Microwave/Convection Oven
11-07-2006, 09:03
Hank: I used Sharp R-1874 Carousel Stainless. Opening 30" wide.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Sunday, November 05, 2006 8:35 PM
Subject: [WanderlodgeForum] Re: Microwave/Convection Oven
---no rush Leroy, as I will be in Australia for a few months....but
thanks for your reply. It is Monday 2pm here in Sydney...will
leave for MELBOURNE on Thursday.
Thanks MATE!
LOL
Hank Hannigan
90SP36 with a great ZF transmission!
In WanderlodgeForum@yahoogroups.com, "Leroy Eckert"
> Hank:
> I'll send you the model number I used and the dimensions, then you
can decide. I replaced the black original with stainless. Will try
to do that tomorrow.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: birdshill123
> Sent: Sunday, November 05, 2006 5:38 PM
> Hank: If technology allows microwaves to be sent via email I
want one
> too!!!!!
> Bruce
> 1988 FC35
11-07-2006, 09:13
---Leroy:
My 90SP has approx 24 and 5/8 opening..thanks anyway......I'll get
something when I return from Australia in the Spring.
LOL
Hank Hannigan
90SP36
80FC31 for sale in the Spring..maybe..
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Henry Jay Hannigan
months....but
> Thanks MATE!
> LOL
> Hank Hannigan
> > Hank:
you
try
> > Leroy Eckert
> > 1990 WB-40
> > Niceville, FL
> > From: birdshill123
> want one
> > too!!!!!
> > Bruce
> > 1988 FC35
11-07-2006, 12:14
Speaking of micros, last night mine died while wife was cooking my
turkey legs...we have an 84 PT36...the Sharp is mounted in its own
cabinet...what's holding it in? Can I just pull it out without
damage to cabinet? Anybody done this to an 84?
Bob Lawrence
84 PT36
Tacoma, Wa.
> Leroy, The dimensions of the Sharp I removed are 24 5/8(w) x 15
3/4
> (h) x 18 3/4 (d). I believe the model number was R8580A. Thanks
> for your help. Mike McMahan
> > From: Mike McMahan
> > Sent: Wednesday, November 01, 2006 5:51 PM
> > Subject: [WanderlodgeForum] Microwave/Convection Oven
> > Well the original Sharp Microwave/Convection Oven in my 1989
> PT40
> > finally died. It is a Model R8580A. I remember several of you
> have
> > replaced yours and I was checking to see if any of you could
> tell me
> > what later model units would fit well in the built in space in
> the
> > bird. I was told that a Sharp R930 was close but I wanted to
> check
> > with the group. Thanks, Mike McMahan 1989 PT Counting the days
> until
> > leaving for South Padre Island for Christmas break
11-08-2006, 01:47
Bob: My Sharp hangs above the stove in the overhead cabinet. The original had
2 mount bolts on the top near the front of the unit which required me to remove
the tank monitor panel to access. These bolts were installed through a
horizontal wood plate. The new installation had bolts from the lower front of
the unit to the top of the wall mount plate on a 45 degree angle. In both cases
the lower rear of the unit rested on a lip in the wall mount bracket which
allowed the unit to be rotated up to its final position. The unit was placed on
the lip at about 45 degrees and the front rotated up. Reverse the order for
removal. Note: The wall mount bracket contained about 60 screws. I guess BB
did not want it t move.
Hope this helps.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Tuesday, November 07, 2006 6:14 PM
Bob Lawrence
84 PT36
Tacoma, Wa.
3/4
> > From: Mike McMahan
> PT40
> have
> tell me
> the
> check
> until
11-08-2006, 16:14
Hi Leroy,
Thanks for the reply...but..mine doesn't have any of that..I can see
4 feet but don't see any bolts thru the bottom of the stainless.
Looks like yours is a lot different than mine.
Bob
original had 2 mount bolts on the top near the front of the unit
which required me to remove the tank monitor panel to access. These
bolts were installed through a horizontal wood plate. The new
installation had bolts from the lower front of the unit to the top
of the wall mount plate on a 45 degree angle. In both cases the
which allowed the unit to be rotated up to its final position. The
unit was placed on the lip at about 45 degrees and the front rotated
up. Reverse the order for removal. Note: The wall mount bracket
contained about 60 screws. I guess BB did not want it t move.
> Hope this helps.
> Leroy Eckert
> 1990 WB-40
> Niceville, FL
> From: Bob Lawrence
my
own
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
15
> 3/4
Thanks
> > > From: Mike McMahan
> > PT40
you
> > have
> > tell me
in
> > the
> > check
days
> > until
