Blue Thunder Lives Again!
02-14-2007, 10:37
As you can see at
http://www.arcatapet.net/travel/bluebirds/newlogo.jpg
Blue Thunder now has her identity back.
I had planned to have it done by my regular graphics guy when we returned to
Eureka in a couple of weeks, but the opportunity arose earlier than that, so I
got it done.
Vinyl graphics made by Too Crazy Ladies at the Gypsy Journal rally in Casa
Grande, AZ. Applied with minimal bubbles by yours truly.
Don Bradner
90 PT40 "Blue Thunder"
02-14-2007, 11:20
Looks great Don. You probably know, but the secret to
applying vinyl bubble free is soapy water. Wet her down
with very dilute soapy water, apply the stickers, and squeegee
out the water with the edge of a rubber pad (the kind used
to apply bondo works well). Using this technique, the decals
can be moved around until just right and then adhered to
the body panel by squeezing out the soapy water.
David Brady
'02 LXi, Smokey
NC
Don Bradner wrote:
> As you can see at
got it done.
> Don Bradner
> Yahoo! Groups Links
02-14-2007, 11:21
I've done that with full decals, but I was leery of trying it with these fully
cut-out letters. You need to get good adherence of the letters before pulling
off the front layer, and trying to apply them removed from the front leads to
stretching.
I will see a few bubbles; I suspect only pros will otherwise.
Don Bradner
02-15-2007, 02:40
Don,
While things are still fresh take a needle, puncture your bubble and
carefully work
the air out (thats how the pros do it)
Steve
02-15-2007, 06:35
It looks good Don. You will be more recognizable now.
--- In WanderlodgeForum@yahoogroups.com, "Don Bradner" wrote:
> As you can see at
returned to Eureka in a couple of weeks, but the opportunity arose
earlier than that, so I got it done.
in Casa Grande, AZ. Applied with minimal bubbles by yours truly.
> Don Bradner
