1978 air srep
08-17-2006, 14:21
1978 air srep
I have downloaded the file from the 'files' section and hope it is
close to the 1978 step control. My step retracts but doesn't extend. This weekend I plan to try to get it working. Has anyone out there worked with a 1978 step? Is ti the same wiring as the one in the Files section? Gardner 78FC33 |
08-18-2006, 04:36
1978 air srep
Gardner,
The air step is very dangerous to work on. Be aware of your body parts (particularly your head) when working on wiring/switches/ valves, etc. located near the operating mechanism. The air step can extend or retract without warning. We want you to be a long-term BB owner! Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > I have downloaded the file from the 'files' section and hope it is > close to the 1978 step control. My step retracts but doesn't extend. > This weekend I plan to try to get it working. Has anyone out there > worked with a 1978 step? Is ti the same wiring as the one in the Files > section? > > Gardner > 78FC33 > > > > > > > > Yahoo! Groups Links > > > > > > [Non-text portions of this message have been removed] |
08-18-2006, 05:34
1978 air srep
Pete,
Thanks for the warning. I am not new to mechanical things, but sometimes I can be inatentive and shortsighted. What I plan to do is disconnect the piston and work from there. That means I need to push the step in and out to activate the right switches at the right stage, but I will save my head, fingers, etc! Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Gardner, > > The air step is very dangerous to work on. Be aware of your body > parts (particularly your head) when working on wiring/switches/ > valves, etc. located near the operating mechanism. The air step can > extend or retract without warning. We want you to be a long-term BB > owner! > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > > > > > On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > > > I have downloaded the file from the 'files' section and hope it is > > close to the 1978 step control. My step retracts but doesn't extend. > > This weekend I plan to try to get it working. Has anyone out there > > worked with a 1978 step? Is ti the same wiring as the one in the Files > > section? > > > > Gardner > > 78FC33 > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
08-18-2006, 09:53
1978 air srep
wrote: > > Pete, > Thanks for the warning. I am not new to mechanical things, but > sometimes I can be inatentive and shortsighted. What I plan to do is > disconnect the piston and work from there. That means I need to push > the step in and out to activate the right switches at the right > stage, but I will save my head, fingers, etc! > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > Gardner, > > > > The air step is very dangerous to work on. Be aware of your body > > parts (particularly your head) when working on wiring/switches/ > > valves, etc. located near the operating mechanism. The air step > can > > extend or retract without warning. We want you to be a long-term > BB > > owner! > > > > Pete Masterson > > aeonix1@ > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > > > > > > > > On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > > > > > I have downloaded the file from the 'files' section and hope it is > > > close to the 1978 step control. My step retracts but doesn't > extend. > > > This weekend I plan to try to get it working. Has anyone out there > > > worked with a 1978 step? Is ti the same wiring as the one in the > Files > > > section? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
08-18-2006, 09:53
1978 air srep
08-18-2006, 09:53
1978 air srep
08-18-2006, 09:57
1978 air srep
Gardner, There is atleast one or two micro-switches, that are trouble makers. And also the switch in the door jam. The air solenoid switch can sometimes be taken apart, cleaned and lubricated. Check the ground wires. There is a write up in the files somewhere and on the Vintage site. Bill 88 FC -- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Pete, > Thanks for the warning. I am not new to mechanical things, but > sometimes I can be inatentive and shortsighted. What I plan to do is > disconnect the piston and work from there. That means I need to push > the step in and out to activate the right switches at the right > stage, but I will save my head, fingers, etc! > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > Gardner, > > > > The air step is very dangerous to work on. Be aware of your body > > parts (particularly your head) when working on wiring/switches/ > > valves, etc. located near the operating mechanism. The air step > can > > extend or retract without warning. We want you to be a long-term > BB > > owner! > > > > Pete Masterson > > aeonix1@ > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > > > > > > > > On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > > > > > I have downloaded the file from the 'files' section and hope it is > > > close to the 1978 step control. My step retracts but doesn't > extend. > > > This weekend I plan to try to get it working. Has anyone out there > > > worked with a 1978 step? Is ti the same wiring as the one in the > Files > > > section? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
08-18-2006, 11:17
1978 air srep
Gardner:
