update on generator and slide.
07-27-2006, 04:06
First, Thanks for the help and information. I check my jacks and they
are working fine. The slide still doesn't work. I'am going to slide it
out tonight after i remove the pin. I checked the battery on the
generator and it is fine. The generator started this morning and ran
for 30 min. and died. Will not even turn over again. All fluids are
fine and the gauges are all reading ok.
Best regards,
Rick Mcintire
86PT38 Patillo,Tx
07-27-2006, 16:32
Rick,
I had a similar problem on my 84 PT. The valve that routes the fluid
was stuck. It is located under the step along with the pump that works
both the jacks and the slide. When you call for the genny to slide out
the valve routes the fluid to the jack that runs the genny out. When
you want to run your jacks down the valve routes the fluid to the
jacks. Not using these systems will cause the valve to stick. On mine
I helped the genny in and out a couple of times and now it seems OK.
I'm going to exercise them weekly now. This may not be your problem
but I thought I would pass the info on.
John Slone
Pikeville, Ky
84 PT 35
--- In WanderlodgeForum@yahoogroups.com, "trautoranch"
they
it
> Best regards,
> Rick Mcintire
> 86PT38 Patillo,Tx
