Electrical gremlin
04-19-2006, 14:29
Electrical gremlin
Folks,
I have a slight problem with my generator auto start feature. The auto start is controlled by a board called the Gencon, built by Westhaver Assoc. The gencon monitors the house batteries and the shore power and starts the generator when the house batteries dip below 11.4V or when the shorepower drops below 104V AC. I have good shore power and my house batteries are charged, the dash "DC Volts Coach" gauge reads 14V and the trace inverters indicate 100% charge, nonetheless the gencon wants to start the generator. Here's the kicker, my dash "DC Volts Engine" gauge reads around 12.5V, if I switch the dash "Aux Battery" switch to "on " (thereby connecting the house and the engine batteries), the gencon no longer wants to start the generator. I would think that the discharged engine batteries would put even more of a load on the house batteries prompting the gencon to start the generator, but the reverse happens, with the "Aux Battery" switch disabled the gencon wants to start the generator while enabling the "Aux Battery" switch prevents the gencon from starting the generator. It's almost as if my gencon is monitoring the engine batteries and not the house batteries... Thanks for your help, David Brady '02 LXi, Smokey Va |
04-20-2006, 00:18
Electrical gremlin
--- In WanderlodgeForum@yahoogroups.com, David Brady
wrote: >find the wire that senses battery voltage,at the board. check the voltage at the board,just to rule out voltage drop in the wires.at least,thats where i would start. randy dupree > Folks, > > I have a slight problem with my generator auto > start feature. The auto start is controlled by a > board called the Gencon, built by Westhaver > Assoc. The gencon monitors the house batteries > and the shore power and starts the generator > when the house batteries dip below 11.4V or > when the shorepower drops below 104V AC. > > I have good shore power and my house batteries > are charged, the dash "DC Volts Coach" gauge > reads 14V and the trace inverters indicate 100% > charge, nonetheless the gencon wants to start the > generator. > > Here's the kicker, my dash "DC Volts Engine" > gauge reads around 12.5V, if I switch the dash > "Aux Battery" switch to "on " (thereby connecting > the house and the engine batteries), the gencon > no longer wants to start the generator. > > I would think that the discharged engine batteries > would put even more of a load on the house batteries > prompting the gencon to start the generator, but the > reverse happens, with the "Aux Battery" switch disabled the > gencon wants to start the generator while enabling > the "Aux Battery" switch prevents the gencon from > starting the generator. It's almost as if my gencon is > monitoring the engine batteries and not the house > batteries... > > Thanks for your help, > David Brady > '02 LXi, Smokey > Va > |
04-20-2006, 01:02
Electrical gremlin
Hi David,
> I have a slight problem with my generator auto > start feature. The auto start is controlled by a > board called the Gencon, built by Westhaver > Assoc. The gencon monitors the house batteries > and the shore power and starts the generator > when the house batteries dip below 11.4V or > when the shore-power drops below 104V AC. Let's start by eliminating: If you have an incorrect AC adapter, the brownout function will have the wrong threshold. Your '02 (actually Gencons made after 98) are typically calibrated for the radio Shack AC adapter catalog number 273-1764 and the Adapt-a-plug (Radio shack # 273-1708 attached so the plug tip is the positive. > I have good shore power and my house batteries > are charged, the dash "DC Volts Coach" gauge > reads 14V and the trace inverters indicate 100% > charge, nonetheless the gencon wants to start the > generator. A reading above 12.65V means the batteries are not "at rest" (one hour or more without charging or discharging) such that what is being "read" is likely the float/maintenance, inverter/charging voltage provided to the coach/house battery bank(sometimes called the surface charge), and not necessarily that of the battery bank itself. > Here's the kicker, my dash "DC Volts Engine" > gauge reads around 12.5V, When the "Aux Battery" switch (sometimes called the boost switch) is "off" and the engine ignition switch also "off," an isolation solenoid separates the engine battery bank from the coach/house battery bank. This 12.5V is the 12.65 or so, referred to previously as the "resting voltage." Your 12.5v tends to indicate a "good" battery bank. 12.0 would indicate discharged. For the record, when the ignition switch is "on" the solenoid is typically energized so the engine alternator will charge all banks (note the green LED at the dash switch). > if I switch the dash > "Aux Battery" switch to "on " (thereby connecting > the house and the engine batteries), the gencon > no longer wants to start the generator. > > I would think that the discharged (Incorrect assumption about discharged) engine batteries > would put even more of a load on the house batteries > prompting the gencon to start the generator, but the > reverse happens, with the "Aux Battery" switch > disabled the > gencon wants to start the generator while enabling > the "Aux Battery" switch prevents the gencon from > starting the generator. It's almost as if my gencon > is > monitoring the engine batteries and not the house > batteries... It is possible an error was made or a change somewhere along the way. How long has this been happening and were there any changes made to the batteries, inverter/charger, switches in the bays, etc.? Have you noticed the switch in the forward-most, driver-side bin, labeled "No 110V A/C and Low 110V A/c" or words to that effect? That switch enables/disables the brown-out "shore power" sensing. In "Low" mode the brown-out feature is enabled. In the other position, nothing will happen with no shore power unless the house bank is also below 11.25V - PROVIDING, the selectable voltages are properly set on the plug-in Radio Shack device which you will find plugged into the 110V duplex outlet high, in the bay. > Thanks for your help, > David Brady > '02 LXi, Smokey > Va Let's start with the above and see where we can go from here to solve the problem. John Suter 2000LXi and prior PT40's __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
