back up camera solenoid or relay or ???
05-07-2006, 14:07
My back-up camera works most of the time. When it doesn't work I get
a blue vertical line on a blank screen. Most of the time, simply turning off the TV and waiting a few minutes then back on, it works. Occasionally it doesn't come back on. Have to turn off the ignition switch and when itd turned back on, the backup camera works again. My conclusion to this... the relay or solenoid that causes the TV to show a TV show when key is off and to show the back-up camera when the key is on,.... is bad. I want to replace this relay or solenoid. Have looked in the over head above the driver. I have not found the relay or solenoid yet. Anybody KNOW where the solenoid or relay IS? If its a weird piece, where do I get it? What part number is it? Thanks in advance!, Jay Darst 85PT40 Springfield, IL where I just got back from the AHDA races in Madison, IL(St.Louis area)(AHDA = ALL Harley Drag racing Association). The TOP FUEL bikes run the 1/4 in 5.60sec @ 215mph, sound just like a top fuel dragster! Spent the weekend there in the Bird. The outside stereo and TV was a hit with the bikers! |
05-07-2006, 15:27
Jay:
That relay is in the chassis of the CT-911 and was part of the modification by PMMI. There is a white plug on the back side of the chassis that has 5 wires and more than likely that is where your problem may be. Ralph Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 02:07 AM 5/8/2006 +0000, you wrote: >My back-up camera works most of the time. When it doesn't work I get >a blue vertical line on a blank screen. Most of the time, simply >turning off the TV and waiting a few minutes then back on, it works. > >Occasionally it doesn't come back on. Have to turn off the ignition >switch and when itd turned back on, the backup camera works again. > >My conclusion to this... the relay or solenoid that causes the TV to >show a TV show when key is off and to show the back-up camera when >the key is on,.... is bad. > >I want to replace this relay or solenoid. Have looked in the over >head above the driver. I have not found the relay or solenoid yet. > >Anybody KNOW where the solenoid or relay IS? If its a weird piece, >where do I get it? What part number is it? > >Thanks in advance!, >Jay Darst >85PT40 > |
05-07-2006, 15:54
Thanks Ralph.
The Tv screen is over head, above the windshield, the tuner and stuff is in the overhead bin on the traffic side above the driver. Where/what is a CT-911? The plug itself is the problem? Thanks again! Jay Darst 85PT40 Spfld, IL --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Jay: > > That relay is in the chassis of the CT-911 and was part of the modification > by PMMI. There is a white plug on the back side of the chassis that has 5 > wires and more than likely that is where your problem may be. > > Ralph > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 02:07 AM 5/8/2006 +0000, you wrote: > >My back-up camera works most of the time. When it doesn't work I get > >a blue vertical line on a blank screen. Most of the time, simply > >turning off the TV and waiting a few minutes then back on, it works. > > > >Occasionally it doesn't come back on. Have to turn off the ignition > >switch and when itd turned back on, the backup camera works again. > > > >My conclusion to this... the relay or solenoid that causes the TV to > >show a TV show when key is off and to show the back-up camera when > >the key is on,.... is bad. > > > >I want to replace this relay or solenoid. Have looked in the over > >head above the driver. I have not found the relay or solenoid yet. > > > >Anybody KNOW where the solenoid or relay IS? If its a weird piece, > >where do I get it? What part number is it? > > > >Thanks in advance!, > >Jay Darst > >85PT40 > > > |
05-07-2006, 16:09
The tuner is where the relay is located. It is a solder in added to the
chassis by PMMI. The back up monitor and tv is a Hitachi CT-911 that PMMI modified. The plug has wires in it and check the pins in the plug. It is where the incoming power goes through and has been a problem in the past. The relay in question is a solid state and rarely has problems. Ralph At 03:54 AM 5/8/2006 +0000, you wrote: >Thanks Ralph. > >The Tv screen is over head, above the windshield, the tuner and >stuff is in the overhead bin on the traffic side above the driver. >Where/what is a CT-911? > >The plug itself is the problem? > >Thanks again! >Jay Darst >85PT40 >Spfld, IL > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Jay: > > > > That relay is in the chassis of the CT-911 and was part of the >modification > > by PMMI. There is a white plug on the back side of the chassis >that has 5 > > wires and more than likely that is where your problem may be. > > > > Ralph > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 02:07 AM 5/8/2006 +0000, you wrote: > > >My back-up camera works most of the time. When it