Drawers don't stay shut!
11-15-2006, 09:20
John, I have had the same recurrent problem. They do adjust and it seems to
be a trial and error method- aka-drive a little and do an adjustment. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
11-15-2006, 13:56
The drawers in the front of our 1982 PT-40 won't stay closed, and
neither will several other drawers that use that same latching mechanism. Does anyone have a cure? Replace the latches or the striker bar? Or can they be bent or adjusted back to where they will hold? --PirateJohn-- http://www.PirateJohn.com (a/k/a John W. Glmer) Jacksonville, FL |
11-16-2006, 11:23
Pirate John:
My drawer locks(really not locks) just a securing mechanism are on the back of the drawer. The one on the drawer is diamond shaped and goes inside a roller type locking receptor and locks in when over center. I have also found that both locking pins on the front of the slide must be fully engaged for the slide to lock in. I have spread the diamond piece out some to widen it, hence a tighter lock. I hope this helps. Do not have any idea if yours are the same. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 15, 2006 7:56 PM Subject: [WanderlodgeForum] Drawers don't stay shut! The drawers in the front of our 1982 PT-40 won't stay closed, and neither will several other drawers that use that same latching mechanism. Does anyone have a cure? Replace the latches or the striker bar? Or can they be bent or adjusted back to where they will hold? --PirateJohn-- http://www.PirateJohn.com (a/k/a John W. Glmer) Jacksonville, FL [Non-text portions of this message have been removed] |