04-21-2006, 04:27
Electrical gremlin
David, I received a call this morning from John Suter. He wanted to
get some clarification on the operation of our GenCon generator controller. To make a long story short, he recommended that I visit this form and take a look around. Having done that, I was surprised to see that you are continuing to have trouble with your GenCon. I want to extend an invitation to any GenCon owner to either email, call or post a message in this forum when you have a GenCon problem and we'll do our best to address it. Thanks John, for pointing me to this forum. Wes Westhaver Westhaver Associates, Inc. --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > I have a slight problem with my generator auto > start feature. The auto start is controlled by a > board called the Gencon, built by Westhaver > Assoc. The gencon monitors the house batteries > and the shore power and starts the generator > when the house batteries dip below 11.4V or > when the shorepower drops below 104V AC. > |
04-21-2006, 04:37
Electrical gremlin
Hello Wes and welcome to the Forum.
Would it be possible, since we all need or could need, a little GenCon 101 here, to post the sequence of operation for that circuit? Reason being, if we know the sequence on how it is designed to work properly then it gives us a solid foundation in which to start the trouble shooting procedure. Also we have a files section on this Forum that would gladly accept a schematic of the circuitry to hand in had with the sequence of operation. Having that knowledge on hand will un doubtingly get someone from being stranded on the side of the road somewhere, etal: as an example. Many thanks for any light you can put on this subject. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:27 PM 4/21/2006 +0000, you wrote: >David, I received a call this morning from John Suter. He wanted to >get some clarification on the operation of our GenCon generator >controller. To make a long story short, he recommended that I visit >this form and take a look around. Having done that, I was surprised to >see that you are continuing to have trouble with your GenCon. I want >to extend an invitation to any GenCon owner to either email, call or >post a message in this forum when you have a GenCon problem and we'll >do our best to address it. > >Thanks John, for pointing me to this forum. > >Wes Westhaver >Westhaver Associates, Inc. > |
04-21-2006, 08:58
Electrical gremlin
Thanks Wes, for your offer. I'm in the process of trying to understand
my symptoms a bit which takes time and use. I'm now at a campground with the "gen auto switch" enabled and the brown-out set to ignore the lower 60V ac, with the radioshack ac adapter unplugged, and with shore power connected. What I'm doing is forcing the gencon to only sense the coach dc voltage level. I'll run it like this for a day or so to see if the generator starts; so far so good. Thanks again for the offer to help diagnose my possible issues; first I need to collect some data. One thing that would be very useful from the gencon would be a display of the reason for the last generator start; i.e., AC brown-out or low DC. The display could be a small led readout on the board itself. As it is today, it's sometimes a bit of a mystery understanding the rationale behind a generator start. Best regards, David Brady '02 LXi, Smokey Va lwesthaver1958 wrote: > David, I received a call this morning from John Suter. He wanted to > get some clarification on the operation of our GenCon generator > controller. To make a long story short, he recommended that I visit > this form and take a look around. Having done that, I was surprised to > see that you are continuing to have trouble with your GenCon. I want > to extend an invitation to any GenCon owner to either email, call or > post a message in this forum when you have a GenCon problem and we'll > do our best to address it. > > > > > > > |
04-23-2006, 07:42
Electrical gremlin
Ralph, I think the best way to describe the operation of the Gencon
