Facet Fan Teardown.
05-16-2006, 16:47
Facet Fan Teardown.
I am getting ready to dissassemble the Facet fan and pulley hub on my
Bird in order to replace all of the bearings. I am doing this as
preventive maint.as I understand these fans are made out of
unobtainimum. I don't want to damage any of the parts so would like to
know the proper order of teardown. Also are the bearings in the hub
packed like a wheel bearing or is there oil in the hub.
Jim Matus 1984 FC35SB Rescue CA
05-17-2006, 01:56
Facet Fan Teardown.
I got a couple of Horton air clutch situations if you run into big problems.
The pulley hub has facing tapered bearings like a front wheel spindle. I takes
about 4 oz. of oil to fill the cavity when reassembling. Use 80/90. End play
for the pulley hub is .001 to .010, torque the nut to 110 ft. lbs. If the
bearing races are in good shape, I would not bother changing the bearing
assemblies but DO change the seal.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Tuesday, May 16, 2006 11:47 PM
Subject: [WanderlodgeForum] Facet Fan Teardown.
YAHOO! GROUPS LINKS
05-17-2006, 15:50
Facet Fan Teardown.
I dont have finess and confidence to do a rebuild. I just removed a
air fan clutch on my 94 Aeromax N14 and sent it out for a rebuild.
$180.00. The turn around time was two days
GregO'Connor
94pt40
Romoland Ca
problems. The pulley hub has facing tapered bearings like a front
wheel spindle. I takes about 4 oz. of oil to fill the cavity when
reassembling. Use 80/90. End play for the pulley hub is .001
to .010, torque the nut to 110 ft. lbs. If the bearing races are in
good shape, I would not bother changing the bearing assemblies but
DO change the seal.
> Mike Hohnstein
> Germantown, WI
> 83FC35
> From: jim matus
on my
like to
hub
> YAHOO! GROUPS LINKS
of Service.
