Toad wiring
08-27-2006, 13:53
Toad wiring
Bill,
I forgot to mention: The SMI only monitors the toad brake signal at the
switch on the pedal and uses this to activate the transmitter to signal the
receiver in the coach that the brakes are applied. As long as the coach
brake voltage is not fed back into the line, the SMI signaling will not be
effected. The SMI does need to see the coach brake voltage on a specific
pair of wires to work, but that can be tapped off the coach signal prior to
the relays I mentioned in the previous post.
Gardner
78FC33
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of pattypape
Sent: Sunday, August 27, 2006 9:45 AM
Subject: [WanderlodgeForum] Re: Toad wiring
Gardner, Curt,
We have a 2001 Jeep Cherokee.
Found the Cherokee tail light/stop light wires and
spliced in two DPDT switches, This method uses the existing Jeep
lights and sockets. Switches are UP for Bird towing, DOWN for Jeep
Driving. The Jeep tail lights are used for turn signals, hazards,
and stop lights. No need for diodes, But I must remember to throw
the manual switches. Easy to install.
I do not know if this works with the SMI.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com
, "Gardner Yeaw"
> I have my SMI brake system installed, by Blue ox tow bar, my Blue
Ox
> tow bar base for my 1995 Jeep Cherokee Sport. Now to the wiring of
> the lights. It seems I have no choice but to use separate lights
for
> the turn signals since the SMI will activate the normal brake
light
> circuit in the toad, so I will not be able indicate a turn when
> SMI is active. I believe I will also need to use diodes at the
brake
> lights so the lights work with both the RV and the toad brake
> lighting without feeding back into either vehicle.
> Also, dumb question: Does the 78FC use the same lights for the
> brakes and turn signals? Mine is at the storage facility and I
> completely forgot to check this when I was there.
> Has anyone out there had experience with this and can you add
any
> comments to what my observations.
> Thanks
> Gardner
> 78FC33
