Ultra-low sulfur diesel fuel affects lubrication
03-19-2007, 14:14
On another forum that I participate in someone found the following
article summarizing the wear that Ultra-Low Diesel has on diesel engines. "A lower wear score indicates better lubricity. Biodiesel has been tested at varying concentrations with No. 1 and No. 2 diesel fuels. The results indicate that a 1 percent blend of biodiesel with No. 2 diesels is sufficient to reduce the HFRR micron score below the required 460 micron standard. However, a 2 percent biodiesel blend is required in No. 1 diesel to get the HFRR micron score down to 460 microns." Link to the article http://www.farmandranchguide.com/article...roduction_ news/prod20.txt Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana |
03-19-2007, 15:49
The first diesel that Rudolf Diesel marketed, was designed to run on straight
vegetable oil, although the first diesel tested, ran on coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, to 80% Petrodiesel,(although Biodiesel is still illegal to use in the US due to epa regulations) The problem with Biodiesel is that it has a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used straight in cold weather, has to be preheated, in order to flow. the other concern would be that Biodiesel has more solvents, than Petrodiesel, which will disolve sludge that may be in the tank, so if one decides to go this route, plan on changing the filters frequently for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run one drop of that, without at least some form of lubrication additive, do to the fact, that it dosen't have enough Jimmy Harvie 82 FC Boston Ma Al someone found the following article summarizing the wear that Ultra-Low Diesel has on diesel engines. "A lower wear score indicates better lubricity. Biodiesel has been tested at varying concentrations with No. 1 and No. 2 diesel fuels. The results indicate that a 1 percent blend of biodiesel with No. 2 diesels is sufficient to reduce the HFRR micron score below the required 460 micron standard. However, a 2 percent biodiesel blend is required in No. 1 diesel to get the HFRR micron score down to 460 microns." Link to the article http://www.farmandranchguide.com/article...roduction_ news/prod20.txt Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana --------------------------------- Food fight? Enjoy some healthy debate in the Yahoo! Answers Food & Drink Q&A. [Non-text portions of this message have been removed] |
03-19-2007, 17:10
Jimmy,
I would agree that biodiesel has a higher gel point than Diesel. But when you are using as a blend, then the higher gel point will not be noticable. I believe this article used 1 - 2% as a basis. You would be able to run 1 - 2 % blend in any weather as long as the other 98 - 99 % is petro diesel. If you would need to add additives to petro diesel to keep from jelling, this wil take care of the biodiesel blend as well. The running of biodiesel is perfectly legal in the U.S. Actually the emmissions are better on the environment than the petro diesel product. It is endosed by the EPA and DOT. In fact, the government is promoting it by dumping millions of dollars in incentives to get the technology rolling becuase biodiesel is a renewable resource. Yes the biodiesel is a cleanser and will remove all the years of petro diesel deposits. This will end up in your filter but after your first tank full, your filter changes will go back to how you changed filters before. I change all of my filters ( gas & oil ) every 5k miles as a preventative. My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the time of the year. Of course I enjoy having about two days a year as a winter season. Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, James Harvie > > The first diesel that Rudolf Diesel marketed, was designed to run on straight vegetable oil, although the first diesel tested, ran on coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, to 80% Petrodiesel,(although Biodiesel is still illegal to use in the US due to epa regulations) The problem with Biodiesel is that it has a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used straight in cold weather, has to be preheated, in order to flow. the other concern would be that Biodiesel has more solvents, than Petrodiesel, which will disolve sludge that may be in the tank, so if one decides to go this route, plan on changing the filters frequently for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run one drop of that, without at least some form of lubrication additive, do to the fact, that it dosen't have enough Jimmy Harvie > 82 FC Boston Ma > Al someone found the following > article summarizing the wear that Ultra-Low Diesel has on diesel > engines. > > "A lower wear score indicates better lubricity. Biodiesel has been > tested at varying concentrations with No. 1 and No. 2 diesel fuels. The > results indicate that a 1 percent blend of biodiesel with No. 2 diesels > is sufficient to reduce the HFRR micron score below the required 460 > micron standard. However, a 2 percent biodiesel blend is required in > No. 1 diesel to get the HFRR micron score down to 460 microns." > > Link to the article > http://www.farmandranchguide.com/article.../productio n_ > news/prod20.txt > > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B75 > Mandeville, Louisiana > > > > > > > --------------------------------- > Food fight? Enjoy some healthy debate > in the Yahoo! Answers Food & Drink Q&A. > > [Non-text portions of this message have been removed] > |
