galley window removal 80FC
05-29-2006, 03:40
my Kitchen window is broke and I'd like to get a new piece of glass
cut for it but I can't seem to get it out. Does the whole window frame have to come off to remove the sliding window? Thanks Mike Meister 80fc Taylor Mill, Ky |
05-30-2006, 13:27
I believe it does, that's how I've done it.
Remove the inside aluminum trim, remove wires from alarm sensor (if equipped) if you can reach them at this point. Outside, the rubber is overlapped at the seam which you see, un- overlap it. The window assembly can now be pushed out of the rubber, someone outside the coach to catch of course, if it has an alarm you will need to push the bottom out first. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Mike Meister" <mike.meister@...> wrote: > > my Kitchen window is broke and I'd like to get a new piece of glass > cut for it but I can't seem to get it out. Does the whole window frame > have to come off to remove the sliding window? > > Thanks > > Mike Meister > 80fc > Taylor Mill, Ky > |
05-30-2006, 13:42
Thanks Jeff-
Mike Meister 80FC Taylor Mill, Ky. (and heading to Montana 7/1/06) --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > I believe it does, that's how I've done it. > > Remove the inside aluminum trim, remove wires from alarm sensor (if > equipped) if you can reach them at this point. > > Outside, the rubber is overlapped at the seam which you see, un- > overlap it. > > The window assembly can now be pushed out of the rubber, someone > outside the coach to catch of course, if it has an alarm you will > need to push the bottom out first. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Mike Meister" > <mike.meister@> wrote: > > > > my Kitchen window is broke and I'd like to get a new piece of > glass > > cut for it but I can't seem to get it out. Does the whole window > frame > > have to come off to remove the sliding window? > > > > Thanks > > > > Mike Meister > > 80fc > > Taylor Mill, Ky > > > |