is to say that it simply sits in a polling loop and watches the three main inputs ie. House battery, Cranking battery and shore power. There are subtle differences in the various firmware versions but typically the Gencon will start your genset if it sees a brown-out condition for at least ten seconds. Or if either battery drops below their respective thresholds. If you have any questions about specific firmware releases, please feel free to ask. As for schematics etc. You may post anything you find on the Westhaver Associates website here for the benefit of the Bluebird forum members. If there is some aspect of the Gencon that you would like to have explained/documented and it isn't already addressed on our website we'll do our best to address it and post the new information. Thank your for your support, Wes Westhaver --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hello Wes and welcome to the Forum. > > Would it be possible, since we all need or could need, a little GenCon 101 > here, to post the sequence of operation for that circuit? > > Reason being, if we know the sequence on how it is designed to work > properly then it gives us a solid foundation in which to start the trouble > shooting procedure. Also we have a files section on this Forum that would > gladly accept a schematic of the circuitry to hand in had with the sequence > of operation. Having that knowledge on hand will un doubtingly get someone > from being stranded on the side of the road somewhere, etal: as an example. > > Many thanks for any light you can put on this subject. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 04:27 PM 4/21/2006 +0000, you wrote: > >David, I received a call this morning from John Suter. He wanted to > >get some clarification on the operation of our GenCon generator > >controller. To make a long story short, he recommended that I visit > >this form and take a look around. Having done that, I was surprised to > >see that you are continuing to have trouble with your GenCon. I want > >to extend an invitation to any GenCon owner to either email, call or > >post a message in this forum when you have a GenCon problem and we'll > >do our best to address it. > > > >Thanks John, for pointing me to this forum. > > > >Wes Westhaver > >Westhaver Associates, Inc. > > > |
04-23-2006, 07:50
Electrical gremlin
David, it sounds like you are going to get to the bottom of your
problem through the process of elimination. John Suter has a good grasp on the inner workings of the Gencon and has given good advice for troubleshooting. If you have any specific questions as you work through the problem, please let me know. Wes Westhaver Westhaver Associates, Inc. --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Thanks Wes, for your offer. I'm in the process of trying to understand > my symptoms a bit which takes time and use. I'm now at a campground > with the "gen auto switch" enabled and the brown-out set to ignore the > lower 60V ac, with the radioshack ac adapter unplugged, and with > shore power connected. > > What I'm doing is forcing the gencon to only sense the coach dc voltage > level. > I'll run it like this for a day or so to see if the generator starts; so > far so good. > Thanks again for the offer to help diagnose my possible issues; first I need > to collect some data. > > One thing that would be very useful from the gencon would be a display > of the reason for the last generator start; i.e., AC brown-out or low DC. > > The display could be a small led readout on the board itself. As it is > today, > it's sometimes a bit of a mystery understanding the rationale behind a > generator start. > > Best regards, > David Brady > '02 LXi, Smokey > Va > > lwesthaver1958 wrote: > > David, I received a call this morning from John Suter. He wanted to > > get some clarification on the operation of our GenCon generator > > controller. To make a long story short, he recommended that I visit > > this form and take a look around. Having done that, I was surprised to > > see that you are continuing to have trouble with your GenCon. I want > > to extend an invitation to any GenCon owner to either email, call or > > post a message in this forum when you have a GenCon problem and we'll > > do our best to address it. > > > > > > > > > > > > > > > |
04-23-2006, 11:59
Electrical gremlin
Hi Wes,
I think one of our problems as owners comes from the description, "brown-out." If brown-out means total loss of shore power, or shore power dropping below 100 volts A/C, then we have a "start generator condition" when our gen start dash switch is on, and the Low A/C - No A/C switch is set to Low A/C, and the house battery bank voltage drops to 11.25 volts D/C. Seminars have instructed that we set the Low A/C - No A/C switch to No A/C when pets are to stay in the coach unattended, with the shore power connected and the Air conditioner(s) running, to permit the generator to start immediately upon shore power failure without also having to meet the criteria of low house battery voltage. Perhaps you can amplify or correct that information, as it appears contradicted by information on the website. Keep in mind, it is difficult to understand why an owner would want to permit any kind of shore power "Brown-out" condition as it would surely play havoc with our electronics. Last, I'm also not at all sure our GenCon setups poll the cranking/engine battery, and although the Westhaver website makes reference to polling the generator battery, I have haven't heard of a Bluebird making use of that feature. Thanks so much for your help. John Suter --- lwesthaver1958 > Ralph, I think the best way to describe the > operation of the Gencon > is to say that it simply sits in a polling loop and > watches the > three main inputs ie. House battery, Cranking > battery and shore > power. > > There are subtle differences in the various firmware > versions but > typically the Gencon will start your genset if it > sees a brown-out > condition for at least ten seconds. Or if either > battery drops below > their respective thresholds. > > If you have any questions about specific firmware > releases, please > feel free to ask. > > As for schematics etc. You may post anything you > find on the > Westhaver Associates website here for the benefit of > the Bluebird > forum members. If there is some aspect of the Gencon > that you would > like to have explained/documented and it isn't > already addressed on > our website we'll do our best to address it and post > the new > information. > > Thank your for your support, > Wes Westhaver > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
