Propane System Issue
02-07-2007, 13:59
Recently upon returning from a trip, I had my propane tank filled at a
FlyingJ and then left the coach in my storage building for a few days.
Today as I was packing to leave again, I find that I have no gas flow
to the inside of the coach. I can only conclude that a solenoid
activated cut-off valve is the reason. Is it possible that the propane
tank could have been over-pressured and possibly damaged the pressure
regulator ? However the gauge inside the coach reads 3/4 full as it
should. The gas detector located below the refrigerator appears to
have no power or is not working either. If anyone has any suggestions
or knows the location of the solenoid activated shut-off valve, I
would appreciate your input.
David Hanvy 89 WB PT40 Crosby, TX
02-07-2007, 14:08
David, i have had to take apart my gas detector, as there had been some
lint/dirt buildup in there. Once I blew that out and hit the reset button,
everything worked. Also, could the attendant that filled your tank, manually
shut the main valve off?
83PT40
Livingston,Montana
Sent: Wednesday, February 07, 2007 6:59 PM
Subject: [WanderlodgeForum] Propane System Issue
02-07-2007, 14:22
--- In WanderlodgeForum@yahoogroups.com, wrote:
>Ernie, Thanks for the quick reponse. I will take apart the gas
detector and look for issues. The manually operated valve is open.
(I hope to make it up to Montana this year and take in the sights.)
some lint/dirt buildup in there. Once I blew that out and hit the
reset button, everything worked. Also, could the attendant that
filled your tank, manually shut the main valve off?
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: David Hanvy
filled at a
days.
flow
propane
pressure
it
to
suggestions
I
02-07-2007, 14:43
Dave,
The propane detector under the frig needs power, it also controlls
the auto propane solenoid shut off switch, Try turning on the
electronic master switch , our switch is located in the overhead
storage near the load center.
Bill 88 FC
--- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@...>
been
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: David Hanvy
> filled at a
few
> days.
gas
> flow
> propane
> pressure
as
> it
> to
> suggestions
> I
02-07-2007, 15:00
David- lots to see and do here in Montana. cheap campground at the fairgrounds
here in Livingston
83PT40
Livingston,Montana- 75 feet away from the Yellowstone river
Sent: Wednesday, February 07, 2007 7:22 PM
Subject: [WanderlodgeForum] Re: Propane System Issue
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: David Hanvy
filled at a
days.
flow
propane
pressure
it
to
suggestions
I
02-07-2007, 15:43
--- In WanderlodgeForum@yahoogroups.com, "pattypape"
>Bill, Thanks for that info. I had already tried turning the
electronic master switch off and back on. May I conclude from your
response that if the LP detector has totally failed, that if will
activate the solenoid shut-down switch ?
> Dave,
> Bill 88 FC
> --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@>
open.
sights.)
> been
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston,Montana
> > > From: David Hanvy
> > filled at a
> few
> > days.
> gas
> > flow
solenoid
> > propane
> > pressure
full
> as
> > it
appears
> > to
> > suggestions
valve,
> > I
02-07-2007, 17:06
Dave, dont rule out that the auto shutdown feature is working and
there is infact a leak. I learned that the manual tank valve must be
fully opened or fully closed to seat proper. My 94 needs 110
electric via inverter or other source for the stove to light. I dont
know if the dash mounted AT switch will shut down the gas but it is
worth a look. Hope it does not stand in the way of your trip
94ptRomolandCA
> Dave,
> Bill 88 FC
open.
sights.)
> been
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston,Montana
> > > From: David Hanvy
> > filled at a
> few
> > days.
> gas
> > flow
solenoid
> > propane
> > pressure
> as
> > it
appears
> > to
> > suggestions
valve,
> > I
02-08-2007, 01:52
Hi Dave,
I am mostly familiar with our 88 FC, But some of the electrical
drawings that I have do refer to a PT. As you probably already know
Propane is dangerous and can explode and kill. And your tank is full.
So if you want to continue, Check that the master shut off and the
electronic master switches are turned ON.
I have one, two stage pressure regulator, some BB's have more than
one regulator, so check the propane at all appliances, such as:
stove, all heaters and refrig etc. If all propane is shut off ,
again check the main manual shut off valve. Rotate it again ON/OFF/On.
If still no propane, I would then suspect the auto propane detector
shut down. It should have a test button, with a light and an alarm.
Find the shut off solenoid. It is easy to hear and feel the magnetic
solenoid activate when the power is applied to the propane detector.
If you decide that the auto shut off is defective.
You could try to apply 12volt DC directly to the terminals of the
solenoid. This is not a good practice, but for a momentary test,
this may isolate your problem. The solenoid needs 12 volts to open,
then the circuit drops this voltage to about 4 to 8 volt to hold it
open, So again it is not a good idea to keep 12 volts on the
solenoid for a longer period of time.
For more information check the CCI Controls web site .
http://www.ccicontrols.com
or
http://www.ccicontrols.com/7719%20Instru...200704.pdf
Bill 88 FC
> > Dave,
controlls
> > Bill 88 FC
> open.
> sights.)
> > been
> the
that
> > > > Ernie Ekberg
> > > > 83PT40
> > > > Livingston,Montana
> > > > From: David Hanvy
> > > filled at a
a
> > few
> > > days.
no
> > gas
> > > flow
> solenoid
> the
> > > propane
> > > pressure
> full
> > as
> > > it
> appears
> > > to
> > > suggestions
> valve,
> > > I
02-08-2007, 03:56
Greg, Thanks. I have determined that there is no power coming to the
LP leak detector. I pulled it out and ran power to it directly from
the battery and it will light up. This seems to lead me back to a
failed part in the LP system. David Hanvy 89WB PT40 Crosby Tx
be
dont
is
> Gregory O'Connor
> 94ptRomolandCA
> > Dave,
controlls
> > Bill 88 FC
gas
> open.
> sights.)
had
> > been
that
> > > > Ernie Ekberg
> > > > 83PT40
> > > > Livingston,Montana
> > > > From: David Hanvy
> > > filled at a
a
> > few
> > > days.
no
> > gas
> > > flow
> solenoid
> the
> > > propane
> > > pressure
full
> > as
> > > it
> appears
> > > to
> > > suggestions
> valve,
> > > I
02-08-2007, 07:03
Hi Bill, I have determined that there is no power to the detector. I
pulled it out and applied power to the unit direct from the battery
and it lights up. Now I need to find the incoming power source to
the gas detector. I have a call in to Wanderlodge but I plan to
check the CCI Controls web site.
David 89 WB
> Hi Dave,
know
full.
ON/OFF/On.
detector
alarm.
magnetic
detector.
defective.
open,
it
> or
> Bill 88 FC
your
will
> > > Dave,
> controlls
overhead
> > > Bill 88 FC
<shanvy@>
gas
> > open.
> > sights.)
had
> > > been
hit
> > the
> that
> > > > > Ernie Ekberg
> > > > > 83PT40
> > > > > Livingston,Montana
> > > > > From: David Hanvy
tank
> > > > filled at a
for
> a
> > > few
> > > > days.
have
> no
> > > gas
> > > > flow
> > solenoid
that
> > the
> > > > propane
> the
> > > > pressure
> > full
> > > as
> > > > it
> > appears
> > > > to
any
> > > > suggestions
> > valve,
> > > > I
