Toyota Toad
06-26-2006, 08:10
Toyota Toad
Has anyone used a Toyato pickup as a towed vehicle? If so would appreciate your
views?
Wallace Craig
95 WLWB 42
Azle, Texas
06-26-2006, 08:30
Toyota Toad
> appreciate your views?
> Wallace Craig
> 95 WLWB 42
> Azle, Texas
I have a '93 Camry and a '03 Echo (both automatics) ... after
reviewing all the possibilities, I'm getting a dolly. If your pickup
is a stick and/or 4WD, there may be some flat-towing options.
Remco <http://www.remcotowing.com> has lubrication pumps or other add
ons for auto-trans Toyotas (depending on model and year).
Don't forget to add some sort of supplemental braking as well, if you
flat-tow.
Pete Masterson
aeonix1@...
'95 Bluebird Wanderlodge WBDA 4203
El Sobrante, CA
06-26-2006, 12:00
Toyota Toad
WE tow an 05 Tacoma 4wd auto. Had a Remco Driveshaft disconnect
installed. Great vehicle and tows well. Any of the newer Toys cannot be
towed without the disconnect due to the electronic transfer case.
Bruce