doesn't work I >get > > >a blue vertical line on a blank screen. Most of the time, simply > > >turning off the TV and waiting a few minutes then back on, it >works. > > > > > >Occasionally it doesn't come back on. Have to turn off the >ignition > > >switch and when itd turned back on, the backup camera works again. > > > > > >My conclusion to this... the relay or solenoid that causes the TV >to > > >show a TV show when key is off and to show the back-up camera when > > >the key is on,.... is bad. > > > > > >I want to replace this relay or solenoid. Have looked in the over > > >head above the driver. I have not found the relay or solenoid yet. > > > > > >Anybody KNOW where the solenoid or relay IS? If its a weird piece, > > >where do I get it? What part number is it? > > > > > >Thanks in advance!, > > >Jay Darst > > >85PT40 > > > > > > > > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
05-08-2006, 02:04
Ralph,
In my 86 PT40 The backup camera has a paper label on the inside casing that says Audiotronics is this a Hitachi brand. At times it will play fine then go blank. I can tap on the case and it will sometimes come back on other times will flash lines across screen. I have moved wiring around running to case with no results so I think it must be internal. Is there some place to get it repaired. Your thoughts please. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 08, 2006 12:09 AM Subject: Re: [WanderlodgeForum] Re: back up camera solenoid or relay or ??? The tuner is where the relay is located. It is a solder in added to the chassis by PMMI. The back up monitor and tv is a Hitachi CT-911 that PMMI modified. The plug has wires in it and check the pins in the plug. It is where the incoming power goes through and has been a problem in the past. The relay in question is a solid state and rarely has problems. Ralph At 03:54 AM 5/8/2006 +0000, you wrote: >Thanks Ralph. > >The Tv screen is over head, above the windshield, the tuner and >stuff is in the overhead bin on the traffic side above the driver. >Where/what is a CT-911? > >The plug itself is the problem? > >Thanks again! >Jay Darst >85PT40 >Spfld, IL > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Jay: > > > > That relay is in the chassis of the CT-911 and was part of the >modification > > by PMMI. There is a white plug on the back side of the chassis >that has 5 > > wires and more than likely that is where your problem may be. > > > > Ralph > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 02:07 AM 5/8/2006 +0000, you wrote: > > >My back-up camera works most of the time. When it doesn't work I >get > > >a blue vertical line on a blank screen. Most of the time, simply > > >turning off the TV and waiting a few minutes then back on, it >works. > > > > > >Occasionally it doesn't come back on. Have to turn off the >ignition > > >switch and when itd turned back on, the backup camera works again. > > > > > >My conclusion to this... the relay or solenoid that causes the TV >to > > >show a TV show when key is off and to show the back-up camera when > > >the key is on,.... is bad. > > > > > >I want to replace this relay or solenoid. Have looked in the over > > >head above the driver. I have not found the relay or solenoid yet. > > > > > >Anybody KNOW where the solenoid or relay IS? If its a weird piece, > > >where do I get it? What part number is it? > > > > > >Thanks in advance!, > > >Jay Darst > > >85PT40 > > > > > > > > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-08-2006, 02:41
Howard:
This is the first I have heard of the Audiotronics being used. When Doug Hampton, of PMMI, sent me the file on the back up camera system, I was doing a write up on image reversing, there was only the Hitachi CT-911 in the file. The image reversing was done via external relays but the Color TV (when Coach key was off) or the back up camera ( when Coach key was in the run position) is done with an internal solid state relay. Your problem sounds more like a cold solder joint or bad variable resistor (pot) on the chassis part of the system. As to service, I honestly do not know. PMMI did change some of the circuitry by adding the solid state relay and there were a couple of board traces cut and re directed in the gain control section. The P to P and voltages remained the same though. So a competent TV repair should be able to help you. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 10:04 AM 5/8/2006 -0400, you wrote: >Ralph, >In my 86 PT40 The backup camera has a paper label on the inside casing >that says Audiotronics is this a Hitachi brand. At times it will play >fine then go blank. I can tap on the case and it will sometimes come back >on other times will flash lines across screen. I have moved wiring around >running to case with no results so I think it must be internal. Is there >some place to get it repaired. Your thoughts please. >Howard Truitt >Camilla, Ga. >86 PT40 > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, May 08, 2006 12:09 AM > Subject: Re: [WanderlodgeForum] Re: back up camera solenoid or relay or ??? > > > The tuner is where the relay is located. It is a solder in added to the > chassis by PMMI. The back up monitor and tv is a Hitachi CT-911 that PMMI > modified. The plug has wires in it and check the pins in the plug. It is > where the incoming power goes through and has been a problem in the past. > The relay in question is a solid state and rarely has problems. > > Ralph > |
