Emergency shut down mod
04-25-2006, 02:15
Good morning everyone:
There, recently, has been a situation that needs to be addressed with a modification added to the '88 through 90's Birds. I am working on drawing a schematic which adds a Bosh relay and a switch located in an accessory slot on the dash, for the engine emergency shut down of the engine. Problem: A relay, # 34 welded the contacts and the Coach could not be shut down with either the dash or rear key switch and there is not a manual cable pull such as in the older Bird's. Solution: Adding a relay to the fuel shut off valve circuit, that is controlled by a switch on the dash. The relay coil will be on the switch and the wire going to the fuel shut off valve on the engine will be on the normally closed side of the relay, thus if the added relay ever fails then it will fail closed keeping the power on the fuel shut off valve. By switching the relay, the circuit to the fuel shut off valve is opened up and you have engine shut down. I will try to get this modification added to the files section this weekend, with the correct wire numbers/colors and connections for those who might be interested. This circuit will be added to Ken and Patti Marsh's "ToWanda" Which is an '89PTWB. So far as I know, this is a first with this "no shut down" problem. It, seemingly has always been, "I can't get it to start" problem. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
04-25-2006, 02:34
Your cutoff should be at the base of your steering column, I believe.
Ernie-83pt40 [Non-text portions of this message have been removed] |
04-25-2006, 06:26
"there is not a manual cable pull such as in the older Bird's"
Does my '82 FC have one of these? Where is it? Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Good morning everyone: > > There, recently, has been a situation that needs to be addressed with a > modification added to the '88 through 90's Birds. > > I am working on drawing a schematic which adds a Bosh relay and a switch > located in an accessory slot on the dash, for the engine emergency shut > down of the engine. > > Problem: A relay, # 34 welded the contacts and the Coach could not be shut > down with either the dash or rear key switch and there is not a manual > cable pull such as in the older Bird's. > > Solution: Adding a relay to the fuel shut off valve circuit, that is > controlled by a switch on the dash. The relay coil will be on the switch > and the wire going to the fuel shut off valve on the engine will be on the > normally closed side of the relay, thus if the added relay ever fails then > it will fail closed keeping the power on the fuel shut off valve. By > switching the relay, the circuit to the fuel shut off valve is opened up > and you have engine shut down. > > I will try to get this modification added to the files section this > weekend, with the correct wire numbers/colors and connections for those who > might be interested. > > This circuit will be added to Ken and Patti Marsh's "ToWanda" Which is an > '89PTWB. > > So far as I know, this is a first with this "no shut down" problem. It, > seemingly has always been, "I can't get it to start" problem. > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
04-25-2006, 07:21
There is no shutoff for the 1982 FC models.
tom warner vernon center,ny 1985 pt40 At 02:34 PM 4/25/2006, you wrote: >Your cutoff should be at the base of your steering column, I believe. >Ernie-83pt40 > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-25-2006, 08:37
---EMERGENCY SHUTOFF OF DIESEL...I have been told by the old timers
here in Australia that to SHUT OFF a diesel just COVER THE AIR INTAKE WITH A TOWEL, RAGS ETC......I guess that sometimes diesels can.."RUN AWAY"... and that's how they shut them off..eg..NO AIR..NO RUN....I never had the need over here yet but Ralph's "shut off" switch" reminded me..so I am passing it on...I imagine that I will get a few comments.........I'm OUTTA HERE in 6 days.....Back to the great United States of America!!!!! See Ya! Hank Hannigan 90Sp36(stored in Vegas) In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Good morning everyone: > > There, recently, has been a situation that needs to be addressed with a > modification added to the '88 through 90's Birds. > > I am working on drawing a schematic which adds a Bosh relay and a switch > located in an accessory slot on the dash, for the engine emergency shut > down of the engine. > > Problem: A relay, # 34 welded the contacts and the Coach could not be shut > down with either the dash or rear key switch and there is not a manual > cable pull such as in the older Bird's. > > Solution: Adding a relay to the fuel shut off valve circuit, that is > controlled by a switch on the dash. The relay coil will be on the switch > and the wire going to the fuel shut off valve on the engine will be on the > normally closed side of the relay, thus if the added relay ever fails then > it will fail closed keeping the power on the fuel shut off valve. By > switching the relay, the circuit to the fuel shut off valve is opened up > and you have engine shut down. > > I will try to get this modification added to the files section this > weekend, with the correct wire numbers/colors and connections for those who > might be interested. > > This circuit will be added to Ken and Patti Marsh's "ToWanda" Which is an > '89PTWB. > > So far as I know, this is a first with this "no shut down" problem. It, > seemingly has always been, "I can't get it to start" problem. > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
