this > > > little stunt with GOOD batteries? > > > > > > Got any other suggestions? > > > > > > Thanks in advance. > > > John > > > > > > |
03-21-2006, 08:35
Adria, you asked, "Shouldn't there be something that stops the
system from charging batteries that don't need charging?" The answer to your question is yes there should be, however there isn't. You do not have to go through the hassel of disconnedcting and reconnecting the cables all the time. If you are going to keep the original chargers, that will charge at only a very high voltage when ever they are on, regardless of the state of charge of your batteries, then just unplug one of them and put a timer in line with the other, only allowing it to charge for 2 to 3 hours a day. Many owners do this. Newer technology allows chargers to sense the charge level of your bank and then charge accordingly with out over charging the bank, they can be left on all the time. These are called smart chargers as they contain a microprocessor that allows them to operate constanlty. I just bought (2) Iota smart chargers from a distributor called Master Techs, you can get their number from the Iota Web Page. They cost a little over $300 for both of them and are state of the art charger/converters. Charging technology has come a long way since the time they built our 'Birds. If you have any more questions please ask. -James 78FC33SB LasVegas NV (cool, breezy, and some strange looking water drops falling from the sky that are very seldom seen in these parts.) --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@...> wrote: > > As far as I know, the inverter/charger/boiler is the original. > > Shouldn't there be something that stops the system from charging up > batteries that don't need charging? > > Aside from buying a new charger (how much are they?) should I just > unhook the battery cables when I'm not using the bus? > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > Sounds like they were over charged to the point of no return!! I > > suspect that you do not have a battery problem but a charging > > problem instead. > > > > This is common for your model 'Bird. > > > > > > Do you still have the original battery boilers, I mean chargers > that > > came from Blue Bird? If so than replace them with Iota smart > > chargers and you will solve the problem. > > > > There has been much written here about this subject ...good luck. > > > > > > -James > > 78FC33SB > > LasVegas NV > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" > > <mrbeebody@> wrote: > > > > > > Guys, > > > > > > (might wanna grab a coke. I tend to type alot.) > > > > > > I lurk here alot but almost never post. I've owned my 1980 35FC > > BB > > > for almost 2 years now and am still learning about the ole girl. > I > > > have a problem that I'm hoping you guys can help me with. > > > > > > When I got her, the batteries that were in it wouldn't hold a > > charge > > > for too long since it had been stored for a couple years with > the > > > fridge set to electric and killed them. I dealt with it for a > > > while, but decided that I needed to just get new ones. > > > > > > I went to the Sam's club and talked to the battery guy about > what > > I > > > needed and he sold me on getting (4) of the Exide "golf cart" > > > batteries. They worked great last summer. About a month after > > our > > > vacation when I went to go start her up, it was dead and I found > > > that "somebody" had left ONE little light on. I decided then > that > > > I'd just leave it plugged into shore power through the winter > and > > > leave the battery switch by the shifter set to OFF. > > > > > > I went out about 5-6 weeks ago, flicked on the battery switch, > and > > > she fired right up. I let her tun for about 30 minutes and all > > was > > > well. I went out Saturday to do the same, only when I hit the > > key, > > > the volts dropped to zero and it would barely even engage the > > > starter selenoid. > > > > > > I checked the (4) NEW batteries for water and soon discovered > > (while > > > adding water) that all four batteries had split along the same > > > vertical seam. > > > > > > I spoke to a different guy at the Sam's club about it yesterday > > and > > > he was a turd. He started telling me that you can't let 6V > > > batteries get that cold (we live in Flint, MI), that I should > know > > > not to use a battery that says "golf cart" in a bus, and that I > > > needed to convert it over to run 2 deep cycle 12 volt batteries > > and > > > blah blah blah. He pretty much was in "cover our butt" mode and > I > > > pretty much was having none of it - since I bought them on THEIR > > > recomendation. Needless to say, I forsee myself dealing with > > > somebody at the management level when I return these babies very > > > soon. > > > > > > I didn't think there would be any problem with leaving it > plugged > > in > > > since it was made for full timers who would do the same darn > thing. > > > > > > Has anybody else ever experienced this? > > > > > > Can you explain what happened so that I can try not to repeat > this > > > little stunt with GOOD batteries? > > > > > > Got any other suggestions? > > > > > > Thanks in advance. > > > John > > > > > > |
03-21-2006, 09:22
Thanks guys for all the immediate and incredible feedback. It
