Refilling Battery Cells- Help!
08-23-2006, 13:18
Does anyone have a good method for checking add refilling the coach
batteries? On my '99 LX, most of the batterries are mounted on a fixed shelf directly under the charger tray and the only way I have been able to access them is by disconnecting the cables and dragging them out one at a time. Even my previous SOB had a sliding tray. I guess if there is no other alternative, what are recommendations for a permanently installed water system? Thanks in advance. Wayne '99 LX Charlotte,NC |
08-23-2006, 13:33
Wayne,
I have '78 FC 33 which also does not have a sliding battery tray. I wonder if anyone out there has installed an after market tray to solve this issue? It would be a great project with the right components. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "wayhamm" wrote: > > Does anyone have a good method for checking add refilling the coach > batteries? On my '99 LX, most of the batterries are mounted on a fixed > shelf directly under the charger tray and the only way I have been > able to access them is by disconnecting the cables and dragging them > out one at a time. Even my previous SOB had a sliding tray. I guess if > there is no other alternative, what are recommendations for a > permanently installed water system? Thanks in advance. > > Wayne > '99 LX > Charlotte,NC > |
08-23-2006, 13:46
I installed the "Qwik-Fill" battery watering system by "Flow-Rite" for filling
the four batterys in my FC slide out tray. The system replaces the original filler caps on the batterys with valved filler caps that are tied together with plastic tubing. All you have to do to refill all the battery cells to the right level is connect the supplied squeeze bulb to the filler tube and pump in distilled water until the valves all close off. System was a great improvement over manually filling each battery cell. System is available through Cabellas, Bass-Pro and other outlets. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, "wayhamm" > > Does anyone have a good method for checking add refilling the coach > batteries? On my '99 LX, most of the batterries are mounted on a fixed > shelf directly under the charger tray and the only way I have been > able to access them is by disconnecting the cables and dragging them > out one at a time. Even my previous SOB had a sliding tray. I guess if > there is no other alternative, what are recommendations for a > permanently installed water system? Thanks in advance. > > Wayne > '99 LX > Charlotte,NC > |
08-23-2006, 14:00
You can add a single point bateery watering system
it involves replacing all the caps and interconnecting all the caps with tubing then you add water at one point and it fills all the cells Let me know if you want any info on this sysstem. It works rather well and is probaly cheaper and less hassle than building a slide out tray Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "wayhamm" > > Does anyone have a good method for checking add refilling the coach > batteries? On my '99 LX, most of the batterries are mounted on a fixed > shelf directly under the charger tray and the only way I have been > able to access them is by disconnecting the cables and dragging them > out one at a time. Even my previous SOB had a sliding tray. I guess if > there is no other alternative, what are recommendations for a > permanently installed water system? Thanks in advance. > > Wayne > '99 LX > Charlotte,NC > |
08-23-2006, 14:15
or you can install an aquapro system from me
http://www.capeinnovation.com/singelpoint/ a much better system industrial strength Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > I installed the "Qwik-Fill" battery watering system by "Flow-Rite" for filling the four > batterys in my FC slide out tray. The system replaces the original filler caps on the > batterys with valved filler caps that are tied together with plastic tubing. All you have to > do to refill all the battery cells to the right level is connect the supplied squeeze bulb to > the filler tube and pump in distilled water until the valves all close off. System was a great > improvement over manually filling each battery cell. System is available through Cabellas, > Bass-Pro and other outlets. > > Regards, Eric in San Antonio > 84FC35SBWL2 > --- In WanderlodgeForum@yahoogroups.com, "wayhamm" > > > > Does anyone have a good method for checking add refilling the coach > > batteries? On my '99 LX, most of the batterries are mounted on a fixed > > shelf directly under the charger tray and the only way I have been > > able to access them is by disconnecting the cables and dragging them > > out one at a time. Even my previous SOB had a sliding tray. I guess if > > there is no other alternative, what are recommendations for a > > permanently installed water system? Thanks in advance. > > > > Wayne > > '99 LX > > Charlotte,NC > > > |