04-25-2006, 09:45
Scott:
Two different engines and systems. My post concerns the PT's not FC's. Sorry for my not making that clear. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 06:26 PM 4/25/2006 +0000, you wrote: >"there is not a manual cable pull such as in the older Bird's" > >Does my '82 FC have one of these? Where is it? > >Scott Forman >82 FC35RB >Memphis > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Good morning everyone: > > > > There, recently, has been a situation that needs to be addressed >with a > > modification added to the '88 through 90's Birds. > > > > I am working on drawing a schematic which adds a Bosh relay and a >switch > > located in an accessory slot on the dash, for the engine emergency >shut > > down of the engine. > > > > Problem: A relay, # 34 welded the contacts and the Coach could not >be shut > > down with either the dash or rear key switch and there is not a >manual > > cable pull such as in the older Bird's. > > > > Solution: Adding a relay to the fuel shut off valve circuit, that >is > > controlled by a switch on the dash. The relay coil will be on the >switch > > and the wire going to the fuel shut off valve on the engine will be >on the > > normally closed side of the relay, thus if the added relay ever >fails then > > it will fail closed keeping the power on the fuel shut off valve. >By > > switching the relay, the circuit to the fuel shut off valve is >opened up > > and you have engine shut down. > > > > I will try to get this modification added to the files section this > > weekend, with the correct wire numbers/colors and connections for >those who > > might be interested. > > > > This circuit will be added to Ken and Patti Marsh's "ToWanda" Which >is an > > '89PTWB. > > > > So far as I know, this is a first with this "no shut down" >problem. It, > > seemingly has always been, "I can't get it to start" problem. > > > > > > |
04-25-2006, 10:36
have never seen a 4 cycle runaway But iam sure it can happen but have
had a 2000 horsepower GM runaway and blow it was neat 500 gallons of old oil every where Stephen --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Scott: > > Two different engines and systems. My post concerns the PT's not FC's. > Sorry for my not making that clear. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 06:26 PM 4/25/2006 +0000, you wrote: > >"there is not a manual cable pull such as in the older Bird's" > > > >Does my '82 FC have one of these? Where is it? > > > >Scott Forman > >82 FC35RB > >Memphis > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Good morning everyone: > > > > > > There, recently, has been a situation that needs to be addressed > >with a > > > modification added to the '88 through 90's Birds. > > > > > > I am working on drawing a schematic which adds a Bosh relay and a > >switch > > > located in an accessory slot on the dash, for the engine emergency > >shut > > > down of the engine. > > > > > > Problem: A relay, # 34 welded the contacts and the Coach could not > >be shut > > > down with either the dash or rear key switch and there is not a > >manual > > > cable pull such as in the older Bird's. > > > > > > Solution: Adding a relay to the fuel shut off valve circuit, that > >is > > > controlled by a switch on the dash. The relay coil will be on the > >switch > > > and the wire going to the fuel shut off valve on the engine will be > >on the > > > normally closed side of the relay, thus if the added relay ever > >fails then > > > it will fail closed keeping the power on the fuel shut off valve. > >By > > > switching the relay, the circuit to the fuel shut off valve is > >opened up > > > and you have engine shut down. > > > > > > I will try to get this modification added to the files section this > > > weekend, with the correct wire numbers/colors and connections for > >those who > > > might be interested. > > > > > > This circuit will be added to Ken and Patti Marsh's "ToWanda" Which > >is an > > > '89PTWB. > > > > > > So far as I know, this is a first with this "no shut down" > >problem. It, > > > seemingly has always been, "I can't get it to start" problem. > > > > > > > > > > > |
04-25-2006, 13:57
been around several runaways,we shut them down by knocking the fuel filter off with a hammer,shoving a raincoat in the air filter to try to choke the engine down(it didnt work),the flap in the early DD's don't work either,it will slow it down,but not shut it down.its hard to stand there and try to save an engine when its running wide open,take a sledge hammer,knock off a fuel line,then run! randy > > have never seen a 4 cycle runaway But iam sure it can happen but have > had a 2000 horsepower GM runaway and blow it was neat 500 gallons of > old oil every where > Stephen > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Scott: > > > > Two different engines and systems. My post concerns the PT's not FC's. > > Sorry for my not making that clear. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 06:26 PM 4/25/2006 +0000, you wrote: > > >"there is not a manual cable pull such as in the older Bird's" > > > > > >Does my '82 FC have one of these? Where is it? > > > > > >Scott Forman > > >82 FC35RB > > >Memphis > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > Good morning everyone: > > > > > > > > There, recently, has been a situation that needs to be addressed > > >with a > > > > modification added to the '88 through 90's Birds. > > > > > > > > I am working on drawing a schematic which adds a Bosh relay and a > > >switch > > > > located in an accessory slot on the dash, for the engine emergency > > >shut > > > > down of the engine. > > > > > > > > Problem: A relay, # 34 welded the contacts and the Coach could not > > >be shut > > > > down with either the dash or rear key switch and there is not a > > >manual > > > > cable pull such as in the older Bird's. > > > > > > > > Solution: Adding a relay to the fuel shut off valve circuit, that > > >is > > > > controlled by a switch on the dash. The relay coil will be on the > > >switch > > > > and the wire going to the fuel shut off valve on the engine will be > > >on the > > > > normally closed side of the relay, thus if the added relay ever > > >fails then > > > > it will fail closed keeping the power on the fuel shut off valve. > > >By > > > > switching the relay, the circuit to the fuel shut off valve is > > >opened up > > > > and you have engine shut down. > > > > > > > > I will try to get this modification added to the files section this > > > > weekend, with the correct wire numbers/colors and connections for > > >those who > > > > might be interested. > > > > > > > > This circuit will be added to Ken and Patti Marsh's "ToWanda" Which > > >is an > > > > '89PTWB. > > > > > > > > So far as I know, this is a first with this "no shut down" > > >problem. It, > > > > seemingly has always been, "I can't get it to start" problem. > > > > > > > > > > > > > > > > > |
04-25-2006, 14:35
and 16 power assemblies pointing in 16 different directions
when they are supposed to in a neat little vee put the roots right through the roof Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > been around several runaways,we shut them down by knocking the fuel > filter off with a hammer,shoving a raincoat in the air filter to try > to choke the engine down(it didnt work),the flap in the early DD's > don't work either,it will slow it down,but not shut it down.its hard > to stand there and try to save an engine when its running wide > open,take a sledge hammer,knock off a fuel line,then run! > randy > > > > have never seen a 4 cycle runaway But iam sure it can happen but > have > > had a 2000 horsepower GM runaway and blow it was neat 500 gallons > of > > old oil every where > > Stephen > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Scott: > > > > > > Two different engines and systems. My post concerns the PT's not > FC's. > > > Sorry for my not making that clear. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > http://home.swbell.net/rlf47/index.htm > > > > > > At 06:26 PM 4/25/2006 +0000, you wrote: > > > >"there is not a manual cable pull such as in the older Bird's" > > > > > > > >Does my '82 FC have one of these? Where is it? > > > > > > > >Scott Forman > > > >82 FC35RB > > > >Memphis > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > > > > Good morning everyone: > > > > > > > > > > There, recently, has been a situation that needs to be > addressed > > > >with a > > > > > modification added to the '88 through 90's Birds. > > > > > > > > > > I am working on drawing a schematic which adds a Bosh relay > and a > > > >switch > > > > > located in an accessory slot on the dash, for the engine > emergency > > > >shut > > > > > down of the engine. > > > > > > > > > > Problem: A relay, # 34 welded the contacts and the Coach > could not > > > >be shut > > > > > down with either the dash or rear key switch and there is > not a > > > >manual > > > > > cable pull such as in the older Bird's. > > > > > > > > > > Solution: Adding a relay to the fuel shut off valve > circuit, that > > > >is > > > > > controlled by a switch on the dash. The relay coil will be > on the > > > >switch > > > > > and the wire going to the fuel shut off valve on the engine > will be > > > >on the > > > > > normally closed side of the relay, thus if the added relay > ever > > > >fails then > > > > > it will fail closed keeping the power on the fuel shut off > valve. > > > >By > > > > > switching the relay, the circuit to the fuel shut off valve > is > > > >opened up > > > > > and you have engine shut down. > > > > > > > > > > I will try to get this modification added to the files > section this > > > > > weekend, with the correct wire numbers/colors and > connections for > > > >those who > > > > > might be interested. > > > > > > > > > > This circuit will be added to Ken and Patti > Marsh's "ToWanda" Which > > > >is an > > > > > '89PTWB. > > > > > > > > > > So far as I know, this is a first with this "no shut down" > > > >problem. It, > > > > > seemingly has always been, "I can't get it to start" problem. > > > > > > > > > > > > > > > > > > > > > > > > |
04-25-2006, 15:33
There is only one sure fire way to shut down a runnaway diesel and
that is to shut off the air. Since it is caused by either oil or fuel getting sucked into the intake past worn or blown turbocharger seals then the only control you have is thru the air that it needs to keep running. If this ever happens the quickest way to shut it down if the emergency shut off does not work is to aim a fire extinguisher at the air intake and give it a blast. Tom Warner Vernon Center,NY 1985 PT 40 |