sounds like I'm going to just get new batteries and where the charger plugs into the bus - seperate the two with a timer that only lets them charge for a little bit every day. --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Adria, you asked, "Shouldn't there be something that stops the > system from charging batteries that don't need charging?" The > answer to your question is yes there should be, however there isn't. > > You do not have to go through the hassel of disconnedcting and > reconnecting the cables all the time. > > If you are going to keep the original chargers, that will charge at > only a very high voltage when ever they are on, regardless of the > state of charge of your batteries, then just unplug one of them and > put a timer in line with the other, only allowing it to charge for 2 > to 3 hours a day. Many owners do this. > > Newer technology allows chargers to sense the charge level of your > bank and then charge accordingly with out over charging the bank, > they can be left on all the time. These are called smart chargers > as they contain a microprocessor that allows them to operate > constanlty. > > I just bought (2) Iota smart chargers from a distributor called > Master Techs, you can get their number from the Iota Web Page. They > cost a little over $300 for both of them and are state of the art > charger/converters. > > Charging technology has come a long way since the time they built > our 'Birds. > > If you have any more questions please ask. > > > -James > 78FC33SB > LasVegas NV (cool, breezy, and some strange looking water drops > falling from the sky that are very seldom seen in these parts.) > > > > > --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" > <mrbeebody@> wrote: > > > > As far as I know, the inverter/charger/boiler is the original. > > > > Shouldn't there be something that stops the system from charging > up > > batteries that don't need charging? > > > > Aside from buying a new charger (how much are they?) should I just > > unhook the battery cables when I'm not using the bus? > > > > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > > > > Sounds like they were over charged to the point of no return!! > I > > > suspect that you do not have a battery problem but a charging > > > problem instead. > > > > > > This is common for your model 'Bird. > > > > > > > > > Do you still have the original battery boilers, I mean chargers > > that > > > came from Blue Bird? If so than replace them with Iota smart > > > chargers and you will solve the problem. > > > > > > There has been much written here about this subject ...good luck. > > > > > > > > > -James > > > 78FC33SB > > > LasVegas NV > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" > > > <mrbeebody@> wrote: > > > > > > > > Guys, > > > > > > > > (might wanna grab a coke. I tend to type alot.) > > > > > > > > I lurk here alot but almost never post. I've owned my 1980 > 35FC > > > BB > > > > for almost 2 years now and am still learning about the ole > girl. > > I > > > > have a problem that I'm hoping you guys can help me with. > > > > > > > > When I got her, the batteries that were in it wouldn't hold a > > > charge > > > > for too long since it had been stored for a couple years with > > the > > > > fridge set to electric and killed them. I dealt with it for a > > > > while, but decided that I needed to just get new ones. > > > > > > > > I went to the Sam's club and talked to the battery guy about > > what > > > I > > > > needed and he sold me on getting (4) of the Exide "golf cart" > > > > batteries. They worked great last summer. About a month > after > > > our > > > > vacation when I went to go start her up, it was dead and I > found > > > > that "somebody" had left ONE little light on. I decided then > > that > > > > I'd just leave it plugged into shore power through the winter > > and > > > > leave the battery switch by the shifter set to OFF. > > > > > > > > I went out about 5-6 weeks ago, flicked on the battery switch, > > and > > > > she fired right up. I let her tun for about 30 minutes and > all > > > was > > > > well. I went out Saturday to do the same, only when I hit the > > > key, > > > > the volts dropped to zero and it would barely even engage the > > > > starter selenoid. > > > > > > > > I checked the (4) NEW batteries for water and soon discovered > > > (while > > > > adding water) that all four batteries had split along the same > > > > vertical seam. > > > > > > > > I spoke to a different guy at the Sam's club about it > yesterday > > > and > > > > he was a turd. He started telling me that you can't let 6V > > > > batteries get that cold (we live in Flint, MI), that I should > > know > > > > not to use a battery that says "golf cart" in a bus, and that > I > > > > needed to convert it over to run 2 deep cycle 12 volt > batteries > > > and > > > > blah blah blah. He pretty much was in "cover our butt" mode > and > > I > > > > pretty much was having none of it - since I bought them on > THEIR > > > > recomendation. Needless to say, I forsee myself dealing with > > > > somebody at the management level when I return these babies > very > > > > soon. > > > > > > > > I didn't think there would be any problem with leaving it > > plugged > > > in > > > > since it was made for full timers who would do the same darn > > thing. > > > > > > > > Has anybody else ever experienced this? > > > > > > > > Can you explain what happened so that I can try not to repeat > > this > > > > little stunt with GOOD batteries? > > > > > > > > Got any other suggestions? > > > > > > > > Thanks in advance. > > > > John > > > > > > > > > > |
