Squirell Cage Fan
07-29-2006, 05:52
Squirell Cage Fan
I have 2 or 3 12 volt fan motors that came out of the squirell cage fans on
the dash AC unit of my bird. I dont know if they are close to what you need or not. Sam Durrett 68 31 FC TN In a message dated 7/29/2006 4:37:19 P.M. Central Standard Time, truitt44@... writes: --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , "Howard O. Truitt" > > Fellows, > I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-29-2006, 08:01
Squirell Cage Fan
Fellows,
I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. Howard Truitt Camilla, Ga. 86 8V92 PT40 [Non-text portions of this message have been removed] |
07-29-2006, 08:01
Squirell Cage Fan
Fellows,
07-29-2006, 08:28
Squirell Cage Fan
I have often wondered why an old fresh water pump motor could not be
adapted for that fan. I have not taken a close look at it but if the shaft is long enough,,,,,,,,, hmm Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:01 PM 7/29/2006 -0400, you wrote: >Fellows, >I need a squirell cage fan motor for the fan in the engine compartment >Does anyone have one they they can part with. >Howard Truitt >Camilla, Ga. >86 8V92 PT40 > > |
07-29-2006, 08:33
Squirell Cage Fan
Howard
would there be any numbers or makers marks on that little beauty Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Fellows, > I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] > |
07-29-2006, 09:36
Squirell Cage Fan
Stephen,
I will have to check on the numbers. BB parts does not have it. They reccomended checking with Grainger. I just thought I would ask if anyone had one. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 4:33 PM Subject: [WanderlodgeForum] Re: Squirell Cage Fan Howard would there be any numbers or makers marks on that little beauty Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Fellows, > I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 [Non-text portions of this message have been removed] |
07-29-2006, 10:30
Squirell Cage Fan
Howard,
If Grainger has your part, they have a good web site. http://www.grainger.com Type in centrifugal fan motors , search and you will find a replacement. Or try to get the part number off of your motor and it may cross to a Grainger part number. These motors are not too costly you may want to replace the whole fan & motor. I am not sure, if you are looking for 12V DC or 110v AC. I used a 110V quiet AC computer fan to circulate air through the bay that houses the Battery Charger. Bill 88 FC Michigan Way toooooooo hot today! --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Stephen, > I will have to check on the numbers. BB parts does not have it. They reccomended checking with Grainger. > I just thought I would ask if anyone had one. > Howard Truitt > Camilla, Ga. > 86 PT40 > ----- Original Message ----- > From: Stephen Birtles > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 29, 2006 4:33 PM > Subject: [WanderlodgeForum] Re: Squirell Cage Fan > > > Howard > would there be any numbers or makers marks on that little beauty > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Fellows, > > I need a squirell cage fan motor for the fan in the engine > compartment Does anyone have one they they can part with. > > Howard Truitt > > Camilla, Ga. > > 86 8V92 PT40 > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------- ----------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 > > > [Non-text portions of this message have been removed] > |
07-29-2006, 11:27
Squirell Cage Fan
Stephen,
I went ahead and pulled the motor and I don't see any markings. Looks like it had a label but it's missing Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 5:36 PM Subject: Re: [WanderlodgeForum] Re: Squirell Cage Fan Stephen, I will have to check on the numbers. BB parts does not have it. They recomended checking with Grainger. I just thought I would ask if anyone had one. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 4:33 PM Subject: [WanderlodgeForum] Re: Squirell Cage Fan Howard would there be any numbers or makers marks on that little beauty Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Fellows, > I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 [Non-text portions of this message have been removed] |
07-29-2006, 12:01
Squirell Cage Fan
Bill,
This is 12vdc and sits at rear above the engine compartment and is used to cool down engine after shutdown Howard ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 29, 2006 6:30 PM Subject: [WanderlodgeForum] Re: Squirell Cage Fan Howard, If Grainger has your part, they have a good web site. http://www.grainger.com Type in centrifugal fan motors , search and you will find a replacement. Or try to get the part number off of your motor and it may cross to a Grainger part number. These motors are not too costly you may want to replace the whole fan & motor. I am not sure, if you are looking for 12V DC or 110v AC. I used a 110V quiet AC computer fan to circulate air through the bay that houses the Battery Charger. Bill 88 FC Michigan Way toooooooo hot today! --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Stephen, > I will have to check on the numbers. BB parts does not have it. They reccomended checking with Grainger. > I just thought I would ask if anyone had one. > Howard Truitt > Camilla, Ga. > 86 PT40 > ----- Original Message ----- > From: Stephen Birtles > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 29, 2006 4:33 PM > Subject: [WanderlodgeForum] Re: Squirell Cage Fan > > > Howard > would there be any numbers or makers marks on that little beauty > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > Fellows, > > I need a squirell cage fan motor for the fan in the engine > compartment Does anyone have one they they can part with. > > Howard Truitt > > Camilla, Ga. > > 86 8V92 PT40 > > > > [Non-text portions of this message have been removed] > > > > > > > > > ---------------------------------------------------------- ----------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006 [Non-text portions of this message have been removed] |
07-29-2006, 14:37
Squirell Cage Fan
Hi Howard,
When I had my '90PT, the blower went bad and I replaced it with a piece of homemade duct, a couple of feet of defroster hose and a 12VDC bilge blower. This worked great and kept the new blower a little fureher from the engine heat. If I did this right, here is a link to a photo of the modification. http://i7.tinypic.com/21del2h.jpg Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Fellows, > I need a squirell cage fan motor for the fan in the engine compartment Does anyone have one they they can part with. > Howard Truitt > Camilla, Ga. > 86 8V92 PT40 > > [Non-text portions of this message have been removed] > |
