Treasure hunting in Pokeys safe.
12-07-2006, 15:10
So if it is above zero this weekend, I have palns to extracate the
safe from Pokey and cut into the back so I can retrieve the millions that are hidden in there, then I can retrofit that 500 H.P. Cat that Pokey has been dreaming about. I took a quick look today and it looks like I have to remove the dinette to get the safe out...is this the case? If not, how do I get the rascal out. Doug Engel, Gunnison, Co., 1981 FC35SB "Pokey" |
12-07-2006, 20:09
Doug- if your safe is like my other 2- it is bolted to the floor from inside
the safe. Good luck, Ernie-83pt40 in Tx [Non-text portions of this message have been removed] |
12-08-2006, 10:23
Gary Miller has a method, removing the dinette and hole-sawing a hole
in the safe. At that point you can remove the bolts (inside) to work on it. The plate must be removed from the back of the head/door (two screws), then the combination can be found by turning slowly and watching the plates with a mirror. With the safe removed it is fairly cheap or easy to weld the hole closed again. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "doug_ngl" wrote: > > So if it is above zero this weekend, I have palns to extracate the > safe from Pokey and cut into the back so I can retrieve the millions > that are hidden in there, then I can retrofit that 500 H.P. Cat that > Pokey has been dreaming about. I took a quick look today and it looks > like I have to remove the dinette to get the safe out...is this the > case? If not, how do I get the rascal out. Doug Engel, Gunnison, Co., > 1981 FC35SB "Pokey" > |
