3208 thermostat housing removal, How do you get the dang thing off.
05-29-2006, 14:29
I just rebuilt my fan assy.,and the water pump belt idler so I figured
I would change the thermostats while I was in the front. I took out the 3 bolts but there are 2 studs w/nuts that won't come out. The stud turns with the nut but doesn't back out. I have the Cat shop manual and it shows a different water neck. Is the 180 degree neck a Blue bird Item? Are the studs really bolts put in from the backside of the thermostat housing before it is installed? I don't want to damage the casting and I don't know if I need to split the nuts on the studs or what. Also if anyone wants to rebuild their idler assy. I can give you the Cat part#s for the parts you need. About $40.00 worth of parts instead of $375.00 for a new idler assy.Thanks Jim Matus 1984FC35SB Rescue CA |
05-29-2006, 15:29
I seem to remember that stud goes all the way through and there is a nut on the
other side. You can reach it with an open end wrench. Dan 81FCRB Jackson, MS ----- Original Message ----- From: jim matus To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 29, 2006 9:29 PM Subject: [WanderlodgeForum] 3208 thermostat housing removal, How do you get the dang thing off. I just rebuilt my fan assy.,and the water pump belt idler so I figured I would change the thermostats while I was in the front. I took out the 3 bolts but there are 2 studs w/nuts that won't come out. The stud turns with the nut but doesn't back out. I have the Cat shop manual and it shows a different water neck. Is the 180 degree neck a Blue bird Item? Are the studs really bolts put in from the backside of the thermostat housing before it is installed? I don't want to damage the casting and I don't know if I need to split the nuts on the studs or what. Also if anyone wants to rebuild their idler assy. I can give you the Cat part#s for the parts you need. About $40.00 worth of parts instead of $375.00 for a new idler assy.Thanks Jim Matus 1984FC35SB Rescue CA SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-31-2006, 16:08
THANKS Dan I never thought they would have used such long thru
bolts.--- > > I seem to remember that stud goes all the way through and there is a nut on the other side. You can reach it with an open end wrench. > > Dan > 81FCRB > Jackson, MS > ----- Original Message ----- > From: jim matus > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, May 29, 2006 9:29 PM > Subject: [WanderlodgeForum] 3208 thermostat housing removal, How do you get the dang thing off. > > > I just rebuilt my fan assy.,and the water pump belt idler so I figured > I would change the thermostats while I was in the front. I took out the > 3 bolts but there are 2 studs w/nuts that won't come out. The stud > turns with the nut but doesn't back out. I have the Cat shop manual and > it shows a different water neck. Is the 180 degree neck a Blue bird > Item? > Are the studs really bolts put in from the backside of the thermostat > housing before it is installed? I don't want to damage the casting and > I don't know if I need to split the nuts on the studs or what. Also if > anyone wants to rebuild their idler assy. I can give you the Cat part#s > for the parts you need. About $40.00 worth of parts instead of $375.00 > for a new idler assy.Thanks Jim Matus 1984FC35SB Rescue CA > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair > Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