03-21-2006, 09:42
Hi Adria,
Sorry you are having so much trouble. First, what likely happened. Typically, the lead-acid type batteries you are using for starting and possibly for the coach, will indicate 12.65V when fully charged and at rest. "Fully charged" batteries will contain a maximum amount of sulphuric acid (H2SO4) which has a freezing point well below 32 degrees farenheit. As the batteries discharge (a discharged battery will indicate 12V or less) the electro-chemical reaction tends to change the liquid composition toward H2O (water) which we know has a freezing point close to 32 degrees farenheit. If lead-acid batteries are overcharged (often called boiled) the liquid evaporates, at which time water is added back to a level to cover the lead plates, and the batteries recharged to convert the water back to acid. In either case it would appear the batteries reached a temperature below that required to freeze the remaining liquid to the point of cracking the cases. --- Adria Haynes <mrbeebody@...> wrote: > I > decided then that > I'd just leave it plugged into shore power through > the winter and > leave the battery switch by the shifter set to OFF. Can't say for sure about your model, but typically, the battery charger only charges the coach batteries and not the engine batteries unless the battery switch (boost switch) is set to on, then, if left on for prolonged periods of days/weeks, the engine lead-acid batteries become "boiled." > I went out about 5-6 weeks ago, flicked on the > battery switch, and > she fired right up. When you did that, you electrically "combined" all batteries (coach and engine) and, as the coach batteries had been charging all along, they in effect provided the power to start your coach. Note: in all likelyhood, your engine batteries were already dead/damaged. > I let her tun for about 30 > minutes and all was > well. The engine alternator provided a charge for both the engine and coach batteries, but 30 minutes was probably not sufficient to charge the engine batteries. You did not say whether or not when you shut off the engine, you also disabled the battery switch. If so, the engine batteries returned to their uncharged state. If not, the engine batteries likely were so discharged, or damaged from prolonged discharge, that they "tricked" the charger into providing maximum charge amperage until all remaining batteries became boiled and damaged. This situation/causation is why the recommendation is to replace all batteries at once. An attempt to charge damaged batteries along with good batteries will likely damage them all. > I spoke to a different guy at the Sam's club > and He started telling me that you can't > let 6V > batteries get that cold Unfortunately, he should have suggested that batteries should be fully charged to survive cold weather. > > I didn't think there would be any problem with > leaving it plugged in > since it was made for full timers who would do the > same darn thing. I trust the above explanation will clarify that leaving it "plugged in" still requires that a close eye be kept to prevent overcharging and "boiling" and the acid/water level must be kept above the top of the lead plates at all times. > Has anybody else ever experienced this? Most of us have also learned the hard way, unfortunately. John Suter __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
03-22-2006, 01:03
> Over charge batterys! I have the old battery
> charger on my 78 > Wanderlodge and never have had a problem with it. I > just go out and > check to see if there is enough water in the > batterys. I leave my > coach shore power on all the time and I have never > had a problem with > the batterys. Why don't I have this problem of over > charging? Sorry, I was trying to wind up the long concept and used the term "overcharged" inappropriately. Given the posed scenario, I attempted to explain, when the charger detects the "need" for a considerable amount of electrical charge (a dead battery or cell, for example) the charger applies maximum amperage to the entire bank (or banks, if the "boost" or "battery switch" is "on") and that is akin to a pot of water on the stove with the burner turned up to max heat - i.e. the battery water/acid begins to literally "boil" and the H2O component of the liquid evaporates, the battery becomes hot to the touch, and as the liquid level drops below the top of the closely aligned lead plates, they begin to warp and touch one another, and so on until permanent damage occurs. A vicious cycle! An undamaged battery, properly charged, can withstand ambient temperatures well down to zero Fahrenheit for a considerable period of time. A severely damaged battery (or cell) within a bank can electrically drain the others, and at temps below freezing, can result in multiple cracked cases. John Suter > > Jon > 78 wanderlodge > Bremerton Washington __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
User(s) browsing this thread: 8 Guest(s)