08-23-2006, 15:19
Stephen,
You typeo'd your own url Try this one: http://www.capeinnovation.com/singlepoint/ sw 04 Essex http://www.rvsafetycandle.com ================ --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > You can add a single point bateery watering system > it involves replacing all the caps and interconnecting all the caps > with tubing then you add water at one point and it fills all the cells > Let me know if you want any info on this sysstem. > It works rather well and is probaly cheaper and less hassle than > building a slide out tray > Stephen 77fc35 > > > > --- In WanderlodgeForum@yahoogroups.com, "wayhamm" > > > > Does anyone have a good method for checking add refilling the coach > > batteries? On my '99 LX, most of the batterries are mounted on a fixed > > shelf directly under the charger tray and the only way I have been > > able to access them is by disconnecting the cables and dragging them > > out one at a time. Even my previous SOB had a sliding tray. I guess if > > there is no other alternative, what are recommendations for a > > permanently installed water system? Thanks in advance. > > > > Wayne > > '99 LX > > Charlotte,NC > > > |
08-23-2006, 16:02
Wayne,
We installed an aquapro system on ToWanda that we purchased from Steve. Not difficult to install and it works like a dream. Makes quick work of battery maintenance and it was money well spent. Thanks Steve! Ken & Patti Marsh Mpls ~ Keepin' our eye on the prize Full-timing as of March '07 - only 32 weeks to go! ToWanda'89WLWB40ft ![]() Stephen Birtles or you can install an aquapro system from me http://www.capeinnovation.com/singelpoint/ a much better system industrial strength Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Eric Johnson" wrote: > > I installed the "Qwik-Fill" battery watering system by "Flow-Rite" for filling the four > batterys in my FC slide out tray. The system replaces the original filler caps on the > batterys with valved filler caps that are tied together with plastic tubing. All you have to > do to refill all the battery cells to the right level is connect the supplied squeeze bulb to > the filler tube and pump in distilled water until the valves all close off. System was a great > improvement over manually filling each battery cell. System is available through Cabellas, > Bass-Pro and other outlets. > > Regards, Eric in San Antonio > 84FC35SBWL2 > --- In WanderlodgeForum@yahoogroups.com, "wayhamm" > > > > Does anyone have a good method for checking add refilling the coach > > batteries? On my '99 LX, most of the batterries are mounted on a fixed > > shelf directly under the charger tray and the only way I have been > > able to access them is by disconnecting the cables and dragging them > > out one at a time. Even my previous SOB had a sliding tray. I guess if > > there is no other alternative, what are recommendations for a > > permanently installed water system? Thanks in advance. > > > > Wayne > > '99 LX > > Charlotte,NC > > > [Non-text portions of this message have been removed] |
08-23-2006, 19:29
aw crap can't even type my own name
thanks for correcting it Stepehehen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Scott Williams" <swilliams@...> wrote: > > Stephen, > > You typeo'd your own url > > Try this one: > > http://www.capeinnovation.com/singlepoint/ > > sw > 04 Essex > http://www.rvsafetycandle.com > ================ > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > You can add a single point bateery watering system > > it involves replacing all the caps and interconnecting all the caps > > with tubing then you add water at one point and it fills all the cells > > Let me know if you want any info on this sysstem. > > It works rather well and is probaly cheaper and less hassle than > > building a slide out tray > > Stephen 77fc35 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "wayhamm" > > > > > > Does anyone have a good method for checking add refilling the coach > > > batteries? On my '99 LX, most of the batterries are mounted on a fixed > > > shelf directly under the charger tray and the only way I have been > > > able to access them is by disconnecting the cables and dragging them > > > out one at a time. Even my previous SOB had a sliding tray. I guess if > > > there is no other alternative, what are recommendations for a > > > permanently installed water system? Thanks in advance. > > > > > > Wayne > > > '99 LX > > > Charlotte,NC > > > > > > |
08-23-2006, 20:33
I saw Ralph install one of those systems on a coach and it really is a great
system. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
