Water leak...
10-17-2006, 13:02
Water leak...
First of all I want to thank everyone for the replies...all were very
helpful! I got the spoiler off and am in the process of cleaning off
the sealant that was between it and the roof. I agree that it is
probably un-necessary to seal all the way around the spoiler. I think
when I replace it I will mainly just seal around where the screws
enter the roof.
Rob, I found that Home Depot had a Butyl sealant. It Dap Butyl-Flex
rubber sealant. It says Gutter & Flashing on the tube. It was about
$3.50 for the 10oz. tube. McCoys hardware had the NP-1 as well.
Thanks again everyone,
John C
--- In WanderlodgeForum@yahoogroups.com, David Brady wrote:
> Rob,
> Where do you buy Buytal? I did some internet searches
> an the best I can come up with is ebay.
> Thanks,
> David B
> '02 LXi, Smokey
> Va
> Rob Robinson wrote:
> > John I would seal the individual mounting holes with Urethane or
Buytal. If
> > the mounting holes in the fiberglass cap have small radiating
stress cracks
> > you could use a self-leveling sealant like Dicor 501 lap sealant
or Sikoflex
10-18-2006, 04:29
Water leak...
Check with any major builders supply house or professional painters supply. They
should have a number of different sealants and someone on staff should be able
to recommend the proper product.
Alex Smith
Tallahassee
82FC35
Stephen Birtles wrote:
search on butyl sealant
some canajuns cantspel
Stephen 77fc35 have a great day rob
> Rob,
> Thanks,
> David B
> '02 LXi, Smokey
> Va
Buytal. If
stress cracks
or Sikoflex
How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
10-18-2006, 12:36
Water leak...
David I have bought butyl tape at paint and body shop suppliers. It is
usually used to seal windshields. I believe you can buy it in both tape and
liquid form. I use the tape and pull small pieces off and wind them around
each SS lag screw I put into a roof.
> supply. They should have a number of different sealants and someone on staff
> should be able to recommend the proper product.
> Alex Smith
> Tallahassee
> 82FC35
> David Brady wrote:
> > Rob,
> > Thanks,
> > David B
> > '02 LXi, Smokey
> > Va
> Buytal. If
> stress cracks
> or Sikoflex
> How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call
> rates.
Rob, Sue & Merlin Robinson
94 WLWB
10-18-2006, 13:05
Water leak...
I just wanted to update my situation. I ended up pulling off the
spoiler and cleaning up everything as well as possible. I used the
NP-1 around all the screws to reattach the spoiler. I wish I had been
able to get it done a little earlier, but it had about 4 or 5 hours of
sunny hot weather to cure before it started pouring rain again. Went
inside and so far everything was still dry as a chip! I just hope that
was long enough for the NP1 to cure. Thanks again for all the replies
and help.
John C
98 Wanderlodge LX
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
tape and
around
someone on staff
> > Alex Smith
> > Tallahassee
> > 82FC35
> > --- In
> > David Brady wrote:
> > > Rob,
> > > Thanks,
> > > David B
> > > '02 LXi, Smokey
> > > Va
> > Buytal. If
> > stress cracks
> > or Sikoflex
> > rates.
> 94 WLWB
10-18-2006, 14:59
Water leak...
John,
I use NP-1 daily. It's nasty @#$% but it works. If it was applied on a dry
substrate metal or otherwise you should be OK. I wouldn't think rain would
effect it after 5 hours.
Leroy Eckert
1990 WB-40
Niceville, FL
Side note. I used NP-1 to apply the polished stainless upgrade on my coach about
1 year ago. It is still there.
Sent: Wednesday, October 18, 2006 8:05 PM
Subject: [WanderlodgeForum] Re: Water leak...
and help.
John C
98 Wanderlodge LX
tape and
around
someone on staff
> > Alex Smith
> > Tallahassee
> > 82FC35
> > --- In
> > David Brady wrote:
> > > Rob,
> > > Thanks,
> > > David B
> > > '02 LXi, Smokey
> > > Va
> > Buytal. If
> > stress cracks
> > or Sikoflex
> > rates.
> 94 WLWB
