Bendix cruise control on mid 80s PT
09-09-2006, 07:04
Does anyone know where the cruise control off/on switch picks up 12
volts dc? I read only 11.6 volts at the switch and the batteries are
on float at 13.6 or so. The cc worked when last I drove the coach, the
end of July, and wouldn't set at all yesterday.
09-09-2006, 07:55
Also, where is the speed sensor located? I'm trying to check it's ground.
Looks like there are 2 grounds in this system, one at the control module and the
other at the speed sensor.
Thanx
Sent: Saturday, September 09, 2006 12:04 PM
Subject: [WanderlodgeForum] Bendix cruise control on mid 80s PT
09-10-2006, 14:38
Hi Dick,
Check the right rear double tires on the inside. You should find it
there. I had occasional cutouts on my cruise also. Turned out the very
thin wires on the speed sensor were almost cut in half. Easy fix.
Will be seening you at the Hood Canal rally in Oct.
Bob Lawrence
84 PT36
Tacky Tacoma, Wa.
ground. Looks like there are 2 grounds in this system, one at the
control module and the other at the speed sensor.
> Thanx