03-19-2007, 17:25
Al. Thanks for setting me straight, on the point that Bio was legal to run in
the US. I read somewhere, that it was illegal. B100 how nice, do you live near a Potato Chip Factory? Al I would agree that biodiesel has a higher gel point than Diesel. But when you are using as a blend, then the higher gel point will not be noticable. I believe this article used 1 - 2% as a basis. You would be able to run 1 - 2 % blend in any weather as long as the other 98 - 99 % is petro diesel. If you would need to add additives to petro diesel to keep from jelling, this wil take care of the biodiesel blend as well. The running of biodiesel is perfectly legal in the U.S. Actually the emmissions are better on the environment than the petro diesel product. It is endosed by the EPA and DOT. In fact, the government is promoting it by dumping millions of dollars in incentives to get the technology rolling becuase biodiesel is a renewable resource. Yes the biodiesel is a cleanser and will remove all the years of petro diesel deposits. This will end up in your filter but after your first tank full, your filter changes will go back to how you changed filters before. I change all of my filters ( gas & oil ) every 5k miles as a preventative. My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the time of the year. Of course I enjoy having about two days a year as a winter season. Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, James Harvie > > The first diesel that Rudolf Diesel marketed, was designed to run on straight vegetable oil, although the first diesel tested, ran on coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, to 80% Petrodiesel,(although Biodiesel is still illegal to use in the US due to epa regulations) The problem with Biodiesel is that it has a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used straight in cold weather, has to be preheated, in order to flow. the other concern would be that Biodiesel has more solvents, than Petrodiesel, which will disolve sludge that may be in the tank, so if one decides to go this route, plan on changing the filters frequently for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run one drop of that, without at least some form of lubrication additive, do to the fact, that it dosen't have enough Jimmy Harvie > 82 FC Boston Ma > Al someone found the following > article summarizing the wear that Ultra-Low Diesel has on diesel > engines. > > "A lower wear score indicates better lubricity. Biodiesel has been > tested at varying concentrations with No. 1 and No. 2 diesel fuels. The > results indicate that a 1 percent blend of biodiesel with No. 2 diesels > is sufficient to reduce the HFRR micron score below the required 460 > micron standard. However, a 2 percent biodiesel blend is required in > No. 1 diesel to get the HFRR micron score down to 460 microns." > > Link to the article > http://www.farmandranchguide.com/article.../productio n_ > news/prod20.txt > > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B75 > Mandeville, Louisiana > > > > > > > --------------------------------- > Food fight? Enjoy some healthy debate > in the Yahoo! Answers Food & Drink Q&A. > > [Non-text portions of this message have been removed] > --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. [Non-text portions of this message have been removed] |
03-19-2007, 18:17
I dump 1 gal at a time of used motor oil in my 100 gal tank ( dump
truck). The used oil burns like diesel so a 10 gallon change returns you $30.00. I start putting in ATF when the used oil is gone. ATF is $9.00 per the gallon and replaces $3.00 worth of fuel so the cost is $6.00 per gallon. ATF is worth $6.00 per 100 gallons IMO. BioDiesel would have no cost as an additive because you burn the product as fuel and it is close to cost of #2 D. I never see it at the pumps I go to. