Turbo whistle?
10-23-2006, 10:22
Turbo whistle?
How come my turbo doesn't whistle like most big turbodiesels? Is this
a 3208 thing or do I have a problem? Everything runs fine.... Scott Forman 82 FC35RB 225 hp turbo Memphis |
10-23-2006, 12:27
Turbo whistle?
I believe it's because of heavier gauge and short pipes associated
with the turbo on the older 3208's. The 'whistle' you hear on the bigger engines, and the 3208 ATAAC engine are likely because of thinner walled turbo pipes and especially aftercooler piping. I couldn't hear my turbo very well until I had silenced the engine noise enough. Now I hear it very faintly every now and then. Gary Miller 83 FC 33 Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > How come my turbo doesn't whistle like most big turbodiesels? Is this > a 3208 thing or do I have a problem? Everything runs fine.... > > Scott Forman > 82 FC35RB > 225 hp turbo > Memphis > |
10-23-2006, 12:34
Turbo whistle?
The 3208 has two exhaust feed ports and those that are up on turbo issues tell
me that is a problem. I paid a shop $1200 to a shop to "modify" a turbo charger for me. Net result was nada. Next step bought a big Schweitzer like they use for the 300 hp Cats. ( $2000) No improvement so I upgraded the nozzles to 375 hp marine spec ($800) and that helped a little. The intake pressure was only 12 or 13 #s. I came across a part number for a generator/water pump application, only 165 hp spec. Paid out another $2000 and this time it was a good investment. 16 #s and great low end performance. Another improvement was the installation of a thermal blanket kit that covers all the exhaust system and turbo and down pipe. Really works well now, but most folks don't want to spend the dinero to get there. Picking up performance with a 3208 is a very hard road and it's best to leave them as they are. Small improvements are worth getting after like fuel system delivery enhancements and some claim improvements with propane injection. The air intake on your 225 could stand upsizing, in fact a new aircleaner arrangement would be a good thing, not a lot of money and worth pursuing. MH ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 23, 2006 5:22 PM Subject: [WanderlodgeForum] Turbo whistle? How come my turbo doesn't whistle like most big turbodiesels? Is this a 3208 thing or do I have a problem? Everything runs fine.... Scott Forman 82 FC35RB 225 hp turbo Memphis [Non-text portions of this message have been removed] |
10-24-2006, 00:50
Turbo whistle?
Has anybody added a pyrometer or boost guage to the instrument
cluster on these FC 225hp buses? I'd like to know what my turbo is up to but wasn't sure where to tap in for the gauges. Also would like to have a trans temp gauge. Thoughts? M Thomas Eastham Anitel Investments, LLC. 713-851-9693 thomase@... [Non-text portions of this message have been removed] |
10-24-2006, 04:42
Turbo whistle?
My FC has a auxiliary console on top of the CB, turbo pressure, EGT, trans temp
and air filter restriction gage. Looks like it was an original option. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: M Thomas Eastham To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, October 24, 2006 7:50 AM Subject: [WanderlodgeForum] Re: Turbo whistle? Has anybody added a pyrometer or boost guage to the instrument cluster on these FC 225hp buses? I'd like to know what my turbo is up to but wasn't sure where to tap in for the gauges. Also would like to have a trans temp gauge. Thoughts? M Thomas Eastham Anitel Investments, LLC. 713-851-9693 thomase@... [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-24-2006, 04:58
Turbo whistle?
Mine has a combo pyro/boost gauge installed on the top of the box
that the CB sits in on top of the dash. The gauge doesn't work, and even if it did, I would practically have to stand up and the helm to read it anyway. Scott 82 225 hp --- In WanderlodgeForum@yahoogroups.com, M Thomas Eastham > > Has anybody added a pyrometer or boost guage to the instrument > cluster on these FC 225hp buses? I'd like to know what my turbo is > up to but wasn't sure where to tap in for the gauges. Also would > like to have a trans temp gauge. > > Thoughts? > > > M Thomas Eastham > Anitel Investments, LLC. > 713-851-9693 > thomase@... > > > > > > [Non-text portions of this message have been removed] > |
10-24-2006, 11:15
Turbo whistle?
Hello Thomas,
I recently had a trans temp gauge installed on our coach by an Allison service shop when they replaced our leaking hoses between the transmission and the radiator. Total cost with labor was about $300. Now we will know if we're getting into the danger zone when we start pulling a mountain pass. I think it's worth the money. Cheaper than overhauling the tranny. We would like to add a turbo boost gauge since we have no indication at this time. For what it's worth I have heard turbo whistle we we've up around 2600-2700 rpm. Regards, Eric in San Antonio 84FC35SBWL2 --- In WanderlodgeForum@yahoogroups.com, M Thomas Eastham > > Has anybody added a pyrometer or boost guage to the instrument > cluster on these FC 225hp buses? I'd like to know what my turbo is > up to but wasn't sure where to tap in for the gauges. Also would > like to have a trans temp gauge. > > Thoughts? > > > M Thomas Eastham > Anitel Investments, LLC. > 713-851-9693 > thomase@... > > > > > > [Non-text portions of this message have been removed] > |
