Replacing Power Steering Hoses to Steering Box
06-06-2006, 17:27
Fellow Wanderlodgers,
I'm working to replace all my power steering lines.
I've got nearly everything off, except, I have not yet found a good
way to remove the lines from the steering box itself.
On my 83 FC-35, the steering box is so stuffed between the battery box
and frame rail, I can't even see it, nevermind reach it.
I went through previous posts and found one that recommended removing
the drivers seat, rolling back the carpet, and exposing an access
plate on the floor. I tried that - turns out my model does not have a
plate above the steering box.
Anybody have any experience in this?? There must be an easier way
that I'm missing... Bluebird usually has a way that everything can be
removed..
Any help is appreciated! Thanks!
Andy
06-06-2006, 22:39
Remove battery box.
MH
Sent: Wednesday, June 07, 2006 12:27 AM
Subject: [WanderlodgeForum] Replacing Power Steering Hoses to Steering Box
removed..
Andy
06-07-2006, 01:01
Andy,
On our 88 FC, I was able to remove the batteries, Lay on the ground
and use a crows foot on a long extention, Needed a helper with the
wrench to place it on the nut with each 1/4 turn. You may need to
rearrange some wireing harnesses.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Andy Coleman"
box
removing
have a
can be
> removed..
> Andy
Loading...