05-08-2006, 08:04
i just changed mine to colour have a good camara fifity bucks call me david 386
804 5619 mine is an 86 pt40 also "Howard O. Truitt" In my 86 PT40 The backup camera has a paper label on the inside casing that says Audiotronics is this a Hitachi brand. At times it will play fine then go blank. I can tap on the case and it will sometimes come back on other times will flash lines across screen. I have moved wiring around running to case with no results so I think it must be internal. Is there some place to get it repaired. Your thoughts please. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 08, 2006 12:09 AM Subject: Re: [WanderlodgeForum] Re: back up camera solenoid or relay or ??? The tuner is where the relay is located. It is a solder in added to the chassis by PMMI. The back up monitor and tv is a Hitachi CT-911 that PMMI modified. The plug has wires in it and check the pins in the plug. It is where the incoming power goes through and has been a problem in the past. The relay in question is a solid state and rarely has problems. Ralph At 03:54 AM 5/8/2006 +0000, you wrote: >Thanks Ralph. > >The Tv screen is over head, above the windshield, the tuner and >stuff is in the overhead bin on the traffic side above the driver. >Where/what is a CT-911? > >The plug itself is the problem? > >Thanks again! >Jay Darst >85PT40 >Spfld, IL > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Jay: > > > > That relay is in the chassis of the CT-911 and was part of the >modification > > by PMMI. There is a white plug on the back side of the chassis >that has 5 > > wires and more than likely that is where your problem may be. > > > > Ralph > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 02:07 AM 5/8/2006 +0000, you wrote: > > >My back-up camera works most of the time. When it doesn't work I >get > > >a blue vertical line on a blank screen. Most of the time, simply > > >turning off the TV and waiting a few minutes then back on, it >works. > > > > > >Occasionally it doesn't come back on. Have to turn off the >ignition > > >switch and when itd turned back on, the backup camera works again. > > > > > >My conclusion to this... the relay or solenoid that causes the TV >to > > >show a TV show when key is off and to show the back-up camera when > > >the key is on,.... is bad. > > > > > >I want to replace this relay or solenoid. Have looked in the over > > >head above the driver. I have not found the relay or solenoid yet. > > > > > >Anybody KNOW where the solenoid or relay IS? If its a weird piece, > > >where do I get it? What part number is it? > > > > > >Thanks in advance!, > > >Jay Darst > > >85PT40 > > > > > > > > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates. [Non-text portions of this message have been removed] |
05-08-2006, 08:38
This is the '86-up monitor, I believe they later became Dotronix.
Your problem is a common one. If you remove the monitor (fairly simple in your coach with the overhead mount), it can be repaired. I have found that the daughter-board has an edge connector which is prone to solder-joints failing, probably from vibration. Re-soldering the connector on the daughter-board and mother-board should (and has always for me) fix the problem. Supporting the board so that it can't as easily vibrate/move should also prevent the problem in the future. That is also a great time to reverse the image so that you can install a new camera. The red and blue wires on the two-pin connector on the mother-board need to be cut and reversed (red to blue, blue to red), then a new BNC-type camera can be used. I've been very happy with ultra- low-light .003 lux B&W cameras from Supercircuits.com, much cheaper cameras are available from them and others also. The Dotronix monitor is B&W. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Ralph, > In my 86 PT40 The backup camera has a paper label on the inside casing that says Audiotronics is this a Hitachi brand. At times it will play fine then go blank. I can tap on the case and it will sometimes come back on other times will flash lines across screen. I have moved wiring around running to case with no results so I think it must be internal. Is there some place to get it repaired. Your thoughts please. > Howard Truitt > Camilla, Ga. > 86 PT40 |
05-08-2006, 15:44
ALl RIGHT! Thanks Ralph, thats a big help!
