Air Drier installation
10-30-2006, 11:23
My bird did not come with an air drier. I decided to install one and
purchased a Meritor-Wabco air drier to install, due to the small size, weight, and easy spin-on cartridge. I figured at this same time, I would go ahead and replace the compressor D-2 Governor and compressor filter. The D-2 control port (cutout) is 1/8" NPT, The Air Drier Port 4 (control) is 1/4" - 18 NPTF. Here is my question. What type of hose/tubing would be suitabile for connection from my governor to my drier; and what recommended size? Where would I get this tubing? I can work out the connections with adapters, I understand that. Im just not sure about tubing. I would assume it would be a black plastic tubing. I have serched e-bay for tubing, but it is difficult when I dont know what type to serch for. NEXT- I will need to connect my drier to the wet tank. The connection on the drier says: Port 21 (delivery): 1/2" - 14 NPTF. I have seen the existing braided stainless line coming from the compressor going to wet tank now. Would just need a short peice to go from drier to wet tank; what about this line? Does it need to be stainless braided as well? What type/size? E-bay? It's easier for me to shop online, than to take time away from work to drive around and look for this stuff! Thanks all for your help! Getting the old bird ready to drive to Ft- Desoto Park for Thanksgiving!! Stephen H. 81 FC-33SB Plant City, FL |
