City water hook up 79 FC
09-20-2006, 11:49
Hi Guys Where is the check valve for the city water hook on a 79 FC
33' ? There is no pressure on the city side of the hook up. The pump has
pressure. This is not my Bird. Its a friends & I'm ont near it. Thanks
Don
89 SP 36'
Butler, PA
09-20-2006, 16:36
Don,
I'm not sure...I know nothing about a check valve...is there a tank fill
switch near the shore hose hookup? That switch could be in the wrong
position. That's how it works on our '87.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
>Don
>89 SP 36'
>Butler, PA
>Yahoo! Groups Links
09-20-2006, 17:09
Don, on my 83 the check valve is right at the water connection. I think that
some of the earlier models had separate connections for city water bypass and
fill. In either case the city water bypass connection has to have a
built-in/attached check valve to keep water from flowing out the connection.
My water connection is at the rear driver's side. Since I have a rear bath it
is in the compartment with the water heater.
Bruce Morris (919)872-7635 Raleigh, NC
Webmaster - WOO (http://www.wanderlodge.us)
1983 WL FC35RB
FMCA: 7142s Ham Radio: KI4ME
Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv
Sent: Wednesday, September 20, 2006 11:49 PM
Subject: [WanderlodgeForum] City water hook up 79 FC
Don
89 SP 36'
Butler, PA
09-20-2006, 20:27
Curt The 79 FC has two fill places one for the tank & one for the city
water. No switch that I know of. My 89 SP has the switch.
Don,
>Don
>89 SP 36'
>Butler, PA
>Yahoo! Groups Links
09-20-2006, 21:00
Bruce This one has the separate fill & city connections. I didn't know if
it had a sporlan valve besides the one in the city hook up.
Thanks Don
89 SP 36'
Butler, PA
and fill. In either case the city water bypass connection has to have a
it is in the compartment with the water heater.
Webmaster - WOO (http://www.wanderlodge.Webm
1983 WL FC35RB
09-20-2006, 22:42
David
Thanks that what I thought. Don
Don,
On the 78 I had, it had the 2 connections and no Sporlan valve
anywhere on the whole coach.
David Hollis 84 FC35 Springfield,Da
--- In _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) , dspithaler@., dsp
09-21-2006, 01:28
Don,
David Hollis 84 FC35 Springfield,IL
didn't know if
> Thanks Don
> 89 SP 36'
> Butler, PA
09-21-2006, 12:39
Don, if you have separate connections there is no need for a sporlan valve to
direct the water flow. You may have other sporlan valves, but not one to direct
water to fill the tank. Also both water connections should have a check valve
either built in or right behind the water connection.
1983 WL FC35RB
Sent: Thursday, September 21, 2006 9:00 AM
Subject: Re: [WanderlodgeForum] City water hook up 79 FC
Thanks Don
89 SP 36'
Butler, PA
1983 WL FC35RB
09-21-2006, 13:48
I believe that check valve is mounted on or near the hot water tank under the
bed. Rear Corner.
Steve Anderson
79FC 35
Poulsbo Wa
-----Original Message-----
Sent: Wed, 20 Sep 2006 8:49 PM
Don
89 SP 36'
Butler, PA
________________________________________________________________________
Check out the new AOL. Most comprehensive set of free safety and security
tools, free access to millions of high-quality videos from across the web, free
AOL Mail and more.