I have redrawn my wiring diagrams to schematics, and I only have one relay to work with, not the 4 like on the SP. Eventually if all goes well I will download them into the files section as well. If you got fax number I can fax you the one I have redrawn. Bill 84FC35SB Terrace, B.C. pattypape --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Pete, > Thanks for the warning. I am not new to mechanical things, but > sometimes I can be inatentive and shortsighted. What I plan to do is > disconnect the piston and work from there. That means I need to push > the step in and out to activate the right switches at the right > stage, but I will save my head, fingers, etc! > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: > > > > Gardner, > > > > The air step is very dangerous to work on. Be aware of your body > > parts (particularly your head) when working on wiring/switches/ > > valves, etc. located near the operating mechanism. The air step > can > > extend or retract without warning. We want you to be a long-term > BB > > owner! > > > > Pete Masterson > > aeonix1@ > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > > > > > > > > On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > > > > > I have downloaded the file from the 'files' section and hope it is > > > close to the 1978 step control. My step retracts but doesn't > extend. > > > This weekend I plan to try to get it working. Has anyone out there > > > worked with a 1978 step? Is ti the same wiring as the one in the > Files > > > section? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > --------------------------------- All new Yahoo! Mail --------------------------------- Get news delivered. Enjoy RSS feeds right on your Mail page. [Non-text portions of this message have been removed] |
08-18-2006, 11:25
1978 air srep
Hey Gary,
What's up with my computer and Yahoo??? Looks like stuttering ![]() Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > Pete, > > Thanks for the warning. I am not new to mechanical things, but > > sometimes I can be inatentive and shortsighted. What I plan to do > is > > disconnect the piston and work from there. That means I need to > push > > the step in and out to activate the right switches at the right > > stage, but I will save my head, fingers, etc! > > > > Gardner > > 78FC33 > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > wrote: > > > > > > Gardner, > > > > > > The air step is very dangerous to work on. Be aware of your > body > > > parts (particularly your head) when working on wiring/switches/ > > > valves, etc. located near the operating mechanism. The air step > > can > > > extend or retract without warning. We want you to be a long- term > > BB > > > owner! > > > > > > Pete Masterson > > > aeonix1@ > > > '95 Bluebird Wanderlodge WBDA 4203 > > > El Sobrante, CA > > > > > > > > > > > > > > > On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > > > > > > > I have downloaded the file from the 'files' section and hope > it is > > > > close to the 1978 step control. My step retracts but doesn't > > extend. > > > > This weekend I plan to try to get it working. Has anyone out > there > > > > worked with a 1978 step? Is ti the same wiring as the one in > the > > Files > > > > section? > > > > > > > > Gardner > > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
08-19-2006, 12:46
1978 air srep
Bill,
I'll send a fax number Monday when I am at work to pick it up. I found lots of other things to work on this weekend anyway. Gardner 78FC33 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Wilhelmus Schreurs Sent: Friday, August 18, 2006 7:17 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: 1978 air srep Gardner: I have redrawn my wiring diagrams to schematics, and I only have one relay to work with, not the 4 like on the SP. Eventually if all goes well I will download them into the files section as well. If you got fax number I can fax you the one I have redrawn. Bill 84FC35SB Terrace, B.C. pattypape < billpatty@... --- In WanderlodgeForum@yahoogroups.com wrote: > > Pete, > Thanks for the warning. I am not new to mechanical things, but > sometimes I can be inatentive and shortsighted. What I plan to do is > disconnect the piston and work from there. That means I need to push > the step in and out to activate the right switches at the right > stage, but I will save my head, fingers, etc! > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com > wrote: > > > > Gardner, > > > > The air step is very dangerous to work on. Be aware of your body > > parts (particularly your head) when working on wiring/switches/ > > valves, etc. located near the operating mechanism. The air step > can > > extend or retract without warning. We want you to be a long-term > BB > > owner! > > > > Pete Masterson > > aeonix1@ > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > > > > > > > > On Aug 17, 2006, at 7:21 PM, Gardner Yeaw wrote: > > > > > I have downloaded the file from the 'files' section and hope it is > > > close to the 1978 step control. My step retracts but doesn't > extend. > > > This weekend I plan to try to get it working. Has anyone out there > > > worked with a 1978 step? Is ti the same wiring as the one in the > Files > > > section? > > > > > > Gardner > > > 78FC33 > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > --------------------------------- All new Yahoo! Mail --------------------------------- Get news delivered. Enjoy RSS feeds right on your Mail page. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
