E-Bay Wanderlodge
08-22-2006, 06:57
E-Bay Wanderlodge
Chris,
It is my understanding that it is not the same thing at all. In fact I'm sure
it is not. It is to control odors by passing a 12 volts charge through one of
two pairs of stainless steel electrodes within the holding tank. It oxidizes
the organics thus eliminating odors. When turned on it cycles on and off by
itself. Our bird has the same thing. But, I don't know if it works. I don't
know how you would tell. I usually don't have odors in the coach and don't use
that feature.
Sent: Tuesday, August 22, 2006 11:10 AM
Subject: Re: [WanderlodgeForum] Re: E-Bay Wanderlodge
On my control panel in the kitchen on my 83FC35 it has a switch for "Waste
Odor Control"..
Any idea what that does?
Is that the same thing?
Richard Hayden > wrote:
My '81 FC didn't have one but it was listed as an option. I've never talked to
anyone who had one.
To:
WanderlodgeForum@yahoogroups.com :WanderlodgeForum@yahoogroups.com>
Sent: Tuesday, August 22, 2006 6:14 AM
Subject: [WanderlodgeForum] Re: E-Bay Wanderlodge
Never heard of this on a WL...I assume this was a "customer
modification" rather than something from the factory???
Scott
--- In
WanderlodgeForum@yahoogroups.com :WanderlodgeForum@yahoogroups.com>,
"Stephen Birtles"
> its called an incinolet one of the worst ever waste disposal systems
> installed in any mobile application
> we had them on Railway Engines and one of the neat things about it
was
> to start it after it was partially full and then leave the cab of
> engine. the resultant stench would just about kill the poor
engineer
> Stephen 77fc35 never ever push the button while moving
> --- In
"Scott Forman" <sforman@>
> > From the description:
> > "and the prize above all motor homes is the revolutionary method
of
> > incinerating sewer waste & converting one weeks waste into a
small
> > cup of ash dust that can be safety deposited in any garbage can."
> > Have I missed something?
> > Scott Forman
> > 82 FC35RB
> > Memphis
> > --- In
"Chris"
> > wrote:
> > > Came across this Wanderlodge on E-Bay..
> > > Item number 120023609811
> > > looks to have rolled over....
08-22-2006, 07:03
E-Bay Wanderlodge
Hi Chris,
The Waste Odor Control on your coach is nothing like the "Incinolet".
Your system (I had that on my '90) sends a minute electric current
through the waste tank to supposedly neutralize odors. It does not
eliminate waste. I believe that your owners manual states that the
Waste Odor Control works better if you add a little table salt to
the waste tank to make the contents more conductive.
The Incinolet actually burns the waste in a gas fired incinerator.
Another type of waste disposal (I can't remember the name) actually
macerated the waste and pumped it into the hot exhaust of the
vehicle. I haven't seen one of those in years but the Incinolet is
still used in camps, cabins, etc. where there is no septic system.
IMO, it is several steps better than the old outhouse, specially in
winter!
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, Chris Reed
for "Waste Odor Control"..
08-22-2006, 07:13
E-Bay Wanderlodge
It was lateral G's attempting to close the door, or,
"how fast can I take this off ramp", or, proof that
Blue Birds don't slide on dry pavement.
Bob
> that s not neagive Gs its lateral G's come on get it right
> Have a great Day
> Stephen 77fc35 whatever g's you measure
> --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor"
> > Chris, DavidB did that while showing JeffM frame effects of
negitive
> > G's.
> > GregoryO'Connor
> > 94ptRomolandCa
> > --- In WanderlodgeForum@yahoogroups.com, "Chris"
08-22-2006, 08:41
E-Bay Wanderlodge
I had one of these in a mid 70s Sportscoach. They were real proud of
it, as I recall that it was around a $2,500 option back then. Worked ok
I guess but did leave you thinking about what was happening all the time
it was running. Odor was always an issue too. You definitely only
wanted to turn it on while "underway". Pity the poor folks behind you.
Terry Neal
Bozeman, MT
82PT40
74FC34
> talked to anyone who had one.
> From: Scott Forman > >
com
> Scott
com
> >, "Stephen Birtles"
> was
> the
> engineer
com
> >, "Scott Forman" <sforman@>
> of
> small
> > > Scott Forman
> > > 82 FC35RB
> > > Memphis
com
> >, "Chris"
08-22-2006, 13:32
E-Bay Wanderlodge
I have a Waste Odor Switch also but have never used it. Truthfully, I've never
had a backflow odor problem since owning the bus(2+ years). I do not use odor
control additives or salt. My monitors work perfectly. I think I have
figured it out. The wife uses the washer so often that the black tank is as
clean inside as the outside of the bus. I know this sounds like BS , but it's
not a joke. If it isn't broke, don't fix it.
Leroy Eckert
1990 WB40
Niceville, FL
Sent: Tuesday, August 22, 2006 1:10 PM
Odor Control"..
anyone who had one.
Scott
--- In
"Stephen Birtles"
was
engineer
> --- In
of
small
> > Scott Forman
> > 82 FC35RB
> > Memphis
> > --- In
"Chris"
08-22-2006, 13:54
E-Bay Wanderlodge
Rich
the incinolet is an electric barbque incinerator have not seen a gas
one yet but they maybe out there
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote:
> Hi Chris,
> winter!
