Source for cruise control vacuum generator?
09-11-2006, 02:50
Anyone know a source for the cruise control vacuum generator on an 82
FC 35? I called Bluebird and they don't carry them. Their parts
department had no idea where I might get one. They seemed to think the
vacuum generator came from Ford. Tom Warner posted 3-G Productions,
but while they rebuild Bendix cruise controls, they don't carry vacuum
generators.
If you don't know a source for the generator, can you tell me what the
two output lines on the generator are for? Are they both vacuum
lines? If I can't find an identical replacement I may have to put
something together and I need to know if I need two vacuum outputs or
something else.
My bus needs to suck again.
Kerry
82 FC 35
Denver
09-11-2006, 06:25
Found these vacuum generators on the internet. Anyone care to express
an opinion as to whether they would work as a substitute for the
original vacuum generator on an early 80's FC?
http://www.anver.com/document/vacuum%20c...-jv.h\
tm
Kerry
82 FC35--that doesn't suck at the moment
Denver
09-19-2006, 21:48
Kerry,
There was a forum update offering a generator in the last 10 days or so.
Do a search you may find it.
Gardner
78FC33
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of davidkerryedwards
Sent: Monday, September 11, 2006 10:50 AM
Subject: [WanderlodgeForum] Source for cruise control vacuum generator?
generators.
something else.
Kerry
82 FC 35
Denver
09-20-2006, 02:23
Thanks. I saw the offer for an electric vacuum pump. After giving it more
thought, I think
the best course of action is to replace the vacuum cruise control with a Rostas
Global cruise
which is electronic. The existing vacuum control was not working consistently
and when I
looked thru the bluebox, I saw that the original owner had taken it back to
Bluebird a number
of times for problems. So, since other members have had success with the
Rostas, I think the
best course of action is to eliminate the need for any vacuum at all.
Kerry
82 FC 35--not sucking anymore
Denver
