HWH levelers
08-23-2006, 12:55
HWH levelers
I am having a problem with my HWH levelers in my '78 FC. The left
front one will lift the coach fine, but slowly drops down. There is no fluid leak, so I assume the valve is not holding properly. Can individual valves be replaced in the 4 lever control module, or does the entire module need to be rebuilt/replaced? Gardner 78FC33 |
08-23-2006, 13:35
HWH levelers
HWH services the valve body as a unit.
MH ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 23, 2006 7:55 PM Subject: [WanderlodgeForum] HWH levelers I am having a problem with my HWH levelers in my '78 FC. The left front one will lift the coach fine, but slowly drops down. There is no fluid leak, so I assume the valve is not holding properly. Can individual valves be replaced in the 4 lever control module, or does the entire module need to be rebuilt/replaced? Gardner 78FC33 [Non-text portions of this message have been removed] |
05-17-2008, 23:03
HWH levelers
If you are doing the work yourself....I just replaced one of my "Kick Down" cylinders (the small hydraulic cylinder on the side) a couple of months ago. HWH has a website, I e-mailed them and they had a technician call me. We chatted and I ordered a new cylinder. $230 ifI remember right. The do not offer repair parts. Itsounds as if that would not be an option for you if the cylinder broke in half. The new cylinder comes complete with O-rings and new interface parts. The new cylinder will include a spring and valve that your old one did not have. It installs in one of the crossover pieces. Ask them to includeextraO-rings asyou may need them when reinstalling.
Steve Anderson
79 FC 35
Poulsbo, Wa
In a message dated 5/18/2008 7:39:16 A.M. US Mountain Standard Time, share74@... writes:
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. |
05-18-2008, 02:01
HWH levelers
we are looking for info on the hwh levelers on our 83fc bird. on the
left front jack, the small cylinder snapped in two, more than likley from hanging down a bit. any ideas where to get another one?? pete & jan |
05-18-2008, 02:38
HWH levelers
Pete & Jan,
Call HWH, I had to replace mine as well on my 81 FC.
They will send you what you need! (800) 321-3494
Check out their website:
Stephen
On Sun, May 18, 2008 at 10:01 AM, racetrash <"racetrash@netzero.net"> wrote:
05-18-2008, 03:26
HWH levelers
I replaced an entire jack on my old FC with a rebuilt unit from HWH,
and I want to say I remember it not costing much more than the $230 mentioned here for the part, might just want to replace the whole unit. It is an easy swap. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, ebirder2000@... wrote: > > If you are doing the work yourself....I just replaced one of my "Kick Down" > cylinders (the small hydraulic cylinder on the side) a couple of months ago. > HWH has a website, I e-mailed them and they had a technician call me. We > chatted and I ordered a new cylinder. $230 if I remember right. The do not offer > repair parts. It sounds as if that would not be an option for you if the > cylinder broke in half. The new cylinder comes complete with O- rings and new > interface parts. The new cylinder will include a spring and valve that your old > one did not have. It installs in one of the crossover pieces. Ask them to > include extra O-rings as you may need them when reinstalling. > > Steve Anderson > 79 FC 35 > Poulsbo, Wa > > > In a message dated 5/18/2008 7:39:16 A.M. US Mountain Standard Time, > share74@... writes: > > > > > > Pete & Jan, > > Call HWH, I had to replace mine as well on my 81 FC. > > They will send you what you need! (800) 321-3494 > Check out their website: > _http://www.hwhcorp.http_ (http://www.hwhcorp.com/) > > > Stephen > > > On Sun, May 18, 2008 at 10:01 AM, racetrash <_racetrash@..._ > (mailto:racetrash@...) > wrote: > > > > > > we are looking for info on the hwh levelers on our 83fc bird. on the > left front jack, the small cylinder snapped in two, more than likley > from hanging down a bit. any ideas where to get another one?? > pete & jan > > > > > > > > > > > > > > > **************Wondering what's for Dinner Tonight? Get new twists on family > favorites at AOL Food. > (http://food.aol.com/dinner-tonight?NCID=...0000000001) > |
