Problems with the fuel gauge and Engine cooling fan
05-06-2006, 14:36
We solved the problem we had with no water flow to the water heater
thanks to Ralph (stuck spool on the drain/fill valve). Now I need help with a couple more. I removed the fuel sender and installed a new one (the old one was defective-open circuit)The fuel gauge still reads all the way to the right even with the new sender(I bench tested the sender before I installed it) Does anyone know where I should look next as there must still be an open in the circuit. Also the engine fan stopped working on the fan override switch(still comes on with temp sw.)When I flip the switch I get a short hiss and a click but no fan. Jim Matus FC35SB Rescue CA |