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Al" > > Jimmy, > I would agree that biodiesel has a higher gel point than > Diesel. But when you are using as a blend, then the higher gel point > will not be noticable. I believe this article used 1 - 2% as a > basis. You would be able to run 1 - 2 % blend in any weather as long > as the other 98 - 99 % is petro diesel. If you would need to add > additives to petro diesel to keep from jelling, this wil take care of > the biodiesel blend as well. > > The running of biodiesel is perfectly legal in the U.S. > Actually the emmissions are better on the environment than the petro > diesel product. It is endosed by the EPA and DOT. In fact, the > government is promoting it by dumping millions of dollars in > incentives to get the technology rolling becuase biodiesel is a > renewable resource. > > Yes the biodiesel is a cleanser and will remove all the years of > petro diesel deposits. This will end up in your filter but after > your first tank full, your filter changes will go back to how you > changed filters before. I change all of my filters ( gas & oil ) > every 5k miles as a preventative. > > My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the > time of the year. Of course I enjoy having about two days a year as > a winter season. > > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B75 > Mandeville, Louisiana > > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > The first diesel that Rudolf Diesel marketed, was designed to run > on straight vegetable oil, although the first diesel tested, ran on > coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, > to 80% Petrodiesel,(although Biodiesel is still illegal to use in the > US due to epa regulations) The problem with Biodiesel is that it has > a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used > straight in cold weather, has to be preheated, in order to flow. the > other concern would be that Biodiesel has more solvents, than > Petrodiesel, which will disolve sludge that may be in the tank, so if > one decides to go this route, plan on changing the filters frequently > for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run > one drop of that, without at least some form of lubrication additive, > do to the fact, that it dosen't have enough Jimmy > Harvie > > 82 FC Boston > Ma > > Al > someone found the following > > article summarizing the wear that Ultra-Low Diesel has on diesel > > engines. > > > > "A lower wear score indicates better lubricity. Biodiesel has been > > tested at varying concentrations with No. 1 and No. 2 diesel fuels. > The > > results indicate that a 1 percent blend of biodiesel with No. 2 > diesels > > is sufficient to reduce the HFRR micron score below the required > 460 > > micron standard. However, a 2 percent biodiesel blend is required > in > > No. 1 diesel to get the HFRR micron score down to 460 microns." > > > > Link to the article > > > http://www.farmandranchguide.com/article.../productio > n_ > > news/prod20.txt > > > > Al, Kathy, Alfred & Daniel Johnson > > '96 BMC B75 > > Mandeville, Louisiana > > > > > > > > > > > > > > --------------------------------- > > Food fight? Enjoy some healthy debate > > in the Yahoo! Answers Food & Drink Q&A. > > > > [Non-text portions of this message have been removed] > > > |
03-19-2007, 19:40
Al. The article I was reading, was from Wikipedia/ burning vegetable oil. Under
"Legal Implications", It states, "The conversion of an automobile engine, to burn Vegetable oil is not legal under US EPA guidelines". This must apply to Gasoline engines, not sure. Jimmy Harvie Al I would agree that biodiesel has a higher gel point than Diesel. But when you are using as a blend, then the higher gel point will not be noticable. I believe this article used 1 - 2% as a basis. You would be able to run 1 - 2 % blend in any weather as long as the other 98 - 99 % is petro diesel. If you would need to add additives to petro diesel to keep from jelling, this wil take care of the biodiesel blend as well. The running of biodiesel is perfectly legal in the U.S. Actually the emmissions are better on the environment than the petro diesel product. It is endosed by the EPA and DOT. In fact, the government is promoting it by dumping millions of dollars in incentives to get the technology rolling becuase biodiesel is a renewable resource. Yes the biodiesel is a cleanser and will remove all the years of petro diesel deposits. This will end up in your filter but after your first tank full, your filter changes will go back to how you changed filters before. I change all of my filters ( gas & oil ) every 5k miles as a preventative. My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the time of the year. Of course I enjoy having about two days a year as a winter season. Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, James Harvie > > The first diesel that Rudolf Diesel marketed, was designed to run on straight vegetable oil, although the first diesel tested, ran on coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, to 80% Petrodiesel,(although Biodiesel is still illegal to use in the US due to epa regulations) The problem with Biodiesel is that it has a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used straight in cold weather, has to be preheated, in order to flow. the other concern would be that Biodiesel has more solvents, than Petrodiesel, which will disolve sludge that may be in the tank, so if one decides to go this route, plan on changing the filters frequently for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run one drop of that, without at least some form of lubrication additive, do to the fact, that it dosen't have enough Jimmy Harvie > 82 FC Boston Ma > Al someone found the following > article summarizing the wear that Ultra-Low Diesel has on diesel > engines. > > "A lower wear score indicates better lubricity. Biodiesel has been > tested at varying concentrations with No. 1 and No. 2 diesel fuels. The > results indicate that a 1 percent blend of biodiesel with No. 2 diesels > is sufficient to reduce the HFRR micron score below the required 460 > micron standard. However, a 2 percent biodiesel blend is required in > No. 1 diesel to get the HFRR micron score down to 460 microns." > > Link to the article > http://www.farmandranchguide.com/article.../productio n_ > news/prod20.txt > > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B75 > Mandeville, Louisiana > > > > > > > --------------------------------- > Food fight? Enjoy some healthy debate > in the Yahoo! Answers Food & Drink Q&A. > > [Non-text portions of this message have been removed] > --------------------------------- Be a PS3 game guru. Get your game face on with the latest PS3 news and previews at Yahoo! Games. [Non-text portions of this message have been removed] |
03-20-2007, 03:13
Jim,
There is a guy I think he lives in a New england state, who converted his Bluebird to run on used vegtable oil, he has special filtration system on his coach and apparently stops for a quick burger, fries and fill up all at once. Maybe Bruce can help you locate his information. Jim Riordan 88 WBWL XXV Stuart, Fl. --- In WanderlodgeForum@yahoogroups.com, James Harvie > > Al. The article I was reading, was from Wikipedia/ burning vegetable oil. Under "Legal Implications", It states, "The conversion of an automobile engine, to burn Vegetable oil is not legal under US EPA guidelines". This must apply to Gasoline engines, not sure. > Jimmy Harvie > Al > I would agree that biodiesel has a higher gel point than > Diesel. But when you are using as a blend, then the higher gel point > will not be noticable. I believe this article used 1 - 2% as a > basis. You would be able to run 1 - 2 % blend in any weather as long > as the other 98 - 99 % is petro diesel. If you would need to add > additives to petro diesel to keep from jelling, this wil take care of > the biodiesel blend as well. > > The running of biodiesel is perfectly legal in the U.S. > Actually the emmissions are better on the environment than the petro > diesel product. It is endosed by the EPA and DOT. In fact, the > government is promoting it by dumping millions of dollars in > incentives to get the technology rolling becuase biodiesel is a > renewable resource. > > Yes the biodiesel is a cleanser and will remove all the years of > petro diesel deposits. This will end up in your filter but after > your first tank full, your filter changes will go back to how you > changed filters before. I change all of my filters ( gas & oil ) > every 5k miles as a preventative. > > My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the > time of the year. Of course I enjoy having about two days a year as > a winter season. > > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B75 > Mandeville, Louisiana > > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > The first diesel that Rudolf Diesel marketed, was designed to run > on straight vegetable oil, although the first diesel tested, ran on > coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, > to 80% Petrodiesel,(although Biodiesel is still illegal to use in the > US due to epa regulations) The problem with Biodiesel is that it has > a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used > straight in cold weather, has to be preheated, in order to flow. the > other concern would be that Biodiesel has more solvents, than > Petrodiesel, which will disolve sludge that may be in the tank, so if > one decides to go this route, plan on changing the filters frequently > for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run > one drop of that, without at least some form of lubrication additive, > do to the fact, that it dosen't have enough Jimmy > Harvie > > 82 FC Boston > Ma > > Al > someone found the following > > article summarizing the wear that Ultra-Low Diesel has on diesel > > engines. > > > > "A lower wear score indicates better lubricity. Biodiesel has been > > tested at varying concentrations with No. 1 and No. 2 diesel fuels. > The > > results indicate that a 1 percent blend of biodiesel with No. 2 > diesels > > is sufficient to reduce the HFRR micron score below the required > 460 > > micron standard. However, a 2 percent biodiesel blend is required > in > > No. 1 diesel to get the HFRR micron score down to 460 microns." > > > > Link to the article > > > http://www.farmandranchguide.com/article.../productio > n_ > > news/prod20.txt > > > > Al, Kathy, Alfred & Daniel Johnson > > '96 BMC B75 > > Mandeville, Louisiana > > > > > > > > > > > > > > --------------------------------- > > Food fight? Enjoy some healthy debate > > in the Yahoo! Answers Food & Drink Q&A. > > > > [Non-text portions of this message have been removed] > > > > > > > > > --------------------------------- > Be a PS3 game guru. > Get your game face on with the latest PS3 news and previews at Yahoo! Games. > > [Non-text portions of this message have been removed] > |