I'll look into it. Thanks Jay Darst 85PT40 Spfld, IL --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > The tuner is where the relay is located. It is a solder in added to the > chassis by PMMI. The back up monitor and tv is a Hitachi CT-911 that PMMI > modified. The plug has wires in it and check the pins in the plug. It is > where the incoming power goes through and has been a problem in the past. > The relay in question is a solid state and rarely has problems. > > Ralph > > At 03:54 AM 5/8/2006 +0000, you wrote: > >Thanks Ralph. > > > >The Tv screen is over head, above the windshield, the tuner and > >stuff is in the overhead bin on the traffic side above the driver. > >Where/what is a CT-911? > > > >The plug itself is the problem? > > > >Thanks again! > >Jay Darst > >85PT40 > >Spfld, IL > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Jay: > > > > > > That relay is in the chassis of the CT-911 and was part of the > >modification > > > by PMMI. There is a white plug on the back side of the chassis > >that has 5 > > > wires and more than likely that is where your problem may be. > > > > > > Ralph > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > http://home.swbell.net/rlf47/index.htm > > > > > > At 02:07 AM 5/8/2006 +0000, you wrote: > > > >My back-up camera works most of the time. When it doesn't work I > >get > > > >a blue vertical line on a blank screen. Most of the time, simply > > > >turning off the TV and waiting a few minutes then back on, it > >works. > > > > > > > >Occasionally it doesn't come back on. Have to turn off the > >ignition > > > >switch and when itd turned back on, the backup camera works again. > > > > > > > >My conclusion to this... the relay or solenoid that causes the TV > >to > > > >show a TV show when key is off and to show the back-up camera when > > > >the key is on,.... is bad. > > > > > > > >I want to replace this relay or solenoid. Have looked in the over > > > >head above the driver. I have not found the relay or solenoid yet. > > > > > > > >Anybody KNOW where the solenoid or relay IS? If its a weird piece, > > > >where do I get it? What part number is it? > > > > > > > >Thanks in advance!, > > > >Jay Darst > > > >85PT40 > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > |
05-09-2006, 02:24
Jeff,
Do you or anyone else have a mother board schematic for the Audiotronic back up monitor that you could send me. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 08, 2006 4:38 PM Subject: [WanderlodgeForum] Re: back up camera solenoid or relay or ??? This is the '86-up monitor, I believe they later became Dotronix. Your problem is a common one. If you remove the monitor (fairly simple in your coach with the overhead mount), it can be repaired. I have found that the daughter-board has an edge connector which is prone to solder-joints failing, probably from vibration. Re-soldering the connector on the daughter-board and mother-board should (and has always for me) fix the problem. Supporting the board so that it can't as easily vibrate/move should also prevent the problem in the future. That is also a great time to reverse the image so that you can install a new camera. The red and blue wires on the two-pin connector on the mother-board need to be cut and reversed (red to blue, blue to red), then a new BNC-type camera can be used. I've been very happy with ultra- low-light .003 lux B&W cameras from Supercircuits.com, much cheaper cameras are available from them and others also. The Dotronix monitor is B&W. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Ralph, > In my 86 PT40 The backup camera has a paper label on the inside casing that says Audiotronics is this a Hitachi brand. At times it will play fine then go blank. I can tap on the case and it will sometimes come back on other times will flash lines across screen. I have moved wiring around running to case with no results so I think it must be internal. Is there some place to get it repaired. Your thoughts please. > Howard Truitt > Camilla, Ga. > 86 PT40 SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
User(s) browsing this thread: 10 Guest(s)