04-24-2006, 04:56
Electrical gremlin
--- In WanderlodgeForum@yahoogroups.com, John Suter
wrote: > > Hi Wes, > > I think one of our problems as owners comes from the > description, "brown-out." > If brown-out means total loss of shore power, or > shore power dropping below 100 volts A/C, then we have > a "start generator condition" when our gen start dash > switch is on, and the Low A/C - No A/C switch is set > to Low A/C, and the house battery bank voltage drops > to 11.25 volts D/C. John, Brown-out is defined as shore power voltage of 105 volts down to zero volts as specified by Blue Bird. I am not sure about Blue Birds nomenclature "No A/C or Low A/C". If this switch is the one connected to E25, closing the switch, thus putting +12V on the terminal, will cause the brown-out range to be 105 down to 0 VAC. If the switch is open, which is the position for road travel, the GENCON will not respond to 0 volts on the shore power. Technically, that open position still monitors shore power, but the brown-out range is 105 down to 60 VAC, which isn't going to be possible with the coach disconnected from shore power. Monitoring of batteries and shore power are completely independent i.e. any one of the batteries voltage dropping below its limit, or the shore power dropping below 105 VAC for ten seconds, is a sufficient condition to start the generator. They do not all have to happen at once. > Seminars have instructed that we set the Low A/C - > No A/C switch to No A/C when pets are to stay in the > coach unattended, with the shore power connected and > the Air conditioner(s) running, to permit the > generator to start immediately upon shore power > failure without also having to meet the criteria of > low house battery voltage. > Perhaps you can amplify or correct that information, > as it appears contradicted by information on the > website. > Keep in mind, it is difficult to understand why an > owner would want to permit any kind of shore power > "Brown-out" condition as it would surely play havoc > with our electronics. We agree that a brown-out condition should always be avoided. It is very harmful to any motor, causing excessive heating. > Last, I'm also not at all sure our GenCon setups > poll the cranking/engine battery, and although the > Westhaver website makes reference to polling the > generator battery, I have haven't heard of a Bluebird > making use of that feature. Unfortunately, some manufacturers used only a portion of the GENCON's capabilities. The GENCON was designed to monitor the house and the generator-cranking batteries. It was never intended to monitor the battery used to crank/start the bus engine. We have seen installations where terminals E3 and E4 are connected together, which means the Gencon is monitoring one battery on both of its inputs. This greatly reduces the Gencon's functionality. The Gencon was designed to make certain that: 1) The genset battery is always charged so that you'll always b able to start the genset when it is needed. 2) The house battery or batteries are always maintained so you will always have power for interior lights and and other accessories like water pumps, slide-outs etc. 3) The AC shore power is always maintained even when your shore power fails due to a brown-out or complete shore power loss. Another typical mistake made by manufacturers is using the wrong Radio Shack ac adapter and connecting it to ac after the first transfer switch. It should be connected to shore power before the first transfer switch otherwise it won't be monitoring the shore power but rather it will be monitoring the generators AC output. Which means that the Gencon won't be able to respond to a brown-out condition. Having said all of this, each RV manufacturer decides how they want to implement the Gencon, and frankly, many have implemented the Gencon in ways that severly limit its unctionality. I hope this clarifies things. > Thanks so much for your help. > > John Suter > > > > --- lwesthaver1958 lwesthaver@... wrote: > > > Ralph, I think the best way to describe the > > operation of the Gencon > > is to say that it simply sits in a polling loop and > > watches the > > three main inputs ie. House battery, Cranking > > battery and shore > > power. > > > > There are subtle differences in the various firmware > > versions but > > typically the Gencon will start your genset if it > > sees a brown-out > > condition for at least ten seconds. Or if either > > battery drops below > > their respective thresholds. > > > > If you have any questions about specific firmware > > releases, please > > feel free to ask. > > > > As for schematics etc. You may post anything you > > find on the > > Westhaver Associates website here for the benefit of > > the Bluebird > > forum members. If there is some aspect of the Gencon > > that you would > > like to have explained/documented and it isn't > > already addressed on > > our website we'll do our best to address it and post > > the new > > information. > > > > Thank your for your support, > > Wes Westhaver > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > [Non-text portions of this message have been removed] |