03-20-2007, 03:25
James,
LOL .. I wish.. They have great oil for the conversion to biodiesel. I do live in the south where we love to eat. So there are plenty of resturants that love to bring me oil. At about .68 a gallong to make.. Its a great thing for me and my family. I have been using since November '05, so it is a safe product to use. Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, James Harvie > > Al. Thanks for setting me straight, on the point that Bio was legal to run in the US. I read somewhere, that it was illegal. B100 how nice, do you live near a Potato Chip Factory? > > Al > I would agree that biodiesel has a higher gel point than > Diesel. But when you are using as a blend, then the higher gel point > will not be noticable. I believe this article used 1 - 2% as a > basis. You would be able to run 1 - 2 % blend in any weather as long > as the other 98 - 99 % is petro diesel. If you would need to add > additives to petro diesel to keep from jelling, this wil take care of > the biodiesel blend as well. > > The running of biodiesel is perfectly legal in the U.S. > Actually the emmissions are better on the environment than the petro > diesel product. It is endosed by the EPA and DOT. In fact, the > government is promoting it by dumping millions of dollars in > incentives to get the technology rolling becuase biodiesel is a > renewable resource. > > Yes the biodiesel is a cleanser and will remove all the years of > petro diesel deposits. This will end up in your filter but after > your first tank full, your filter changes will go back to how you > changed filters before. I change all of my filters ( gas & oil ) > every 5k miles as a preventative. > > My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the > time of the year. Of course I enjoy having about two days a year as > a winter season. > > Al, Kathy, Alfred & Daniel Johnson > '96 BMC B75 > Mandeville, Louisiana > > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > The first diesel that Rudolf Diesel marketed, was designed to run > on straight vegetable oil, although the first diesel tested, ran on > coal dust. I wouldn't hesitate to run a mixed blend of 20% Biodiesel, > to 80% Petrodiesel,(although Biodiesel is still illegal to use in the > US due to epa regulations) The problem with Biodiesel is that it has > a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used > straight in cold weather, has to be preheated, in order to flow. the > other concern would be that Biodiesel has more solvents, than > Petrodiesel, which will disolve sludge that may be in the tank, so if > one decides to go this route, plan on changing the filters frequently > for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't run > one drop of that, without at least some form of lubrication additive, > do to the fact, that it dosen't have enough Jimmy > Harvie > > 82 FC Boston > Ma > > Al > someone found the following > > article summarizing the wear that Ultra-Low Diesel has on diesel > > engines. > > > > "A lower wear score indicates better lubricity. Biodiesel has been > > tested at varying concentrations with No. 1 and No. 2 diesel fuels. > The > > results indicate that a 1 percent blend of biodiesel with No. 2 > diesels > > is sufficient to reduce the HFRR micron score below the required > 460 > > micron standard. However, a 2 percent biodiesel blend is required > in > > No. 1 diesel to get the HFRR micron score down to 460 microns." > > > > Link to the article > > > http://www.farmandranchguide.com/article.../productio > n_ > > news/prod20.txt > > > > Al, Kathy, Alfred & Daniel Johnson > > '96 BMC B75 > > Mandeville, Louisiana > > > > > > > > > > > > > > --------------------------------- > > Food fight? Enjoy some healthy debate > > in the Yahoo! Answers Food & Drink Q&A. > > > > [Non-text portions of this message have been removed] > > > > > > > > > --------------------------------- > TV dinner still cooling? > Check out "Tonight's Picks" on Yahoo! TV. > > [Non-text portions of this message have been removed] > |
03-20-2007, 03:32
Hi Jim,
Yes I believe you are talking about Steve with a BMC. The technology of using straight vegie oil is really not a proven one. The vilosity of the oil is much thicker than biodiesel or petrodiesel. He succussfully coverted his bus to run on straight used oil but only time will tell. I am sure he believes in the technology and from what I saw in his pictures, he knows what he is talking about. A very nice professional conversion for sure. Certainly straight vegie oil will have even higher freeze temp than biodiesel or petro diesel. But people running those systems usually have some form of heating mechanism to get the oil upto engine temp. Then they swap off of petro diesel to staight cooking oil. Before they shut down they swap back to petro diesel to clense out the system so it will start again next time. Al, Kathy, Alfred & Daniel Johnson '96 BMC B75 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "jqrjr" > > Jim, > There is a guy I think he lives in a New england state, who converted > his Bluebird to run on used vegtable oil, he has special filtration > system on his coach and apparently stops for a quick burger, fries > and fill up all at once. Maybe Bruce can help you locate his > information. > > Jim Riordan > 88 WBWL XXV > Stuart, Fl. > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > Al. The article I was reading, was from Wikipedia/ burning > vegetable oil. Under "Legal Implications", It states, "The conversion > of an automobile engine, to burn Vegetable oil is not legal under US > EPA guidelines". This must apply to Gasoline engines, not sure. > > > Jimmy Harvie > > Al > > I would agree that biodiesel has a higher gel point than > > Diesel. But when you are using as a blend, then the higher gel > point > > will not be noticable. I believe this article used 1 - 2% as a > > basis. You would be able to run 1 - 2 % blend in any weather as > long > > as the other 98 - 99 % is petro diesel. If you would need to add > > additives to petro diesel to keep from jelling, this wil take care > of > > the biodiesel blend as well. > > > > The running of biodiesel is perfectly legal in the U.S. > > Actually the emmissions are better on the environment than the > petro > > diesel product. It is endosed by the EPA and DOT. In fact, the > > government is promoting it by dumping millions of dollars in > > incentives to get the technology rolling becuase biodiesel is a > > renewable resource. > > > > Yes the biodiesel is a cleanser and will remove all the years of > > petro diesel deposits. This will end up in your filter but after > > your first tank full, your filter changes will go back to how you > > changed filters before. I change all of my filters ( gas & oil ) > > every 5k miles as a preventative. > > > > My mixture goes from 50 % ( B50 )to 100 % ( B100 ) based on the > > time of the year. Of course I enjoy having about two days a year as > > a winter season. > > > > Al, Kathy, Alfred & Daniel Johnson > > '96 BMC B75 > > Mandeville, Louisiana > > > > --- In WanderlodgeForum@yahoogroups.com, James Harvie > > > > > > > > The first diesel that Rudolf Diesel marketed, was designed to run > > on straight vegetable oil, although the first diesel tested, ran on > > coal dust. I wouldn't hesitate to run a mixed blend of 20% > Biodiesel, > > to 80% Petrodiesel,(although Biodiesel is still illegal to use in > the > > US due to epa regulations) The problem with Biodiesel is that it > has > > a high gel rate, (+32*F) compared to Petrodiesel (-15*F) so if used > > straight in cold weather, has to be preheated, in order to flow. > the > > other concern would be that Biodiesel has more solvents, than > > Petrodiesel, which will disolve sludge that may be in the tank, so > if > > one decides to go this route, plan on changing the filters > frequently > > for a while. As for this new Ultra Low Sulpher Diesel, I wouldn't > run > > one drop of that, without at least some form of lubrication > additive, > > do to the fact, that it dosen't have enough Jimmy > > Harvie > > > 82 FC Boston > > Ma > > > Al > > someone found the following > > > article summarizing the wear that Ultra-Low Diesel has on diesel > > > engines. > > > > > > "A lower wear score indicates better lubricity. Biodiesel has > been > > > tested at varying concentrations with No. 1 and No. 2 diesel > fuels. > > The > > > results indicate that a 1 percent blend of biodiesel with No. 2 > > diesels > > > is sufficient to reduce the HFRR micron score below the required > > 460 > > > micron standard. However, a 2 percent biodiesel blend is required > > in > > > No. 1 diesel to get the HFRR micron score down to 460 microns." > > > > > > Link to the article > > > > > > http://www.farmandranchguide.com/article.../productio > > n_ > > > news/prod20.txt > > > > > > Al, Kathy, Alfred & Daniel Johnson > > > '96 BMC B75 > > > Mandeville, Louisiana > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Food fight? Enjoy some healthy debate > > > in the Yahoo! Answers Food & Drink Q&A. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > --------------------------------- > > Be a PS3 game guru. > > Get your game face on with the latest PS3 news and previews at > Yahoo! Games. > > > > [Non-text portions of this message have been removed] > > > |
